Like Tree21Likes
Old 04-20-2014, 09:52 AM   #2026
Robert_K's Avatar
Originally Posted by hydrakermit View Post
Hi all,
What I wondered was where would I get a 78T, 79T, 80T, 81T, 82T, 83T, and 84T Spur gears from? I have the gear chat with ratios on but I cant find anywhere that sell these size spur gears.
Thanks in advance
I don't think Schumacher makes them? They just make some of them. Like 80T, 84T, 86T, 90T.
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 04-20-2014, 10:26 AM   #2027
SteveM's Avatar
Trader Rating: 133 (100%+)
Hi all,
Thanks in advance
Why not check on the Schumacher web page? There you will see that they offer 70, 74, 85, 87 and 89 in 48P as well as 90, 96, 114, 116 and 118 in 64P. Spurs gears for the Mi5 are proprietary and you are stuck with what is offered.
SteveM is offline   Reply With Quote
Old 04-20-2014, 12:08 PM   #2028
hydrakermit's Avatar
Ok thanks, I just thought I may of been able to get different spurs in order to get the gear ratio for blinky I want and that between 4.5 and 5.4, but none of the spurs give me these rations in 48dp and I really don't want to change to 64dp
hydrakermit is offline   Reply With Quote
Old 04-20-2014, 01:47 PM   #2029
SteveM's Avatar
The selection of spur gears is limited but there's nothing you can do. I run 64P on my Mi5 and in 17.5 blinky I use a 90T spur and 46T pinion for a 3.5 FDR
Old 04-21-2014, 10:54 AM   #2030
poochy's Avatar
try RW spur gears http://www.rwracing.co.uk/cars.html
48Dp 68-74, 78, 83, 85, 89
poochy is offline   Reply With Quote
Old 04-21-2014, 10:17 PM   #2031
Ive been told the RW range fit but I was unsure. Will try thanks
Old 04-22-2014, 12:15 AM   #2032
Robert_K's Avatar
I had my first race and had a nice battle with the leader. Just couldn't get past him in the first two finals. And the third I got past him, but it didn't matter :P. It sure was fun!
It was a really tight and twisty track. The grip was low, but the car was really good! Also it was nice and sunny weather.
Set-up via this link: https://www.dropbox.com/s/644zir8tfi...20-04-2014.pdf
Regards Robert
Old 04-29-2014, 07:49 AM   #2033
What would you like to see on a new car.
Me, a harder bumper, better steering rack a bit more robust, gear diff that can go in the front as well as the back. What do you think.
big paul is offline   Reply With Quote
Old 04-29-2014, 07:49 AM   #2034
double post
Old 04-29-2014, 08:52 AM   #2035
Robert_K's Avatar
1. Harder bumper, I'm not having any problems with that, but okay
2. Better steering rack. I'm also not having any problems with it not being robust? I would like to see more holes for more ackermann adjustment. For example the two center holes Ed made on his car.
3. Geardiff in front, a Schumi "own" front geardiff and not a SpecR version, I really like the quality of the schumi diff's.
4. The axle clamps like all other brands have. This clamp type, with the O-ring to ensure the pin gives a lot of play in the rotation movement. It feels like the drive shafts have worn out, but are still new. This type of play is in the clamps. Also the front to back movement is harder to adjust with shims. When you tighten the wheel nut, it takes away room arround the bearings. I just like the normal clamp type other brands have.
5. A way to give the car 0,5 degree armsweep at front, or a different (spare part) arm, to adjust arm sweep, like the rear toe.
6. It's a heavy car, maybe it could loose some weight.
Please keep all the nice carbon parts. The arms and stuff. I really like the idea of all these parts and the uniqueness of the car. I think that's it, I'm really happy with the car, like it is. It's really easy to work on, and the quality of the parts is really good if you ask me.
Regards Robert
Old 04-29-2014, 08:58 AM   #2036
Robert_K's Avatar
Schumacher takes both Modified and Stock titles in the first round of the Dutch Nationals:
http://www.redrc.net/2014/04/dutch-e...A8/#more-80365
My set-up before the rain came in:
https://www.dropbox.com/s/g8llefhydf...27-04-2014.pdf
Track looks a lot like the latest set-up I've posted. It has a bit more grip, and is a little bit more flowing, but still really tight and a lot of slow corners.
Hope it helps.
Regards Robert
Old 04-29-2014, 09:06 AM   #2037
SteveM's Avatar
1. More slop free steering rack
2. Dual Cardan CVD's as standard in the kit
3. An easier way to change shims under the suspension arms
4. Stronger front bumper plastics
Old 04-29-2014, 10:37 AM   #2038
poochy's Avatar
the mi5 is awesome, an upperdeck tweak proof sedan! much better than the mi4.
1. cvd pins coming off has caused me 2 races in 4 years (mi4/mi5)--not bad-but always on my mind, lets change to the modern retainer ring/clip style-not requiring threadlock around that area.
2. a kit that comes with Martin H's. grub screw style of eliminating the outer hinge pin slop
3. provide a 3rd gear diff oring with the kit
4. shorter shock shaft
5. rsd reflex racing shock o-rings
6. a slimmer wrench, the one that is used for the tightening down the arms to the chassis
7. a truely tested stock kit setup for asphalt and carpet not requiring anything else not included in the box
easiest suggestion-let Martin H test the car, make the improvements and then release the new car
Old 05-03-2014, 07:59 PM   #2039
TryHard's Avatar
Finally finished my diff build blog post....
http://www.thard.co.uk/mi5-diff-build/
Regards
Ed
Old 05-04-2014, 06:17 AM   #2040
How does the Mi5 compares with T4?
Prince Nuada is offline   Reply With Quote
