Like Tree21Likes
Old 04-03-2014, 10:42 AM   #2011
BardSmith's Avatar
Trader Rating: 59 (98%+)
Originally Posted by DiscountRCStore View Post
... We have seen pics of prototypes and are working to secure one to test ourselves, however there isn't one commercially available at the moment; that we're aware of at least. We will post should one become available ...
...p
Sounds good Phil. Let us know when you have some news!
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 04-07-2014, 01:36 AM   #2012
hydrakermit's Avatar
Default Shock Length (X)
Hi all,
Just a quick question, I want to shorten my shock length from 12.5mm to 10.5mm, how would I go about doing this?
At the moment I have put a 2mm spacer inside the shock, will this make any difference on the outcome?
Any help is appreciated.
Many Thanks,
hydrakermit is offline   Reply With Quote
Old 04-07-2014, 03:06 AM   #2013
Robert_K's Avatar
My Schumacher Mi5.
Nothing special like me previous cars, but still clean enough :-)
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 04-07-2014, 03:07 AM   #2014
Robert_K's Avatar
Originally Posted by hydrakermit View Post
Hi all,
Many Thanks,
This is an option, but will make the "pack fluid" smaller above the piston.
You can also dremel the shockshafts shorter (where the threat is, not where the clips are) like Martin Hofer has described on his blog. This is something I've also done and is pretty easy to do.
Regards Robert
Old 04-07-2014, 04:30 AM   #2015
Regards Robert
Many Thanks
Old 04-07-2014, 04:31 AM   #2016
My Schumacher Mi5.
Regards Robert
Looks Great!
Old 04-08-2014, 11:18 PM   #2017
Hello, i was just wondering if anyone knew if Hot Bodies #68290 44mm/2mm universal driveshafts would fit the Mi5 CVDs, or if there was a mismatch in size/pin thickness at the joint end. Thanks, Matt
matt31313 is offline   Reply With Quote
Old 04-09-2014, 12:46 AM   #2018
Trader Rating: 25 (100%+)
No they don't. The mi5 cvd's have a larger ball where the pin goes though.
Gtr r34 m-spec is offline   Reply With Quote
Old 04-09-2014, 08:01 AM   #2019
poochy's Avatar
per Martin Hofer:
"I like to only use 1 of the big spacers per big gear instead of two as according to the manual. The missing big spacer needs to be taken in mind, when adding shims to the outdrive. Therefore I use 3 small ones in stead of 2."
1 big spacer inside, 3 little spacer outside - will building the gear diff in the above manner hold up for MOD racing or is that for stock racing?
poochy is offline   Reply With Quote
Old 04-16-2014, 11:24 PM   #2020
Old 04-17-2014, 02:33 AM   #2021
TryHard's Avatar
Originally Posted by poochy View Post
per Martin Hofer:
It's fine, and how I run my diffs. Actually been meaning to write up the diff build I use as a new blog post... maybe this easter weekend I'll get round to it!
Old 04-18-2014, 06:30 AM   #2022
poochy's Avatar
yep-raced mod with 3 lil shims outside and 1 big shim inside, and it works fine for mod
i am finding that the "Caster Block Bolt Fix track power 4x14 bolt" has a lot of slop after 2 race days (slop between bolt shaft and bearing inner circle)--i have switched to the schumacher V2 caster king pin bolt, lets see if this has less slop after a few races..
Old 04-18-2014, 09:08 AM   #2023
DiscountRCStore's Avatar
.. it's been found that some of the slop can come from where the bearings insert into the plastic mold itself.. if this is the case, you can try scoring a crosshatch pattern into the plastic with a hobby knife which will tighten it up for a bit.. we've gone as far as creating a small flat spot on the bearing case and fitting grub screws into the molds.. (similar to the hinge pin mod, pics on the previous pages). We have located someone who's looking into the bushing idea again.. We will post should that produce positive results.. hope it helps..
..p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 04-18-2014, 10:09 AM   #2024
poochy's Avatar
..p
thanks, to me the king pin bolt fit inside the bearing circle is the majority of the slop and not the circular cut out where the bearing sits in. putting a bushing there would cause more post/bearing slop--but ill keep an eye on the insert mould and fix it the way you mention when that slop creeps up.
as for the post/bearing slop-temp fixes are ca and threadlock to fill the gap between the bolt and bearing-threadlock proved to work on the tc5 (steering post slop)
i have seen this type of slop improved by going to a double post setup-two posts and two bearings.
Old 04-19-2014, 02:41 PM   #2025
Talking 48DP Spur gears
Hi all,
What I wondered was where would I get a 78T, 79T, 80T, 81T, 82T, 83T, and 84T Spur gears from? I have the gear chat with ratios on but I cant find anywhere that sell these size spur gears.
Thanks in advance
