Old 03-24-2014, 01:12 AM   #1981
hydrakermit's Avatar
Default C/F 2mm Chassis Conversion Set
http://www.racing-cars.com/pp/New_Ca...Mi5/U4398.html
How are the braces fitted on this please? Any pictures? And is this better than the kit standard 2.5mm chassis for carpet or tarmac?
hydrakermit is offline   Reply With Quote
Old 03-24-2014, 04:25 AM   #1982
TryHard's Avatar
I've found the 2mm chassis to be very good outdoors, sharpens up the reaction of the car, as despite being thinner, the weave used is stiffer than the standard chassis. The braces help to improve mid-corner rotation as well. Add in that the chassis is also 15g lighter, and lowers the whole car 0.5mm (for a lower CoG), and you've got a win-win.
Old 03-24-2014, 08:42 AM   #1983
Oh cool, Any good for indoors on carpet? and has anyone got any pics of how the braces are fitted on the chassis please
Old 03-24-2014, 02:00 PM   #1984
Mopar's Avatar
It looks like the braces mount the same as the Wild Thing braces. If you look there are pics on this thread of them.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 03-24-2014, 02:06 PM   #1985
Ok thanks, any idea where as I have no clue hehe
Old 03-24-2014, 03:37 PM   #1986
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
Use the search feature
Serpent project 4x
jeff jenkins is offline   Reply With Quote
Old 03-24-2014, 11:38 PM   #1987
Old 03-25-2014, 03:18 AM   #1988
TryHard's Avatar
And if in doubt, here are the instructions
Old 03-26-2014, 07:53 PM   #1989
So I know its a little late now but I had my first outing with my schuie MI5 last Saturday. I am running it in the mid motor config and after some adjustments I have gotten it to my liking as at first the rear end was really loose and couldn't even get on power exiting a corner . im running mod btw. what I ended up doing was at first I widened the rear of the car by 4.5mm and that helped slightly but it was still too loose for my liking. so the next thing I did was remove all roll center shims from under the arm mounts in the rear and leaving the 1mm under the front ones so I had the lowest roll center possible and this helped out tremendously! now I can get on power. I also ended up leaning in the shocks 1 hole in the rear from kit setting and this also feels real good. now I can really rip out of the corner in mid motor config. the last thing I did before the main was upped my diff oil from 3k to 5k and this has helped out with all around stability around the track . so far every change has made the car better and is improving the lap times each time so looking forward to the next race. the parts I am currently running are the 2mm chassis with the braces and the dcj front shafts .
Serpent project 4x
Old 03-27-2014, 01:50 AM   #1990
HappyHippo's Avatar
Jeff..... Try front geardiff with 1.000.000 in it.... that rocks in mod
HappyHippo is offline   Reply With Quote
Old 03-27-2014, 06:03 AM   #1991
Got one on the way to try
Serpent project 4x
Old 03-28-2014, 02:18 AM   #1992
HappyHippo's Avatar
Just remeber to take the edges of the sliders
Old 03-28-2014, 08:09 AM   #1993
Now you say 1,000,000wt in the front diff but have you tried 2,500,000wt
Serpent project 4x
Old 03-30-2014, 05:29 AM   #1994
Robert_K's Avatar
Yesterday I had my second outing with the car.
The first day was at my local track, which is really tight and small. The car felt with the "box set-up" good but pretty under steered. Not so strange on a tight track ;-). Changed some small things, diff oil, roll center at rear and the car kept going better and better.
The thing I was mostly surprised by was the overall grip. This track is really dusty and low grip and the car felt really good from the first battery on really old tires.
Second day out was at AMCA Apeldoorn. This track has seen the ETS a few times. There were some top drivers, Crissy Crapp, Toni Rheinhard and Yannic Prumper.
I changed the rear toe-out to 2deg. The diff Oil to 800CST (like I had in my previous car at the ETS). Also changed the roll center at the back. At the end of the day I ran out of time to change more, and the car was really fast, just lacked at bit at mid corner.
Again, the car had awesome grip! And also it's really easy when you clip the curbstones. More easy then other cars. I also liked the kit springs more than the HotBodies Silver springs which I normally always drive .
So after two day's... Awesome car! A massive load of grip. Really easy to "place" at a corner. My only negative point is, that the eyelets have a lot of slop. I know Hofer has described in his blog how to get rid of, but I've seen other brand were this was not necessary.
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 03-30-2014, 01:15 PM   #1995
HappyHippo's Avatar
No... i would, but no shop here has it... orderd it from Hong Kong ....
