Like Tree21Likes
Old 02-01-2014, 10:58 AM   #1876
haywood's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Shock Tower View Post
Hi guys.
How do you balance you Mi5 from side to side.
I think that using spikes in under the chassie in front and rear is the normal way, but where do you get such 'spikes' and in wich holes are you using for the job ?
There is a Schumacher Option Part for that. U3582
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 02-01-2014, 11:24 AM   #1877
Ah, thanks.
Just to bad that they are out of stock :-(
Shock Tower is offline   Reply With Quote
Old 02-02-2014, 01:08 PM   #1878
haywood's Avatar
Default Martin Hofer
Anyone have any pics or setups of his car from the last Ets race?
Old 02-03-2014, 10:32 AM   #1879
I had a good and long traning day yesterday. The track was on carpet with good grip, and with a good layout, with long sweeps and long straight, and also a tight in the middel of the track.
I ran 17.5T novak Vulcan, in super stock, and most of my setup was martin hofer standard carpet. I had the wildthing rear and front brace, and an extra alu chassi stiffner.
The car was easy to drive, and with a lot og steering going into turns and also on power control.
I tried to take off the front brace, but found that I couldn't push so hard at the same entry and exit of corners, as if I had the front brace mounted.
I also have a set of wishbones front and rear there are cut, and I was thinking of trying them out soon. What can I expect of the car, when mounting these on a similar track and high grip carpet ?
Old 02-03-2014, 04:09 PM   #1880
DiscountRCStore's Avatar
Yes that is correct
Ah, thanks.
..There are some available in the shop..
.. in our experience, it allows the arms and chassis to flex slightly more offering a bit more traction on the end they're used on. Similar to harder or softer plastics with the other manufacturers..
..p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 02-04-2014, 03:52 PM   #1881
New bits from Wild Thing ...
..p
Old 02-05-2014, 02:02 AM   #1882
TryHard's Avatar
Want to know how to make your Mi5 a little lighter? I've updated my website/blog with a few suggestions... roll on the weekend
http://www.thard.co.uk/?p=55
Old 02-05-2014, 02:13 AM   #1883
Very good info! My car weights in at 1380 right now! have a order from fastener on its way and a package with titan turnbuckles
21.1g saved with the screws sounds like a good start
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 02-05-2014, 08:04 AM   #1884
Trader Rating: 14 (94%+)
[QUOTE=TryHard;12977912]Want to know how to make your Mi5 a little lighter? I've updated my website/blog with a few suggestions... roll on the weekend
http://www.thard.co.uk/?p=55[/QUOTE ]
good suggestion. so Tell me do u also shorten wires from the electronics?do you know how much weight you would save by shortening the wires? I've been not wanting to do that just in case I need to use my electronics in the other cars that require longER wires.
Capricorn LAB C03, Serpent Project 4X, Airtronics M12, Airtronics Super Vortex
snuvet75 is offline   Reply With Quote
Old 02-05-2014, 12:39 PM   #1885
got my screws from fastener today, made a difference of 25g on my car (changed most screws, kept std steel in steering and motormount), now just have to wait for the titan turnbuckles and see what they do on the weight
Old 02-05-2014, 03:29 PM   #1886
I found 8.4g saved with Ti studs and 5g saved with the Ti turnbuckles. Nice thing about the studs and turnbuckles are that they are 'high' weight so you reduce the rolling moment.
On Road: VBC WF D06, A700 Evo, Mi5
Off Road: K1, DEX408
cgroves is offline   Reply With Quote
Old 02-12-2014, 09:58 AM   #1887
Default Mi5 round up for Welland
So how many Mi5s are we going to see at the Canadian Indoor Nats in Welland next month? I know I'm bringing 2 for CVTA and 17.5 blinky.
Old 02-13-2014, 12:45 PM   #1888
Just discovered that one of my rear wishbones precision balls have fairly amount of sloop when the shocks are dismounted.
Is there any fix to get rid of this kind of sloop ?
Old 02-13-2014, 02:26 PM   #1889
Just got my hard bumper foams from the guys at DiscountRCStore. They fit awesome and look like they'll really improve the durability of the front of the car. They are way harder that the stock bumpers from the kit. Next club race is just over a week away, I'll post their performance in a followup.
Old 02-13-2014, 02:36 PM   #1890
haywood's Avatar
If I'm thinking correctly I think you can replace them if you can get them out. I would try to hang the arm in a can of acetone to try to loosen the glue. I'm sure Phil could tell us if this would work?
