Like Tree21Likes
Old 12-29-2013, 03:54 PM   #1771
havent had any issues with the casterblock so far (2 race meetings and 2 practice sessions) but interested in knowing what c hub is that?
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 12-29-2013, 04:07 PM   #1772
That looks like the C-hub and knuckle off an Mi4CXL.
On Road: VBC WF D06, A700 Evo, Mi5
Off Road: K1, DEX408
cgroves is offline   Reply With Quote
Old 12-30-2013, 01:12 AM   #1773
HappyHippo's Avatar
Med flex c-hubs, sterring you can use tamiya or HB, but i did end up with the ons from the mi4 they seens to hold better...
HappyHippo is offline   Reply With Quote
Old 12-30-2013, 03:40 AM   #1774
The Teacher's Avatar
Trader Rating: 48 (100%+)
HappyHippo, using the different c-hubs does what for the car? Did you do this just to get rid of slop in the front?
The Teacher is offline   Reply With Quote
Old 01-04-2014, 11:21 AM   #1775
reg
Has anyone tried the stiff chassis on carpet and Tarmac,does it work ok on both?for carpet it it better to just fit the mid or fiddle with the setup?
reg is offline   Reply With Quote
Old 01-04-2014, 12:24 PM   #1776
I have some questions that I hope someone can anwser.
1: is any using the optional rear hub carrier 2 dink ? And what does you think about them compared to the standard ones.
2: what does the topdeck mounts in aluminium do to the driving ?
3: I started with 2000CST in my diff, but has now tried 3000CST and like it, but what are you running. (I am driving 13.5T blinky)
Shock Tower is offline   Reply With Quote
Old 01-04-2014, 01:22 PM   #1777
haywood's Avatar
Default Mi5
I run indoors on carpet and I'm running 1k in the rear diff. I've played with multiple top deck variations but have gone back to running just the rear stock mount. I've tried the Jet Hobbies aluminum mounts also but I'm most comfortable with the stock rear mount only.
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 01-04-2014, 01:45 PM   #1778
HappyHippo's Avatar
did get more feeling on lowgrip track, car was more easy to drive when the grip was low....
Old 01-04-2014, 02:13 PM   #1779
KBRacing's Avatar
Hi haywood,
Do you have a website where I can find the Jet Hobbies aluminum mounts .......???
KBRacing is offline   Reply With Quote
Old 01-04-2014, 02:46 PM   #1780
reg
Have you got a part number,did they just bolt on with no mod?
Old 01-04-2014, 03:36 PM   #1781
haywood's Avatar
Originally Posted by KBRacing View Post
Hi haywood,
http://www.discountrcstore.com/mobile/default.aspx
Contact Phil. I don't think he has them on his website.
Old 01-04-2014, 03:45 PM   #1782
TryHard's Avatar
Questions??
In response;
1) the optional rear hub plates can help with freeing the car up on tighter tracks. I tend to flick between the two groove on a track with tight hairpins, and the kit plates on a track that is more flowing. On a flowing open track, the two groove can make the car over rotate on exit a little, but does help with initial stability too. Honestly, best thing to do (as they aren't expensive) is try them. The two groove moves the outer rear link in towards the car centre 2mm, and the one groove 1mm, so shorter links than the kit plates. One good thing is that one full turn of the camber link tie rod equates to 1mm... So changing the plates is pretty quick and painless, and don't even need to use gauges (I have checked this against gauges mind)
2) I assume you mean the top deck mounts that go against the shock towers? If so, the aluminium mounts are a little stronger and stiffer, and this is more so in higher ambient temperatures, as the plastic mounts soften in heat. They also do away with any need for lock nuts, as the alu mounts are all threaded.
3) For modified, I tend to use 2000 or 3000 oil. I do have a diff with 4k ready to go. I tend to find that a thicker rear oil really helps with on power steering, although needs a better trigger finger in mod. Lower than 2k, and the car tends to diff out, IMO.
HiH
Ed
Old 01-04-2014, 04:06 PM   #1783
HappyHippo's Avatar
You have to mod them, best tool for shumi drivers are dremmel.....
Old 01-04-2014, 08:08 PM   #1784
I am in desperate need of a stock top deck for my MI-5. Phill at Discount does not have any. Any one know where I can pick 1 up?
gdcopbdcop is offline   Reply With Quote
Old 01-04-2014, 08:35 PM   #1785
haywood's Avatar
http://www.amainhobbies.com/product_...tor-Top-Deck-2
