Like Tree21Likes
Old 12-09-2013, 11:59 AM   #1711
When using the Wildthing shock alu mounts, what size screw do you use on each side, and do you use any shims on the back of the shock tower.
Shock Tower is offline   Reply With Quote
Old 12-09-2013, 12:18 PM   #1712
KBRacing's Avatar
Does anyone know where to buy Wild Thing parts.....??
KBRacing is offline   Reply With Quote
Old 12-09-2013, 01:14 PM   #1713
DiscountRCStore's Avatar
..We've been using alloy 3x6 buttonheads on both sides; haven't needed any shims.. finish with a 3mm countersunk washer mounted backwards; reference haywoods pic on the last page..
... next shipment due in close to Christmas...
..p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 12-09-2013, 02:07 PM   #1714
KBRacing's Avatar
Do you know if they ship internationally......???
Old 12-09-2013, 02:39 PM   #1715
Yes we do.. I suggest USPS First Class Package International for the best rates..
..p
Old 12-14-2013, 12:52 PM   #1716
haywood's Avatar
Trader Rating: 48 (100%+)
Default Slop
I've developed some slop in my rear hubs and in the rear arms where they mount to the chassis. Looks like its in between the pivot ball and plastic inserts. Anyone else have this problem?
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-14-2013, 01:26 PM   #1717
Me to. But it is not back and forth, but upwards. Overall I think there is to much slop in the Mi5. It is worse in the front in the caster blocks, and I have not yet heared about a fix, ore a statement from Schuamcher if this is normal or what to do to solve these slop things.
Old 12-15-2013, 04:30 PM   #1718
Mopar's Avatar
heard something about a set screw mod to eliminate slop in the front and rear hubs. Found this from Adrian: To get rid of the slop in the front caster block and rear hubs drill a 7/64" hole for an M3 set screw from the bottom of the part to the hinge pin hole. Use m3x3mm pinon set screws. Works great.
I also squished my ball cups per Martin's blog and that got rid of all remaining play. My car's suspension is very free moving but has zero slop in any direction.
Adrian Martinez
Mopar is offline   Reply With Quote
Old 12-16-2013, 04:13 AM   #1719
sgp-chris's Avatar
Hi guys,
Just bought myself an Mi5, and I need some pinion advice.
I plan to run a 17.5 SpeedPassion V3 motor with no timing. The track is indoor carpet, with a medium lengt straight.
What pinion/pinions should I get to start with? I plan on using the 48p spur, but I'm curious to know why some choose to run 64p?
Cheers
Xray-shop.dk - Xray T4'17 - Xray X1'17 - #PHUB
sgp-chris is offline   Reply With Quote
Old 12-16-2013, 11:22 AM   #1720
Adrian Martinez
The main problem seems to come from the kingpin going through the bearing in the front mini caster block, and not from the caster block and the hinge pin. It is realy irretating with all the sloop in the front.
Old 12-16-2013, 02:57 PM   #1721
Mopar's Avatar
Did you replace the king pin screw w/ the suggested 4mm x 14mm buttonhead screws?
Old 12-16-2013, 04:01 PM   #1722
olhipster1's Avatar
Trader Rating: 95 (100%+)
Send a message via Yahoo to olhipster1
Originally Posted by sgp-chris View Post
Hi guys,
Cheers
I always use 96 spur or lower.... pinion will depend on the motor and temperature.
Try to start around 3.9 final then go down from there..... not sure how much built in timing the SP motor has (check the SP thread).
Have fun
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 12-16-2013, 04:38 PM   #1723
Trader Rating: 38 (100%+)
For a Speed Passion I'd start around a 4.5 and work from there. Even the fixed (10 degree) timing motor works well at that ratio. Anything more just deadens the bottom and doesn't seem to gain any top speed.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 12-16-2013, 04:51 PM   #1724
Mopar's Avatar
SP v3 17.5 has 0-10 degrees adjustable timing, if it's the MMM version those have 15 degree max sensor boards.
Old 12-17-2013, 08:55 AM   #1725
sgp-chris's Avatar
Does anybody know if there are other dcj's that fit the Mi5 besides the Spec-R axles?
