Like Tree21Likes
Old 11-17-2013, 05:42 AM   #1636
Originally Posted by snuvet75 View Post
That's interesting because I thought front spool gives more entry steering..
The idea of a front spool is to give better traction out of the corner by locking the front axles together, the downside is that it kills turn in steering. Not a problem on large asphalt tracks as the reduced steering helps stabilise the car under braking.
Spools came about because we used to use front one ways as the extra traction out of the corners of the locked front axle was faster, but rear wheel only braking made the cars very unstable and front one ways were starting to be banned from some big meetings. The spool gave you that extra traction out of the corners, and the chassis were redesigned to compensate for the lack of entry steering from the spool.
In theory a front diff will always be faster on tight high grip carpet tracks, but with chassis design and setup based around the front spool it's not always the case.
terry.sc is offline   Reply With Quote
Old 11-17-2013, 01:01 PM   #1637
HappyHippo's Avatar
Try this setup... this track had monstergrip, and cars did tractionroll...
http://hofaaa.files.wordpress.com/20..._hrotovice.pdf
This setups is awsome with sorex 28, car is a litle more "egdy" with spool, you can also try Yokomo yellow spring in the rear...
HappyHippo is offline   Reply With Quote
Old 11-18-2013, 04:08 AM   #1638
subzero2k's Avatar
Hi,
what do you need the small carbon parts for? They come with the stiff chassis.
Maybe to connect the left and rigth pivot balls in the wishobones and make the alloy screws last longer?
http://www.redrc.net/2013/09/schumac...ssis-ti-balls/
Greetings
Offroad: Kyosho MP9e TKI, Kyosho MP9 TKI3, Kyosho RB6
Onroad: ARC R10 2013, Schumacher Supastox, Tamiya M05 Vers.2 Pro, Sakura D3 CS
(Tamiya TT01, TA03R, R.I.P XD)
subzero2k is offline   Reply With Quote
Old 11-18-2013, 04:25 AM   #1639
TryHard's Avatar
Originally Posted by subzero2k View Post
Hi,
Greetings
They do two things. Help to stop screws pulling through the chassis in a big accident, and also stiffen the rear of the car up and help it rotate through the corners better.
Alternatively, you can leave them off and use alloy screws in the back of the car as well as the front.
HiH
Ed
Old 11-18-2013, 11:32 AM   #1640
I crash tested my Mi5 pretty decently the last couple race nights (really bad driving on my part - not enough sleep). Nothing broke or tweaked
DavidNERODease is offline   Reply With Quote
Old 11-21-2013, 07:15 PM   #1641
silvalis's Avatar
Trader Rating: 29 (100%+)
So Hara was driving an Mi5 on the weekend...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 11-21-2013, 07:18 PM   #1642
snuvet75's Avatar
Trader Rating: 14 (94%+)
Where? How did you find it out? Is he thinking of driving for Schumacher?
Capricorn LAB C03, Serpent Project 4X, Airtronics M12, Airtronics Super Vortex
snuvet75 is offline   Reply With Quote
Old 11-21-2013, 07:19 PM   #1643
silvalis's Avatar
http://www.redrc.net/2013/11/atsushi...-opening-race/
I doubt it. He seems to be having a go at every car in every class across the market.
Old 11-21-2013, 07:19 PM   #1644
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
whoops, got to it before i did
Dan is offline   Reply With Quote
Old 11-22-2013, 04:08 PM   #1645
Trader Rating: 72 (100%+)
If interested in a brand new Mi5 for an excellent price, please check below link.
Schumacher Mi5, brand new, never run
waswadener is offline   Reply With Quote
Old 11-23-2013, 11:01 AM   #1646
I have two Mi5 cars, and both of the have leaking diffs. It seems to come out from where the two parts are assembly togehter, and comming out where the two o-rings are located. Does anyone have a fix for this ?
Shock Tower is offline   Reply With Quote
Old 11-23-2013, 02:57 PM   #1647
chiefj48's Avatar
Use three o-rings and no more leaks
chiefj48
Home of the; 2016 ROAR On Road Paved Nationals
Special Thanks, Serpent USA, Awesomatix USA, Valkaria RC, Trinity, Discount RC Store, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is online now   Reply With Quote
Old 11-23-2013, 07:22 PM   #1648
DiscountRCStore's Avatar
Pm or email me, we have them available by themselves ..
+1,.. that's the ticket!
..p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 11-23-2013, 11:39 PM   #1649
snuvet75's Avatar
Pressure is too high. Too much oil or air bubble. Let it sit till all air bubbles are gone before you close the diff case. Fill the oil only till the shafts meet the level of oil. If not, ask anybody else LOL
Old 11-25-2013, 09:36 AM   #1650
haywood's Avatar
Trader Rating: 48 (100%+)
Default Mi5
Had a great day club racing with the Mi5! Car is on pace and has been very durable. Finished 3rd after starting 9th in the A! 3 orings solved the leaking rear diff. I'm running the shocks with the cut shafts and Yokomo Springs. (Emulsion style)
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
