Old 11-05-2013, 06:20 PM   #1621
olhipster1's Avatar
Trader Rating: 89 (100%+)
Send a message via Yahoo to olhipster1
Originally Posted by The Teacher View Post
olhipster1, you forgot to get Phil's info from me before I left on Sat. He will be able to get you what you need Hope you are working on that car....I've been in the lab the last 2 days got some good stuff cooking with the Mi5
got the number....Phil contacted me in minutes after I posted...
I've dismantled the car...found my problem...
spool cup was damaged and bore into the spool itself.... waiting on a new spool to come in.....hopefully this Friday.
front end is all shimmed up and solid...belts changed to low friction...
shock re-done....
TI ball studs being added...
I'm coming this weekend to make things happen.
remember it's doubled up this weekend...down with Perez
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 11-06-2013, 01:11 PM   #1622
Is cutting the front and rear wishbones something you would only do under low-med traction conditions or does it improve the handling all the time? I'm wondering if I want to keep a set of intact wishbones for things like snowbirds, IIC, Cleveland where the traction is outrageous.
On Road: VBC WF D06, A700 Evo, Mi5
Off Road: K1, DEX408
cgroves is offline   Reply With Quote
Old 11-06-2013, 03:48 PM   #1623
Suspended
Looks pretty nice!
http://www.timesharescam.com/
emabrown is offline   Reply With Quote
Old 11-10-2013, 03:54 PM   #1624
Who is running a spool on carpet,tried it in mine a few times and always end up back on a diff with 2.5 million in it.To me just too edgy cant push the car hard with the spool,but can with diff,run spool outside no problem.
Spool makes the inital steering too much in the top of the a finals,just windering if i should give it a go to see if theres any more i can get out the car,only thing i can see is that spool gives little more inital steering,but the diff gives little more in the middle and exit...
Quietman is offline   Reply With Quote
Old 11-11-2013, 06:57 AM   #1625
olhipster1's Avatar
I only run a spool...(carpet)
find it gives more initial steering, works for me.
test back to back and see which is better for your driving.
if it's too snappy up front then play with the camber links to get the right feel.
CAUSE and EFFECT
Old 11-11-2013, 08:38 AM   #1626
SteveM's Avatar
Trader Rating: 125 (100%+)
I run a spool up front as well on carpet and it works for me as well.
SteveM is offline   Reply With Quote
Old 11-11-2013, 10:46 AM   #1627
For me a spool is more push entry and more steering on exit. I switched from a spool to a diff(filled with cleaning clay) and went a 1/10 faster and the car was more consistent overall and gave slightly more entry and didn't seem to effect exit at all.
This was running modified.
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 11-11-2013, 11:42 AM   #1628
wtcc's Avatar
Definitly! You don't want flexing wishbones in high grip conditions! So keep them uncut for every high grip event!
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 11-14-2013, 08:33 AM   #1629
kwiksi's Avatar
Trader Rating: 101 (100%+)
Send a message via AIM to kwiksi
SUPER clean Mi5 in F/S section!
David Perez
Big thanks in 2017 to
Serpent/Desoto Racing - Jconcepts - Maclan Racing - Schelle Racing Innovations - Exotek Racing - Vision Racing Products - Reilley Motorsports - 92Zero Designs
kwiksi is offline   Reply With Quote
Old 11-15-2013, 08:00 AM   #1630
DiscountRCStore's Avatar
Wild Thing back in stock next week ...
..p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 11-15-2013, 04:20 PM   #1631
Trader Rating: 14 (94%+)
That's interesting because I thought front spool gives more entry steering..
Capricorn LAB C03
snuvet75 is offline   Reply With Quote
Old 11-15-2013, 04:22 PM   #1632
Granger's carpet default setup. Does that work good in high traction carpet? What do you guys think about thicker diff oil in the rear than 2000? When I drove on high traction carpet last time, the car seemed pushy a bit at exit so I thought maybe thicker diff would help.
Capricorn LAB C03
Old 11-16-2013, 06:01 AM   #1633
Thats same as i thought also
Old 11-16-2013, 08:03 AM   #1634
wtcc's Avatar
A balldiff (or geardiff with a soft oil) or a one way in front will give more entry steering, because the front tires can have different rotation speeds. Therefore you will lose speed exiting under throttle.
AE / Reedy / RSD
Old 11-16-2013, 03:43 PM   #1635
Maybe give this a try..
http://www.racing-cars.com/images/Te...arpet_2013.pdf
I'm running this currently verbatim on a high traction track and it's working quite well..
..p
SEO by vBSEO 3.5.0
