Like Tree21Likes
Old 11-03-2013, 02:53 PM   #1606
Trader Rating: 17 (100%+)
What about some play in front hubs....normal? Horizontal movement.
Team Schumacher USA
meddman is offline   Reply With Quote
Old 11-03-2013, 03:00 PM   #1607
olhipster1's Avatar
Trader Rating: 95 (100%+)
Send a message via Yahoo to olhipster1
I have a little play in the front hubs...I did shim the outer hinge pins to remove some of it...just enough not allow binding up...
the play from the bearings so far is okay.
make sure to check the top ball stud to make sure it doesn't get loose....had one go bad after I got clobbered on the track.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 11-04-2013, 09:34 AM   #1608
Just cut my front wishbones, and I am looking foreward to see If I can noticed the different. How did I work out for your guys there allready have tried it ?
Shock Tower is offline   Reply With Quote
Old 11-04-2013, 10:14 AM   #1609
olhipster1's Avatar
Default TI ball studs.
hope someone knows this one....
I want to order the Core RC TI ball stud set..
does anyone know what the weight difference/savings would be
standard kit ballstud vs TI ballstud set (part number: CR283)
CAUSE and EFFECT
Old 11-04-2013, 12:26 PM   #1610
triggar118's Avatar
Just want some help iv had my mi5 a few months now it's a great car I race indoors on medium to high grip carpet average lap times are around 9 to 10 seconds a lap I'm running 13.5 boosted on a prity standard kit set up with a spool in the front I'm getting a lot of power on oversteer when coming out of slow corners I'm losing a lot of time with the back end very loose any suggestions
triggar118 is offline   Reply With Quote
Old 11-04-2013, 02:09 PM   #1611
go see the martin hofer blog, and follow it EXACTLY! you can find it on google.
works pretty good.
gdcopbdcop is offline   Reply With Quote
Old 11-05-2013, 04:54 AM   #1612
Default wildthing parts
ive just purchased the wildthing parts for the mi5, could some one confirm how to fit the rear brace and also on the wishbone ends i take it the shocks screw into the new ofset holes?
jont is offline   Reply With Quote
Old 11-05-2013, 05:29 AM   #1613
DiscountRCStore's Avatar
The rear brace is intended for use across the (2) front screws of the rear arms.. You will need to replace the standard mounting screws with shorter 6mm screws so that the brace can be fastened through the (now open) threads of the ballstuds.. Using the included spacers and screws, mount the brace.
Yes, the reoriented holes are intended for the lower shock mounting.. Hope it helps..!
..p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 11-05-2013, 06:49 AM   #1614
olhipster1's Avatar
quick question
where can I buy the wildthing option parts?
i'm looking for the arms and shock mounts.
CAUSE and EFFECT
Old 11-05-2013, 07:10 AM   #1615
Originally Posted by olhipster1 View Post
quick question
You can order them thru RC Discount. Phill keeps the Schuey stuff in stock. I highly recommend purchasing the wild things shock mounts, and also the new 2 mm chassis with the braces. It really makes a difference. Especially on asphalt.
Old 11-05-2013, 07:26 AM   #1616
olhipster1's Avatar
thanks for the info
went on their webpage but I don't see any of the items...
and don't see a number to call.
CAUSE and EFFECT
Old 11-05-2013, 08:00 AM   #1617
thanks for the info
You have PM ...
..p
Old 11-05-2013, 11:11 AM   #1618
The Teacher's Avatar
Trader Rating: 47 (100%+)
olhipster1, you forgot to get Phil's info from me before I left on Sat. He will be able to get you what you need Hope you are working on that car....I've been in the lab the last 2 days got some good stuff cooking with the Mi5
The Teacher is offline   Reply With Quote
Old 11-05-2013, 11:41 AM   #1619
jdm19turn's Avatar
i plan on testing the rear stiffen braces on the stock chassis then the 2mm chassis along with rear stiffen braces and wild thing shock mounts this weekend on both
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 11-05-2013, 01:26 PM   #1620
Default cut front arms
could some one also explain wher you cut the front arms and the advantages in doing this,
thanks
