Like Tree21Likes
Old 10-30-2013, 04:18 PM   #1591
TryHard's Avatar
Originally Posted by DiscountRCStore View Post
.. I noticed that as well.. Very nice ..
That should be an okay place to start.. also consider leaving your end bell timing alone.. zero timing to start... there's a post in that thread and it talk's about when and how to watch your gearing based on the temp of the motor and esc; whether ones running hotter than the other.. I'd encourage you to spend some time in there.. It's a pretty quick and fascinating read..
..p
Just to add further to this, I'm running a MuchMore 4.5t, with HW v3, and use 114/25 (8.2fdr)... And this is pretty much my default setting, and then tune the esc to suit the conditions. Normally run around 20boost and 24ish turbo. This is the same on a couple of decent sized outdoor tracks, so obviously would be different for a tight indoor track. But should give an idea on where to start.
HiH
Ed
Old 10-30-2013, 05:08 PM   #1592
cementsurfer86's Avatar
Originally Posted by TryHard View Post
The answer is both
I actually counter sunk the whole car, bar the top deck (have a look at the camber plates and arms), and took the opportunity to make up some different steering plates with the holes moved inwards a little.
There are a couple of other mods on the car too..
Excellent work! Looks awesome!
I'll finally be able to buy the new car next month, as I'm still getting back into the swing of things (8 months, post-baby being born). Had some good E-mails with Mark across the pond, getting filled in on the progress with the car, as well as everyone's posts on here. Should be fun!
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC / Schumacher
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 10-30-2013, 11:37 PM   #1593
HoJo's Avatar
Hi
Wanted to check how you tell whether the screw is the steel or alloy ones ? Am I right that the steel ones are the black ones?
HoJo is offline   Reply With Quote
Old 10-31-2013, 07:17 AM   #1594
snuvet75's Avatar
Trader Rating: 14 (94%+)
Check out this posting if anybody wants to buy my Schui Mi5.
Schumacher Mi5 for sale
Capricorn LAB C03, Serpent Project 4X, Airtronics M12, Airtronics Super Vortex
snuvet75 is offline   Reply With Quote
Old 10-31-2013, 07:44 AM   #1595
Originally Posted by HoJo View Post
Hi
Steel are black aluminum are dull grey, optional titanium screws titanium are shiny grey.
You can also tell if you are using a hex driver that is even remotely rounded. The aluminum screws round out before you even touch them, the titanium screws round out just before they are tight enough, and the steel ones crank down so hard you'll never get them off the car
On Road: VBC WF D06, A700 Evo, Mi5
Off Road: K1, DEX408
cgroves is offline   Reply With Quote
Old 10-31-2013, 09:42 AM   #1596
+1, that is so true!
gdcopbdcop is offline   Reply With Quote
Old 11-01-2013, 01:55 AM   #1597
.. seems Atsushi Hara may be a fan of the Mi5; here's a pic of it at the Jet Cup from his Facebook page
..p
Yap, hopefully i can get his setup .and post it here later .
vm2 ,tm e4,mi 4,cup racer,yokomo d1,TCX,PHI RDX,MI4CX,TC6,china made pro-d.
ps.just came back to this hobby this year after22 years .
oldnoob is offline   Reply With Quote
Old 11-01-2013, 02:32 AM   #1598
Originally Posted by PurcyP View Post
Hes trying every car under the sun lol dunno if the schumacher will be to his tastes, will be interesting if he says anything about it.
either way i want him to go to yokomo but im biased and a yokomo fan boy lol
He was using a BD7 recently in a race in hk , really hope he has some good input for MI5 for this race .he didn't look very comfortable in both 417&BD7.
Old 11-03-2013, 05:37 AM   #1599
My aluminium and steel scres holding the wishbones through the carbon bottom are getting loose after a few bumps. How does you get yours to stay tight, are you locktighten them ?
Shock Tower is offline   Reply With Quote
Old 11-03-2013, 06:51 AM   #1600
TryHard's Avatar
So it's been a few weeks since I've posted any meeting feedback, and I've had a coupe of good weeks learning the car more, so here we go again...
Last weekend was a club race at the Bayside track, where we had our recent State titles. Started out with the same setup as at the state titles with the exception of 450wt oil in the shocks all round, and 1 groove rear hub plates. The main things I wanted to work on, were to try and reduce how quickly the car rotated, particularly in the slower corners, and also trying to improve the mid-corner steering in higher speed, particularly on exit. With time to think over the previous weeks, and having talked to a few other drivers about how my car looked on track, I had a developed a feeling that the car was pushing, particularly on-power out of the turns, whilst at the same time rotating too quickly in the centre. This was making it hard to flow the car well. This was less of an issue at Bayside, but at Logan this was a real issue.
Anyway, with this in mind, my line of thought was that the rotation issue was mostly related to the rear end setup. I had been using the Hoffer outdoor setup, with 1mm under the rear suspension balls, and also both braces fitted. With the 1mm shims raising the roll centre, and the braces stiffening up the rear of the car, this was pretty much a double whammy of increasing rear rotation. So it was in this part of the setup I wanted to focus on.
First run of the night, I kept the car as before, mainly to get a baseline laptime, and just see what the other changes had done. It felt good, with decent (but not great laptimes), but the aforementioned issues were still there.
So, first change, due to ease, was to just pull the braces off the rear end, but leaving 1mm under the balls.. Straight away, this was a big improvement. fast lap improved by 3/10ths, and was much easier to flow, as the rotation in the middle of the turn was much more predictable. Interestingly, didn't feel that the on-power steering suffered.
For the next run, I wanted to try a different method to achieving a similar thing, by lowering the roll-centre shims to 0.5mm, and putting the braces back on. Interestingly, car felt very very similar to the 1mm/no-braces setup, with almost identical laptimes, and only a very slightly different feel. In some respects it felt like that the car rotated a little harder with the braces, but no where near as much when running the higher roll-centres.
Given that the feel of the car was, to me, better without them (and also for ease of setup!) I went back to not having the braces, and the higher roll-centre shims for the rest of the night.
Next on the list, was to try the modified rear wishbone plastics, moving the rear lower shock mounting position outwards by 1mm. Straight away, this improved the on-power, with meaning I could get on the gas earlier out of the tighter turns.. but, it did also cause one slight issue, with the stiffer rear end springing now causing a problem with the front lifting over a particularly sevre bump on the main straight.. at one point I managed a full back flip over another car! A change of bodyshell to another LTC, and lowering the front down helped to stop this for the rest of the night.
So with the car balance better, the next change I wanted to try out was a 1.3mm front roll bar to gain steering, and also try different springs, mainly to try and make the car a little smoother over the bumps. The front bar pretty much did as expected, loosing a smidge of initial steering, but gaining from the middle out. Spring wise, I tried a few variants, switching between Ride and Schumacher Greens. The Ride's are a softer spring, and felt good over the bumps, but laptimes were similar. It'll be something I'll come back and test out next time I'm there, and will also give the Ride and Schuey Blues a try as well.
Now, during that meeting, Scott G from Action RC handed over a 2mm stiff chassis, which is something I've been keen to try since it was announced. The plate itself is certainly stiffer than the stock part, and being thinner as well helps to lower the whole CoG of the car by 0.5mm, by being thinner. Given that pretty much all the UK driver setups have been using this for a while, during the week pulled the stock plate off the car, and put the 2mm on. Also gave the car a little bit of a fettle, and had a bit of an inspection on the diffs, as I had been having issues with the outdrives leaking oil. Looking closely at the outdrives, and the o-ring, there was a bit of float, so I spaced the o-ring up by putting 0.3mm of shims, which now (lightly) pushes the o-ring up to the outdrive.
So with the 2mm chassis on, first run out was yesterday at Logan. Different track, with much higher speed turns, and getting a good flow with the car is vital for a fast times. Putting the car on the track (with only changes from previous week were less droop, spool, and lower ride-height), straight away the car felt more reactive, all the way through the turn. Really liked the feel, and was very close to hitting 19s laps even on the green track. Main order of business was to firstly check the previous rear end changes (trying the 1mm/no-braces vs 0.5mm/braces) tested out at Bayside, with the new chassis plate. Interestingly, I now found the 0.5mm/braces combo to be faster, and feel better... quite possibly the stiffer plate has altered the balance a little, and now favours that combination.
Actually spent quite a bit of the night trying out changes I've made before, more in terms of checking to see what they did with the new chassis. Tried out changing rear hub plates (zero groove vs 1 groove), camber plates (3groove vs 4), and also re-testing out the previous roll bar change.
All told, I preferred the 3groove camber plates, the 4groove feeling like it rolled a little too much, and had lower corner speed. Hubs plates, not sure on this one... ended up going with the zero (kit) plates, but I think by the end of the night the one-groove would have been the better option, as the rear of the car was starting to step sideways on a couple of corners on exit.
In terms of the roll bars, 1.4mm gave more intital turn-in, but seemed to give up mid-exit, and ultimately, was a little slower, although not much in it.
Overall though, had my best night at Logan, setting a new PB, and only being a hare (0.02s!) off of 16lap pace. Over the last time I was there, gained over 0.4s of laptime, and was able to do these times all night. Yes the track was in a good state, but a lot of that was down to the behaviour of the car, which I strongly put down to the new chassis plate... a very worthwhile upgrade IMO.
Interestingly, I wasn't the only one having a good time with his Mi5 at Logan, as Scott G also had his car whipping round, also posting some really quick times too, with pretty similar settings.
As for next time out, couple of things on the list to try, such as the hub plates (again), springs, and also bodyshells, as I gave a Speed6 a try out after racing, and it felt nice vs the LTC-R... but with no times available b y then to check, will give it a proper run next time out.
But overall, rather happy with the car at the moment... feels really good on track, and getting good comments, and I am competitive on times... win-win
Setups attached!
Old 11-03-2013, 06:53 AM   #1601
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
If anybody is looking for a roller. Will be putting mine up in F/S soon. One race day in 21.5 class. Super clean with spares. PM me for details. Just don't have the time.
kwiksi is offline   Reply With Quote
Old 11-03-2013, 07:29 AM   #1602
Trader Rating: 17 (100%+)
I have same question about keeping the screws on the a arms tight. Front seems to come loose. Also the play in the front hubs. Is that normal?
Team Schumacher USA
meddman is offline   Reply With Quote
Old 11-03-2013, 08:00 AM   #1603
Setups attached!
you have mail.
Old 11-03-2013, 08:04 AM   #1604
On keeping the wishbone mounting screws tight:-
Chris Grainger told me to hold the screw still with your 2mm driver and then turn the spanner to tighten the mount down. He said that works much better than turning the screw itself.
cyclonetog is offline   Reply With Quote
Old 11-03-2013, 09:53 AM   #1605
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Agreed.... you have to use the wrench when tightening the screw, be careful with the aluminum front screws they can snap if you over tighten..
Never had one come loose since using this method.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
