Like Tree21Likes
Old 10-16-2013, 08:02 AM   #1531
DiscountRCStore's Avatar
Originally Posted by masterhit View Post
Bit of a strange question for y'all.... Could someone accurately measure the thickness (height) of the hex on the inner arm mount pivot balls?
Even better would be overall pivot ball height and ball diameter in addition to the hex height!
It would be greatly appreciated! Thanks!
Mike Slaughter
Hey Mike..
I get:
1.43mm hex height
6.5mm overall
5.47mm OD of ball itself
Was going to bring up to you tonight if that will help..
..p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 10-16-2013, 08:12 AM   #1532
Originally Posted by olhipster1 View Post
quick question.
why the cut arms?
I would think that would create too much grip on high traction.
did you notice an improvement with the arms cut?
was thinking of cutting the arms also...but have been holding back.
thanks
Being the first event many of us had been to with the Mi5 that had that level of grip, we were all trying different things; I opted for the super soft flexy setup and worked diligently to make it fast but to no avail.. Tim had more of a mid range setup ( full arms, yok pink and blue, mid motor) and Adams was the most stiff ( full arms, Shuie greens and some pretty thick oil, rear motor) .. the others were in between Tims and Adams. On low to mid traction, I prefer the cut arms. They actually made the car feel quite good on the high grip.. just wasn't fast through the corner..
..p
Old 10-16-2013, 08:50 AM   #1533
masterhit's Avatar
Trader Rating: 15 (100%+)
Originally Posted by DiscountRCStore View Post
Hey Mike..
..p
Works for me! And thanks! Might have to put an order in too for some stuff.
Mike Slaughter
masterhit is offline   Reply With Quote
Old 10-16-2013, 09:24 AM   #1534
cyclonetog is offline   Reply With Quote
Old 10-16-2013, 11:23 AM   #1535
jdm19turn's Avatar
This is what I ran in the mains, was the softest of all the setups .. Hope it helps ..
..p
I've been running mid motor with 3 dink plates front and rear yok pinks and blue springs same washers under the ball studs as your using 0 notch rear hub plate .5 washers under rear arms and .5 under just the rear of the front arms I'm running .5 antidive with the stock 4 deg yok shocks laid all way down front rear with ae 37.5 oil front and rear 2.5 rear toe 2000 cst diff oil deg 2 camber front and rear thats on jaco blue tires and sxt tire prep sauce the both tires full 5 m ride height mazda speed6 body I'll post a setup sheet for eveyone to see in better detail in a little while
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 10-16-2013, 08:32 PM   #1536
olhipster1's Avatar
Trader Rating: 95 (100%+)
Send a message via Yahoo to olhipster1
Default pdf
Silly question...I have pdf setup sheet ready but its too large...how do I compress or load up.
Tried online compression but only gets down to 1100kb max allowed is 498kb on rctech.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 10-16-2013, 08:39 PM   #1537
TryHard's Avatar
Easiest way I've found is to use bullzip pdf printer, then print the setup pdf's as jpg's. You'll need to play with the settings a little (I think 600dpi is a good compromise between quality and size), then resize in photo manager. It's easier to compress a jpg to the file limit than a pdf to load on here.
http://www.bullzip.com/
The one here was treated that way... http://www.petitrc.com/reglages/schu...ide2013092728/
HiH
Ed
Old 10-16-2013, 09:23 PM   #1538
Trader Rating: 38 (100%+)
I found the source of my steering rack failure in the main. Due to the close tolerances needed for the steering rack, any noticeable play in the bearings will eventually cause the rack to pop out. Looking back, that car probably has 5000+ laps on it at my local track so it's not a big deal to need to replace them, just sucks the way that I had to find out.
The testing that concluded the issue was to move the screw fully forward and tighten without the rack in position. I then slid the rack into position upside down (the tabs won't allow it to go right side up). The fact it went in easily and even wiggled a bit showed me that something was wrong. I put new bearings on and the rack will not go in without backing off the bearing slightly.
This is in no way a defect but something that over time needs to be checked and at some point you will need to replace the bearings.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 10-17-2013, 04:50 AM   #1539
Anyone tried the mid motor conversion out doors on tarmac with rubber tyres ? if so how did it compare to the standard rear motor configuration ?
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 10-17-2013, 05:08 AM   #1540
We've found the very same thing; a servo saver can help prolong the life of those bearings however, over time and use they do wear out 'radially' and the races in them get quite sloppy... can also make the car corner inconsistently if they get too bad.
..p
Old 10-17-2013, 07:38 PM   #1541
PDF from Schumacher is 2.5M but here you have two lighter options: 1.5mb and under 800kb. That may help once you want to compress your filled file.
Arn0 is offline   Reply With Quote
Old 10-17-2013, 10:24 PM   #1542
olhipster1's Avatar
Default steering rack
Don't forget to clean the steering, around the area where the bearing sits in the groove tends to get a slight amount of debris now and then.
Qtip with motor spray does the trick.
CAUSE and EFFECT
Old 10-18-2013, 03:18 AM   #1543
pbr
Ok what am I going to need for minrig & the birds for the carpet? Car is built box stock mid motor been running asphalt
pbr is offline   Reply With Quote
Old 10-19-2013, 12:21 PM   #1544
Default Brushed motor in the Mi5 !?
Hey guys,
Just finished building my Mi5. I wanted to put in my brand new Novak GT7 (never used) and my P2K2 brushed motor (I was going old school here). The brushed motor holes won't fit the motor mount.
I was really looking forward to my vintage setup in the new car. Anyway around? If you can't think of anything, I'll just go buy a brushless one...
Thanks!
undying is offline   Reply With Quote
Old 10-19-2013, 11:21 PM   #1545
olhipster1's Avatar
Default carpet setup
Starting setup for carpet.
Car rolls a lot but has a ton of steering.
Going try and to 450 shock oil but did try red springs, car became easy to drive when traction went up.
So far so good.
Link to setup sheet...
http://www.petitrc.com/reglages/schu...rsham20131015/
CAUSE and EFFECT
