Like Tree21Likes
Old 10-09-2013, 07:27 PM   #1486
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Originally Posted by haywood View Post
I went with the Xray Xtra Stiff servo saver. Try the cut shafts and Yokomo springs !
Cut shafts front and rear?
kwiksi is offline   Reply With Quote
Old 10-09-2013, 08:53 PM   #1487
haywood's Avatar
Trader Rating: 48 (100%+)
Yes.
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 10-10-2013, 04:30 AM   #1488
NITROmmm's Avatar
Questions??
Would like to know a gearing start point for the Mi5 with 4.5t?
He who laughs last, thinks slowest!
RC HOBBYZONE
JSPECSTICKERS
NITROmmm is offline   Reply With Quote
Old 10-10-2013, 05:03 AM   #1489
TryHard's Avatar
What motor and ESC?
With the HW V3, and MuchMore 4.5t, I'm running 114spur and 26pinion, which gives 7.89FDR.
This is with 20 on the motor, and the using 22 of boost, and 20 of turbo on the ESC.
HiH
Ed
Old 10-10-2013, 05:50 AM   #1490
poochy's Avatar
in regards to the castor block bolt fix, how much filing does the aftermarket bolt need (.5mm, 1mm etc..)?
also how does the granger kit ashpalt setup compare to the hofer stnadard asphalt setup?
poochy is offline   Reply With Quote
Old 10-10-2013, 06:41 AM   #1491
NITROmmm's Avatar
Post
Originally Posted by TryHard View Post
What motor and ESC?
HiH
Ed
Thanks Ed.
V3.1 HW, trinity duo 3.5.
Only standard 85t spur atm .
For openbitumen track at littlehampton.
Steve.
RC HOBBYZONE
JSPECSTICKERS
Old 10-10-2013, 08:14 AM   #1492
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Try hard
are you runing rear or med motor set up?
I run my first 17.5 med motor set up and it was okay..needs a little more off power streering..
OVA is offline   Reply With Quote
Old 10-10-2013, 05:11 PM   #1493
I just did the castor block m4x14 bolt fix. It felt like the end of the screw was hitting the cva axle so I dremeled less than .5mm off and it's all good.
Old 10-10-2013, 05:24 PM   #1494
TryHard's Avatar
Originally Posted by OVA View Post
Try hard
I have run my car only in rear motor, don't have the mid-motor conversion, and probably wont get it until I build up a stock class car.
Do you have a copy of your setup, can suggest some things to try to gain the steering then.
HiH
Ed
Old 10-10-2013, 05:25 PM   #1495
TryHard's Avatar
Thanks Ed.
Steve.
For littlehampton, it would be worth get hold of Antoni Caretti, or Peter Dooley... both I believe are running there in preperation for the nats, so should be able to give you some advice on gearing and speedo setup
HiH
Ed
Old 10-10-2013, 08:46 PM   #1496
haywood's Avatar
Default Vegas
Anyone having any luck out there? Mid motor or rear motor working better on the high bite ?
Old 10-10-2013, 09:00 PM   #1497
I'm having good luck with mid-motor running relatively soft (Yoko pink & blue) and flat links. No spacers under the arm screws. Only saucing rears it doesn't want to roll badly and the speed seems good and steering is great. That being said, Adam is having a lot of luck with a relatively stiff setup and rear motor. I'll post up the final setups when I get to my laptop at home next week.
On Road: VBC WF D06, A700 Evo, Mi5
Off Road: K1, DEX408
cgroves is offline   Reply With Quote
Old 10-11-2013, 08:46 AM   #1498
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Setup pdf
is there a download for a editable Setup sheet?
would like to post up my carpet setup...
working great for me....
Sorry to drop this post...but kinda limited on time...work has taken over my life
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 10-11-2013, 10:31 AM   #1499
Here
http://www.petitrc.com/reglages/schu...SetupSheet.pdf
Shock Tower is offline   Reply With Quote
Old 10-12-2013, 05:52 PM   #1500
haywood's Avatar
Default Vegas
Any positive results or setups from the week in Sin City? Been pretty quiet.
