Team Durango DETC410
#1456
Quick question...want to run this for cya...but the front rims run on the steering knuckles...are you guys using different knuckles,if so,which ones ? Thanks
#1457
Springs
Hi
Can some one point me in the direction of a spring set for this car
#1459
Sorry thanks guys I do appreciate that
#1463
Hi
Would you use same outdoors ?
Thank you
Thank you
#1466
I am Sorry
Would any one have any recommendations for yokomo springs outdoors
#1467
#1470
R/C Tech Elite Member
for any one running this in VTA, protoform premounts rub upfront on the stearing arms. I have to run 1.5mm of shims per side to get no rub, however this leaves me with maybe 2 or 3 mm of exposed thread for the nut to lock onto.
Does any one have a solution? maybe diff rims or longer outer axles?
