Old 04-14-2017, 10:47 PM   #1411
Trader Rating: 1 (67%+)
Send a message via AIM to racer034life
does anyone have a starting point for usgt! also I am looking for a aluminum chassis.
Access Hobbies,CRC, Detc410, Xray T4 15,
The Ian Ruggles Negative Reinforcement Driving School
racer034life is offline   Reply With Quote
Old 04-15-2017, 08:01 AM   #1412
SpeedySST's Avatar
What surface? PetitRC has setup sheets for most surfaces. Good luck finding an aluminum chassis. There werent that many made and I got lucky. Team Durango DETC410 & DETC410v2 Setup Sheets
Team Durango DETC410 / SpeedPassion / Fantom Racing / Aston Martin Racing
SpeedySST is offline   Reply With Quote
Old 04-15-2017, 12:32 PM   #1413
YoDog's Avatar
Trader Rating: 26 (100%+)
Fenix recently made another batch of chassis. Contact Giorgio. He has posted recently about them. The only problem is that shipping to the U.S. is expensive from Italy.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 04-15-2017, 01:56 PM   #1414
SpeedySST's Avatar
Contact from their web page or RCTech. I cant find contact info. NM found it.
Old 04-15-2017, 02:57 PM   #1415
Please let me know what you find out! I would like to order one or two. Also I have a local hobby shop with more spares then they know what to do with! I'll post a list in a few days.
Old 04-19-2017, 06:25 AM   #1416
SpeedySST's Avatar
Received this email this morning for those that are interested:
Good morning Mark
Sorry for the delay, but all the team was in Holland for the International Dutch F1 Master.
Durango Chassis is available in 2 options
Flex
Durango DE410TC - 2mm 7075 Chassis - FenixRacingShop
And
Full flex
Shipping cost to the USA , using UPS, is 24 euro.
Hope this helps
Best Regards
Giorgio Favaretto
Fenix Racing
FenixRacingShop
FENIX RACING
mobile + 39 348 2209673
Old 05-14-2017, 02:55 PM   #1417
bikedoctor's Avatar
Default replacement parts
looking to get back imto on road is this a risky buy in terms of replacement parts for easily broken parts?
bikedoctor is offline   Reply With Quote
Old 05-14-2017, 06:48 PM   #1418
Crowbo74's Avatar
Trader Rating: 111 (100%+)
Default Parts
Delete
Crowbo74 is offline   Reply With Quote
Old 05-14-2017, 08:39 PM   #1419
Good morning Mark
Flex
And
Full flex
Hope this helps
Best Regards
Giorgio Favaretto
Fenix Racing
FenixRacingShop
FENIX RACING
Now if only Durango or someone would make all the other parts, that'd be something. ...
blankenj99 is offline   Reply With Quote
Old 05-14-2017, 08:58 PM   #1420
SpeedySST's Avatar
Yeah I would use overpriced XRAY parts but Id rather not. Found a bunch of Pro5 parts that will fit with a little dremel work. It will be enough for the outdoor season anyway.
Old 05-14-2017, 09:01 PM   #1421
SpeedySST's Avatar
Yes it is getting hard to find Durango parts, especially the V2 parts. For outdoor Im ok with the V1 parts except for the steering hubs which seem to be made out of butter. They're way too soft.
Old 05-16-2017, 08:42 AM   #1422
SpeedySST's Avatar
Does anyone know if any of the Spec-R gear diffs fit the DETC? Im getting tired of replacing cases because of the stupid fine pitch screws. Serious design flaw.
Old 05-16-2017, 10:43 AM   #1423
Broadwater's Avatar
On the front of my car i'm using all yokomo bd7 parts. since i can't find parts for this car anymore. arms,hubs steering block and anti roll bar. you just have to add extra spacers at the inner hinge pin.
Darren B.
Broadwater is offline   Reply With Quote
Old 05-16-2017, 11:12 AM   #1424
I have two new BD8s, going to measure everything as I build it to see how they compare...
Old 05-16-2017, 11:33 AM   #1425
Johnny Wishbone's Avatar
Could you not go up one screw size or try a standard screw thats bigger or even go to a course thread screw. Just suggestions if your stuck for parts.
I know when I'm using machine screws into plastic, I actually use a tap on a new hole. Then when I take a screw out and get ready to put it back in, I'll turn the opposite direction from tightening so the screw kind of jumps the thread, then its starting in the same spot every time, lined up with the threads. This method really saves on the wear and tear of plastic threads. If its a case of over tightening, well then, I got nothing.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
