Old 01-20-2017, 09:12 AM   #1381
SpeedySST's Avatar
Anyone know the pin size for the DCJ? Im at work right now so I cant measure it. I might try some other, more available parts (like Spec R) so trying to figure out which ones fit.
Team Durango DETC410 / SpeedPassion / Fantom Racing / Aston Martin Racing
SpeedySST is offline   Reply With Quote
Old 01-20-2017, 01:00 PM   #1382
Price is going back up on Tower hobbies site
sgtlt is offline   Reply With Quote
Old 01-20-2017, 01:51 PM   #1383
SpeedySST's Avatar
Ebay has them from Omni Models at $170 for the V2.
Old 01-20-2017, 02:17 PM   #1384
Dodged a bullet then, ordered my third kit yesterday. ..
blankenj99 is offline   Reply With Quote
Old 01-20-2017, 03:39 PM   #1385
SpeedySST's Avatar
I did find some suspension parts at Active Powersports. C Hubs and steering blocks.
Old 01-23-2017, 06:50 AM   #1386
And now Omni Models is back up to 199.99 like Tower...
Old 01-24-2017, 07:39 AM   #1387
Juanqui's Avatar
Can anyone share Xray parts list that is compatible with the V2? Thanks!
Juanqui is offline   Reply With Quote
Old 01-24-2017, 07:41 AM   #1388
SteveM's Avatar
Trader Rating: 134 (100%+)
When demand increases (no doubt due to their earlier lower price) they increase the price and expect to sell all these discontinued kits.
SteveM is offline   Reply With Quote
Old 01-24-2017, 10:54 PM   #1389
MGU
I just had a look at their site and there was no mentioning of the V2 being discontinued. The "V1" yes but not the V2. Around here (Europe) you can still get plenty of parts so I am wondering.
MGU is offline   Reply With Quote
Old 01-25-2017, 05:13 AM   #1390
Durango lists the DCJ pin as a M2x10, hope that helps.
Old 01-26-2017, 11:06 AM   #1391
Juanqui's Avatar
Any tips to achieve the 1.30g diff oil without a scale?
Old 01-26-2017, 11:28 AM   #1392
I think as long as the spider gears are covered you are ok
Old 01-26-2017, 01:33 PM   #1393
Trader Rating: 30 (97%+)
up to the cross bar of the spider gears
zaraz is offline   Reply With Quote
Old 01-26-2017, 06:50 PM   #1394
From the arms out as long as u can shim the arms right the rest just bolts on thats what i did with mine.
But u will need longer axles for the front a 5x10x3 bearings if u are running dcvand wider hexs or .50 shims for the axles
Felix v.
Ae sc10.2, xray t4 2016 usgt,wrc f-one 016, Tamiya m05 mini
Expensive is not always faster
Scionara05 is offline   Reply With Quote
Old 01-27-2017, 04:20 AM   #1395
Juanqui's Avatar
Thanks!
I'm currently in the building process up to step F (Bulkheads, Spurs, Belts and Diffs Installation). When installing the motor mount and layshaft mount I was very careful to follow the instructions as to when to tighten screws. After all this is done I noticed a bit of tweak in the front right side. Went back and started over but the problem persists. I've been working on top of a glass table. It is a very slight tweak. Will it solve after I install the top deck or should I try something else?
