Old 12-23-2016, 02:20 AM   #1351
Location: Beneath a rock down by the river. Don't have money for van
Hard to have part shortages when I don't need anything. The shop that had durango parts didn't have much for the DETC but he said he can order whatever it's needed (EU).
( ͡ ͜ʖ ͡)
30Tooth is offline   Reply With Quote
Old 12-23-2016, 08:47 AM   #1352
SpeedySST's Avatar
Well, now its at $200 for the V2! Id say thats worth it.
Team Durango DETC410 / SpeedPassion / Fantom Racing / Aston Martin Racing
SpeedySST is offline   Reply With Quote
Old 12-25-2016, 11:16 AM   #1353
Is the setup Philipp Huber used with the alloy chassis available anywhere? I cant get my car to work for me on carpet at all.
davidroypitcher is offline   Reply With Quote
Old 12-25-2016, 11:34 AM   #1354
What's is it doing? Post your setup. What class? Motor? Springs?
TeamThibault is offline   Reply With Quote
Old 12-25-2016, 12:40 PM   #1355
Struggling with balance. The car doesnt seem to be generating enough grip all round. I've been focussing on chassis flex options and tried soft/hard springs and damping just cant seem to get a nice balance its either got no front end grip and wont rotate or the rear is to loose on corner entry. Im running modified. Right now the front end is lacking high speed bite and off power the rear is loose so im scrubbing to much speed on corner entry, mid and exit. Dont yave the alloy chassis just standard carbon maybe this is the issue? Do any of you guys have a solid carpet setup i could try as im running out of ideas. I dont know anyone else who runs the durango so cant share ideas etc
Old 12-26-2016, 09:03 AM   #1356
Post your entire setup I will take a look at it.
( ͡ ͜ʖ ͡)
Old 12-28-2016, 10:45 AM   #1357
YoDog's Avatar
Trader Rating: 26 (100%+)
A couple of things I have found that work on carpet is to start with the softer springs (2 dot) all around with 35w oil, lay down the front shocks 1 hole lower than the rear (2nd hole up at the front and 3rd on the rear for example) and use 0.5mm wheel spacers at the front. 1deg camber up front and 2 degrees at the rear. Use droop to tweak weight transfer and see how it goes. The soft setup will help with overall grip and the other settings will calm the car down. Clamping down on the droop, little by little will flatten the car out to get a little quicker in the transitions. Are you using a spec tire? if not, what are you using? Sauce type and technique?
As mentioned... posting your complete setup will be helpful to asses your situation.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-29-2016, 07:30 AM   #1358
In the mean time the shake down run was a bit disappointing. The steering radius is big but everything is OK
Manual asphalt low traction setup... Think I'm going to dial some aggressiveness by raising the front lower holders 1mm and more droop all round.
( ͡ ͜ʖ ͡)
Old 12-29-2016, 12:32 PM   #1359
Thanks. I will upload full setup at the weekend when i have some spare time. I will try what you suggested next time out and see if it helps. Im using spec tyres which are sweep SQE-28EWS with sweep handout additive. Everyone has been doing same thing with additive so i think the issue is purely setup..
Old 01-04-2017, 09:44 AM   #1360
Price is down to 179.99 today. Picked one up just to have a compleet set of spairs.
sgtlt is offline   Reply With Quote
Old 01-08-2017, 09:20 AM   #1361
What is a good gear to run on carpet with the stock spur gear
Rvargas77 is offline   Reply With Quote
Old 01-12-2017, 11:47 AM   #1362
SpeedySST's Avatar
Guys, Tower Hobbies still has V2 kits now at less than $175!
Old 01-12-2017, 03:11 PM   #1363
Yeah I'm trying to resist buying a 3rd one 8-)
blankenj99 is offline   Reply With Quote
Old 01-13-2017, 07:58 AM   #1364
SpeedySST's Avatar
For that price I couldnt resist (my 3rd). Two will be set up for indoor carpet (USGT and 17.5) and the new one will be set up for outdoor asphalt. I have plenty of spare parts too and even if I run out, Tamiya parts fit in some cases.
Old 01-13-2017, 08:17 AM   #1365
Trader Rating: 30 (97%+)
I got lots of v2 parts for sale in the for sale section for this kit, if anyone is looking for some.
zaraz is offline   Reply With Quote
