Old 04-06-2016, 07:38 AM   #1276
Had to put some lead in the car to get it balance i cant put the car on the track until Saturday thanks for all the help.
SGrubb is offline   Reply With Quote
Old 04-06-2016, 11:07 AM   #1277
YoDog's Avatar
Trader Rating: 26 (100%+)
Make sure your droop settings are equal. This can have a huge effect on weight transfer under loading.
YoDog is offline   Reply With Quote
Old 04-06-2016, 02:43 PM   #1278
You can move battery holders outwards or inwards to try and get more balance
Adam Howe is offline   Reply With Quote
Old 04-06-2016, 03:34 PM   #1279
yodog you r right my droop was off. i also moved the battery to get a better balance. thank you. steve-0
Old 04-07-2016, 07:28 AM   #1280
P.S thank you Adam HOWE the battery did help get balance thanks steve-o
Old 04-12-2016, 02:47 PM   #1281
Hi to all durango drivers and good luck at the mile high indoor champships this weekend.
Old 04-18-2016, 10:21 AM   #1282
Hi to all durango drivers i will be puting my two detc410 up for sale in a couple of day from not one is setup for usgt and one is setup for 17.5 with a alum. chassis.
Old 04-18-2016, 10:46 PM   #1283
Originally Posted by YoDog View Post
I recently heard that Durango has discontinued their on road program so I don't know if that means no more DETC or just the Team driver program has been discontinued. It's disappointing news either way.
it would be nice is a member from team durango
would comment on this
or some one from Hobbico could tell us if tc has been discontinued
medennisojay is offline   Reply With Quote
Old 04-19-2016, 09:16 AM   #1284
I now have pix of my car put your email and i will sent the pix. thanks
Old 04-19-2016, 11:52 AM   #1285
I have no official quote and don't speak on their behalf however I drive in the UK for hobbico and still are being asked to provide feedback on the v2. We were still getting prototype plastics last year for the v2 whilst running the v1. The Touring car is not discontinued and is still available. They had a new approach of sponsoring local good performing drivers encouraging people to buy kits and cost cut by reducing the size of the factory drivers.
Old 04-20-2016, 11:45 AM   #1286
I have both car are clean and ready to be sold please ask for my tex number.
Old 04-27-2016, 02:44 AM   #1287
MGU
Originally Posted by SteveM View Post
When setting up your steering, you must ensure that the servo horn and the tie-rod are at a 90 degree angle. In the case of the DETC410, this means that the servo horn leans towards the middle of the chassis slightly. The brand of servo and radio make no difference. See how the servo arm on my steering servo leans into the middle of the chassis.
Sorry to resurrect such an old question. I just finished building my V1 and have a similar issue. To get the same steering throw I have to set the EPA to
L-95
R-125
I am using the servo saver and I really tried to get a 90 degree angle between it an the tie-rod. It is leaning a little bit to the inside but if I lean it in any further the steering is not centered and the tie rod is already shortend as much as possible.
I am a little bit at a loss here. Since it should work just fine according to everything I read here.
MGU is offline   Reply With Quote
Old 04-28-2016, 03:08 AM   #1288
fyrstormer's Avatar
Cut the tie-rod shorter if you have to. This is a hobby, modification of parts is part of the fun.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 04-28-2016, 03:47 PM   #1289
L-95
R-125
Are your steering links the correct length as reccomended in the manual?
Old 04-28-2016, 10:51 PM   #1290
MGU
I completely reset them both and will start from scratch setting it up. It is snowing here so not a lot of testing I can do right now. What I noticed so far is that I need a fair amount of subtrim (around 30ish) to really make the steering linkage point straight ahead. Of course changing the subtrim also changes my endpoints but I haven't gone so far to check how much I need to compensate here.
