Old 12-21-2015, 04:43 PM   #1201
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Armandolenzi View Post
in wich case i'll need to take down those screws?
No,no! All the setups I've seen use the screws and spacers so leave them in. If you tighten the screws without the spacers, the top deck will bow and cause handling problems. It's not just a pinion fitment issue. In the back of the user manual are some well thought out setups for both carpet and pavement. Definitely use them as a good starting point.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-21-2015, 06:17 PM   #1202
yes, i already setup the car with the asphalt low traction setup sheet as a starting point.
i've fitted an kyosho 96t64p spur from my tf5. and the 50t64p pinion, giving me and FDR of 3.74.
i'm gonna check the temp for the racing time and adjust the motor mechanical timing.
Armandolenzi is offline   Reply With Quote
Old 12-22-2015, 08:28 AM   #1203
YoDog's Avatar
Unless you're running on a pretty large track, your FDR may be a little low. I would suggest a 45 or 46 tooth pinion. You want to be around 4.0 FDR in 13.5 blinky. Do you have the regular D4 or the short stack? If it's a SS, try 44-45t pinion first. Your end bell timing should be around 40 deg. to start.
Old 12-22-2015, 09:00 AM   #1204
it's the regular D4.
this are the tracks where i race, in both tracks we race 1/10 190mm, 1/8 nitro GT, and 1/5 touring
Team Durango DETC410-img-20150325-wa0015.jpg   Team Durango DETC410-img-20150608-wa0005.jpg
Old 12-22-2015, 09:28 AM   #1205
YoDog's Avatar
Well, those are bigger tracks... Very nice!
Ok, then... 3.8FDR could be a good place to start.
Old 12-22-2015, 11:00 AM   #1206
both tracks are about 50m long, the lap time it's about 20 sec aprox in both tracks
Old 12-22-2015, 11:03 AM   #1207
tbrymer's Avatar
You'll probably end up even lower than the 3.8 on those tracks.
CRC - C&C Motorsports - SpeedZone
tbrymer is offline   Reply With Quote
Old 12-22-2015, 12:05 PM   #1208
YoDog's Avatar
Likely, but starting on the conservative side might be a wise decision till he figures out how temps factor in.
Old 12-22-2015, 12:20 PM   #1209
of course i'll be starting from the bottom. i'm not that experienced on 1/10 touring.
i believe the Q minutes that we are running are 5, and the finals are 10 minutes
i'll be adjusting mi FDR and mechanical timing around the motor and esc temp within those 10 min.
i think i'll be running the durango for the first time on dec 24th (this Thursday) and post a few pics
Old 12-22-2015, 12:42 PM   #1210
YoDog's Avatar
Good luck Armando!
Ciao!
Old 12-22-2015, 01:38 PM   #1211
Good luck Armando!
Ciao!
here's a video of my old kyosho with 13.5t
https://www.youtube.com/watch?v=ysur...ature=youtu.be
Old 01-15-2016, 02:57 PM   #1212
Hi iam new to durango but not new to rc racing here at 5280 raceway we r geting the new carpet. dont know the name of it but thay tell me more grip. i need a setup for this so the word HELP... thanks
SGrubb is offline   Reply With Quote
Old 01-15-2016, 03:25 PM   #1213
YoDog's Avatar
The manual has a good starting setup for both low and high grip carpet. I would start there.
Old 01-16-2016, 04:57 PM   #1214
thanks YoDog i have the high grip on the car now have you ran on the new carpet
Old 02-03-2016, 01:50 PM   #1215
I am now going to put associated balls and cups all around to stop the slop i will post the parts numbers if it works
