Old 11-28-2015, 11:45 AM   #1186
Potoczak's Avatar
Trader Rating: 111 (100%+)
Originally Posted by Rick Vessell View Post
I have Xray bladders in my shocks. Fit ok and feel better.
Which version of X-ray bladder??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-29-2015, 05:43 AM   #1187
rjf
Xray bladders for T3, 308081 low profile shock membran.
rjf is offline   Reply With Quote
Old 12-01-2015, 06:02 PM   #1188
YoDog's Avatar
Trader Rating: 26 (100%+)
In case anyone is wondering about the V2 kit.
It includes all the V1 parts with the V2 updated parts crammed into the box so you get twice the plastics as originally shipped. Nice deal for the same price as the V1 kit alone!
They probably couldn't fit anything else into the box without breaking the seams.
When I got my V2, it looks like TD cut the seal and stuffed more parts in and resealed it with V2 stickers. The new arms are really nice and do away with the molded ball ends for the swaybar mounts for metal ones. I can't wait to get out to the track to get her dialed in.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-02-2015, 08:13 AM   #1189
Rick Vessell's Avatar
What this guy said.
Rick Vessell is offline   Reply With Quote
Old 12-21-2015, 07:53 AM   #1190
Default DETC410 NEW USER
hello there, i'm a new user for the durango detc410. in my local track we run 13.5T motor and i would like to know which spur/pinion config do you guys recommend. i was racing with and old kyosho tf5 ready set, but the car it came to a dead end. so i purchased the durango.
in the kyosho i had 88T 64P spur/50T 64P pinion, but the durango doesn't give me that option, the biggest pinion i can put in there is 37T 64P, perhaps an 40T but i don't know.
i would be swell if you guys can help me out.
best regards
Armandolenzi is offline   Reply With Quote
Old 12-21-2015, 09:00 AM   #1191
YoDog's Avatar
best regards
you will want to achieve an FDR of around 3.8 - 4.2 for 13.5t on most tracks. To get in that range you will need a spur gear of 96t - 100t. There are many gear charts apps out there so I would strongly recommend getting something that calculates FDR (Final Drive Ratio). The DETC410 internal ratio is 1.95 so a 100t spur with a 50t pinion will achieve a 3.9:1 FDR. This is based on a 64p gear set. Alternatively, a 96t spur and 48t pinion will achieve the same. Your Kyosho was set for 4.7:1 as it looks like they used is a brushed motor. What 13.5 system are you going to use in your Durango?
Old 12-21-2015, 09:48 AM   #1192
the same setting of the kyosho: trinity D4 13.5t motor, hobbywing juststock esc.
ok i understand what you're saying but in my durango doesn't fit any pinion above 37t64p because it'll hit with the top deck.
thanks for the reply
Old 12-21-2015, 10:20 AM   #1193
YoDog's Avatar
That doesn't sound right... can you post a picture?
I run pinions over 50t 64p with no problems.
Are you racing or bashing? This will determine the kind of advice you want to look for. If you are racing, you will want to keep some 100t spurs on hand and 44t -50t pinions for running 13.5t motors in "blinky" classes.
Old 12-21-2015, 01:48 PM   #1194
here are some pics.
as i was taking the picture from above the car, i saw a slot that i believe that it's simply a pocket for the pinion, but plz correct me if i'm wrong.
Team Durango DETC410-2015-12-21-17.13.00.jpg   Team Durango DETC410-2015-12-21-17.15.16.jpg
Old 12-21-2015, 02:41 PM   #1195
ekt
ekt's Avatar
here are some pics.
You're missing the spacers between the spur mount and top deck, they keep the top deck straight when using those screws.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 12-21-2015, 03:15 PM   #1196
yes thats right, i've allready check with the manual and does have those spacers between the spur mount and topdeck. let me change that and re-check the fit of 50t pinion.
thanks
Old 12-21-2015, 04:23 PM   #1197
hey YoDog, as you were saying, indeed the 50t64p pinion does fit.
if you don't pull down the motor you just must loosen the top deck screws a bit and then bend it up so the pinion can go through.
also i was missing the four spacers, thanks to ekt for that.
i'll be posting some pics and vids of the car on the track.
best regards
Old 12-21-2015, 04:34 PM   #1198
YoDog's Avatar
best regards
Just when I looked at the side view pic, I noticed the spacers were missing as well but was beaten to the punch. The gap is designed in as a tuning option so that there is no contact between the top deck and lay shaft support when the screws are removed allowing for more rear flex. I have yet to see a setup that does this though.
Old 12-21-2015, 04:38 PM   #1199
in wich case i'll need to take down those screws?
Old 12-21-2015, 04:42 PM   #1200
ekt
ekt's Avatar
Here's Team Durango's gear chart to give you an idea of what pinions can fit http://www.team-durango.com/pdf/gear...ar%20Chart.pdf
Leo Lorenzen
