Old 03-25-2015, 11:07 AM   #1066
Originally Posted by Ray Kindstrom View Post
Hey guys. Whats the largest pinion I can run with the Durango 86T spur. To achieve 4.0 I'd need a 86-42/43
Thanks!
Ray, it will also be dependent upon which motor you are going to use.
There may or may not be interference with the top deck with some pinions as well as an interference issue at the chassis motor mount plate.
If you were closer, I would show you on mine and RJ's car.
Also, side note for all of you guys who have the car. Check your chassis', especially at the battery hold down screws and at the rear front arm mount when not using split blocks.
Under certain conditions during a hard crash, the battery hold downs will break the locator pin and cause a de-lamination of the chassis as the those screws torque and move (I have not found a fix other than a longer screw with a nut on the battery side).
The same goes for the rear front arm mount when using the 3mm plastic spacers, the torque from an impact will cause the mount to flex and damage the chassis as the screws try to pull through.
I have inspected 12 different chassis' over the last 3 months, and all have the same damage in the same spots from the exact same thing.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 03-25-2015, 11:12 AM   #1067
Ray Kindstrom's Avatar
Trader Rating: 147 (100%+)
I'm running either the short stack Fantom or the R1. Setting the car up for Leisure Hours....but I wanna come play at your track too! With that huge back straight gearing is going to be critical (as you know). Thanks for your help.
Ray Kindstrom is offline   Reply With Quote
Old 03-31-2015, 03:30 PM   #1068
tbrymer's Avatar
Default MB Models
I just received my Durango that I ordered from MB models in the UK, and I must say it was well worth it. Great car, great service!!
tbrymer is offline   Reply With Quote
Old 04-01-2015, 09:42 AM   #1069
pete68's Avatar
told you lol
great news and good luck
Yokomo BD7-15&16/YZ2 HOBBYWING/SMC/FUTABA/XPERT/MRT-PTX
pete68 is offline   Reply With Quote
Old 04-01-2015, 09:43 AM   #1070
pete68's Avatar
is there a 48pitch spur gear that fits directly the detc410
Old 04-01-2015, 11:56 AM   #1071
ErikJan's Avatar
I use this one: http://www.the-border.com/SPR-R1P314.html
ErikJan is offline   Reply With Quote
Old 04-01-2015, 12:09 PM   #1072
Spec gt? or you gonna move up to vta
tbamsey is offline   Reply With Quote
Old 04-01-2015, 01:31 PM   #1073
tbrymer's Avatar
This will be my backup car for the Reedy Race and then I'll make one of my Durango's a spec GT.
Old 04-01-2015, 03:13 PM   #1074
Pana racer and Lee speed spur gears are a straight fit
**Destiny RX-10s**Futaba**Trinity**Montech**SpeedyRC
Madmaxaus is offline   Reply With Quote
Old 04-20-2015, 09:45 PM   #1075
rcjunky1's Avatar
Not much activity here I've got 3 if these on the way
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 04-22-2015, 02:47 PM   #1076
rcgod's Avatar
Trader Rating: 27 (100%+)
I just picked up one of these for $235 shipped from MB Models. If you send them an email they'll send a paypal invoice and ship to the us.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-24-2015, 08:41 PM   #1077
tbrymer's Avatar
Default Low friction belts
Does anyone make low friction belts for the Durango? This is the only TC I have, so I'm not sure if they are universal or not. Any help is appreciated.
Old 04-25-2015, 09:54 AM   #1078
rcjunky1's Avatar
What's wrong with the stock belts? Degreasing and oiling the bearings will do more
Team Durango Canada
Old 04-25-2015, 08:10 PM   #1079
tbrymer's Avatar
Thanks for the tips, but I'm looking for low friction belts for the Durango.
Old 04-26-2015, 12:03 PM   #1080
rcgod's Avatar
Measure the length of the stock belts and try to cross reference them with low friction belts for xray or tamiya or one of the more popular cars.
Dialed RC Hobbies
