Old 02-04-2015, 01:17 PM   #1006
Hi everyone,
Here is the setup from Bjrn Brockmann, winner of the 17.5 class at lrp touring car masters.
Greets
Chris
Lutz is offline   Reply With Quote
Old 02-07-2015, 12:53 AM   #1007
Bmans5's Avatar
Raced Night.
Had some success, thought I would share.
We Race a tight carpet track and my rear end was slipping all over the place in practice.
Took another racers suggestion (he is sorta the setup guru around here), we removed the Rear Sway bar completely, set the rear shocks tops all the way in and front shock tops all the way out (he also wanted to replace the Springs, Hard in Front, Soft in the rear but we didn't have time).
Car become WAY more planted and only when I really floored it did the rear step out on me.
Was put in the A main Qualifiers (really should have been in the Bs, I am a rookie) but was able to put down respectable time despite having to move aside for the faster racers and managed 5th (out of 6).
My position got me bumped down to the B-Main, and much to my complete amazement I got 2nd Place, which got me bumped back up to the A-main.....Where I was doing ok till my battery died after about 20 laps.
Overall I am really pleased with the car. Nothing Broke, It handled well, and I was happy with the results.
I strongly suggest a Parma Hard bumper and Front gear if your on a tight track. The bumper has probably saved me quite a few bucks and the gears just give me great speed out of the corners.
Figure I will have this car perfectly dialed in....just as the indoor season finishes and outdoor off-road begins
Bmans5 is offline   Reply With Quote
Old 02-17-2015, 06:33 PM   #1008
Hi thought I would share my thoughts on this car
I have been running it now for just over a month. The build of the car was quite good, I did read through this thread to see what issues people where having with this car and took some steps in the build to help alleviate those foreseen problems
So the steps I took was to replace all the plastic spacers with Ali ones, pre threaded all the plastic to stop the stressing you get when using the screw to do this and glued in the cut outs in the front bumper.
As I race in the Modified class running a TX 4.5t orca set up, I changed out the spool out drives to the steal ones as I know from other cars that the track we race on is very aggressive on front ends. The track has a 60m front straight which leads into a 10 banked sweeper. I did try the front ali shafts but after 10 runs they had started to elongate at the joint so changed to the steal.
I put the low asphalt setup to start out as the track can be dusty and is a bit bumpy. I have slowly tried some of the option parts and settled with running the split block front and rear of the car.
Overall Im very pleased with the car, I have had some teeth issues but I do expect that with any new car as the settle down and you get into a routine with them.
I am currently working on resolving a front drive shaft issue Im having with the car but this is one more specific to the track I race on being the 60m straight into the banked sweeper. I am looking at two options, first is to put a diff in the front to help reduce the bind and the second is to replace the dcjs with ones from Roche. The second is the approach Im currently taking, I have found the drive shafts for the VBC DO6/7 from Roche fit but require the spool out drives to be changed. Im currently waiting on the Radtech T4 outdrive to arrive as I believe these should do the job.
Thanks and hope to contribute more to this thread.
The track I race on
**Destiny RX-10s**Futaba**Trinity**Montech**SpeedyRC
Madmaxaus is offline   Reply With Quote
Old 02-18-2015, 02:32 PM   #1009
theclutch's Avatar
Originally Posted by Crowbo74 View Post
Yup Tyler it works good. It gives you a little better turn in than a spool but still pulls hard off the corner without spinning the inside tire so easy when it's unloaded coming off a tight corner. Also you don't have to worry about it leaking like diff grease if it's not sealed good. Kinda like running a really tight ball diff.
I always wondered about this... So instead of putting putty, then why not just run a ball diff that's tightened up a little more than usual?
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 02-18-2015, 03:09 PM   #1010
Crowbo74's Avatar
Trader Rating: 111 (100%+)
Default Gear diff
In my opinion the gear diff is more reliable. Whith the ball diff, it wears the rings and loosens up over time. If you have a good sealed gear dif, it stays consistent whether you use putty, ear plugs, or oil.
Crowbo74 is offline   Reply With Quote
Old 02-19-2015, 10:38 PM   #1011
hi , somebody know if theres a new detc 410 v2 coming or new options ?? thank you.
good car
Javier Bas is offline   Reply With Quote
Old 02-20-2015, 08:32 AM   #1012
tbrymer's Avatar
good car
I've only heard that they are making new harder composite parts.
tbrymer is offline   Reply With Quote
Old 02-20-2015, 08:36 AM   #1013
Default agree
Originally Posted by TAMAK View Post
I think its safe to say the Team Durango car is belt driven. lol..Not knocking shaft drive cars, but i think it was a "safe" choice.
Yes.. I agree with you
jokowi is offline   Reply With Quote
Old 02-20-2015, 09:57 AM   #1014
ok thank you.,,,
Old 02-20-2015, 10:54 AM   #1015
32819toon's Avatar
My Durango DETC410 for sale :-
FOR SALE - DURANGO DETC410 TOURING CAR
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 02-21-2015, 03:46 AM   #1016
morning all. its probably been mentioned some where in the 68 pages, but last night i bent a rear camber link, so i would like to upgrade to titanium or another alternative, and while im at it would like to upgrade the ball cups to get rid of some of the slop.
so can anyone recommend me turnbuckles and ball cups. links would be appreciated
many thanks
micksid is offline   Reply With Quote
Old 02-21-2015, 12:12 PM   #1017
Mick. seen the car was based on the Yokomo I would start there.
big paul is offline   Reply With Quote
Old 02-23-2015, 06:14 AM   #1018
Originally Posted by Bmans5 View Post
Raced Night.
Thanks for sharing this setup, very intersting i will need to try this. Now you know to start a race on a full charge
What front gear are you refering to?
Saint Hyacinthe RC Circuit
circuitctsh.com
rc-demon is offline   Reply With Quote
Old 02-23-2015, 06:16 AM   #1019
many thanks
I have not bent any camber links only steering and have upgraded those to titianium.
as for ball cups, switch to Tamiya balls and cups and no more issues! super tight and resistance.
circuitctsh.com
Old 02-23-2015, 08:17 AM   #1020
edonsohc's Avatar
i finally got a full race weekend w/ the Durango in usgt trim. overall the car ran good. I broke two front plastic spool outdrives. totally my fault. I hit very hard trying to avoid traffic. I bent an aluminum steering link also. other than that, the car ran well when the driver wasn't running into stuff. finished third in the b main. I'm happy with that considering it was my first real outing w/ the car.
Tekno sct410.3, tekin gen2 rx8, hobbywing 4700kv motor, savox 1258.
Tekno EB48.3sl, 4000kv hobbywing on 3s.
Losi scb, mmp, bhr 10.5 motor.
Ofna H4E, vta, usgt, & 17.5 tc
Spratt's Hobby Center, Hillsdale Michigan.
edonsohc is offline   Reply With Quote
