Old 01-20-2015, 11:36 AM   #991
Hexonox's Avatar
Originally Posted by Mikey M View Post
Yeah that thought has come to mind to try. Just need to figure out why the threaded rods seem to be continuing to pull out too on what seems to be fairly mild taps on cliktrack barriers on a carpet track.
Lock tight!!!! Had the same issue on mine. Used the lock tight that came with the kit.
Team F.T.N.S.
Kyosho MP9e TK I, XRAY XB4 2015, TD DEX210, TD DESC210, TD DETC410, Tamiya TA06 PRO, Tamiya M05/06, Serpent S100
Hexonox is offline   Reply With Quote
Old 01-21-2015, 12:30 AM   #992
Use longer screws and Loctite. I´m of the opinion, that the screws in the kit are to short.
Fischmeister is offline   Reply With Quote
Old 01-26-2015, 05:29 AM   #993
Default Team Durango wins LRP Touring car masters
Hello, everyone,
the lrp toring car masters (tcm) took place last Weekend and we had 5 participants there. Björn Brockman tqed and won the 17.5 blinky class while Michael Spiering qualified 3rd but endet up 5th with little luck in the finals.
I participated in the 10.5 class but wasn´t my Weekend so I endet 23rd but the car felt good in the end.
The track was large and flowing on blue ETS-carpet. We had to use LRP CPX tires and hotbodies Bodys as well as LRP Motors and esc.
I can post Setup in the next days, as we need to recover from the long Weekend first^^
greets
Chris
Lutz is offline   Reply With Quote
Old 01-26-2015, 10:52 AM   #994
tbrymer's Avatar
Default Front Diff
So put a front diff in my car and there seems to be a lot of play in the driveshaft/outdrive area. Does anyone have a solution for this, or have people been living with it? I'm not sure if the rear driveshaft would work in the front since they are 44mm versus 41mm and there might be other reasons.
tbrymer is online now   Reply With Quote
Old 01-26-2015, 05:30 PM   #995
ekt
ekt's Avatar
Just checking, do you have the front diff outdrives TD310440 installed? They have a smaller gap for the driveshaft pin than the rear ones.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 01-26-2015, 05:37 PM   #996
nice
articsilber323 is offline   Reply With Quote
Old 01-26-2015, 09:16 PM   #997
tbrymer's Avatar
Nope, didn't know they made them. Thanks.
Old 01-28-2015, 02:30 AM   #998
Does anyone know if there is any company out their that is making a hop up replacement part for the l shaped plastic battery holders. I keep splitting and breaking them.
Thanks in advance
Pearso888 is offline   Reply With Quote
Old 01-28-2015, 03:13 AM   #999
Thanks in advance
Do you use tape or velcro? you could try the Mr Roche battery stops
http://www.roche.hk/shopping/index.p...roduct_id=1202
**Ausrab Industries**Destiny RX-10s**Futaba**LRP**GRP**SpeedyRC
Madmaxaus is offline   Reply With Quote
Old 01-28-2015, 11:25 PM   #1000
Bmans5's Avatar
I did this after the 3rd time it popped loose on me and it solved the issue, books says a 3x10, I went to a 3x12 and Locktite and no more issues
Bmans5 is offline   Reply With Quote
Old 01-29-2015, 01:17 AM   #1001
Cool thank you i might try that.
Old 01-30-2015, 06:35 AM   #1002
What are some ideas being used to keep these from spinning off? And also from the threaded rod from pulling out of the arm?
As someone else mentioned, you need to loctite the set screw to the lower shock mount then attach lower mount with your nut driver.
An other solution some people are doing is using longer set screws and screwing it in directly to the a-arm. There is enough aterial to do this.
Saint Hyacinthe RC Circuit
circuitctsh.com
rc-demon is offline   Reply With Quote
Old 02-01-2015, 11:07 AM   #1003
tbrymer's Avatar
I just put the new outdrives designed for a front diff and all the slop is gone!
Old 02-01-2015, 01:08 PM   #1004
Bmans5's Avatar
Thanks in advance
Not to my knowledge. The part that is breaking, is the the part you can slip a velcro strap through?
If so this was my solution (with a friends help).
We added longer screws used a punch to punch through the strap and secured it with a nylon locking nut. (I would add an image but apparently I can't, but you should be able to figure out what I am saying.)
It works great...would be even better if I had a hard case battery but still works as long as I add servo tape under the battery. My buddy did the same thing on his VBC and so far both of us have had no battery issues.....and we have hit things HARD, my car actually got airborne a few races ago and it was fine....body was mangled though.
my only really big issue is the softness of some of the plastic. Normally it would be ok but the adjustablity (additional mount points, IE holes) make it so things strip out easily. MY solution has been to stuff every adjustable point with a m3x5 set screws. I hope we see some harder plastic in the future.
Old 02-04-2015, 08:46 AM   #1005
Default price drop
I noticed on tower/amain the price drop $20 whaz up?
TeamThibault is offline   Reply With Quote
