Old 01-17-2015, 01:49 AM   #976
Originally Posted by tbrymer View Post
I'm thinking about putting on a diff in the front. I know someone else that has done it and it seems to be working great for him. We race on asphalt. In building the diff he said that he tore apart an a couple of ear plugs and put the pieces inside of the diff so that it would be almost as tight as a spool, but still work somewhat. Has anyone heard of this?
TBH I've tried allsorts and settled on 1million cst oil, as its always consistent, the problem with things like putty's and ear plugs etc is that they break down and become inconsistent, building a diff properly will ensure that it won't leak also.
B.C.Ninja is offline   Reply With Quote
Old 01-17-2015, 08:13 AM   #977
tbrymer's Avatar
Default Front Gear Diff Oil
Where is a good place to purchase the 1million cst?
tbrymer is online now   Reply With Quote
Old 01-17-2015, 04:57 PM   #978
hi , somebody runs the car without double sided tape under the servo, i have the aluminum servo mounts(optional) and i removed the double sided tape and theres a small flex under servo works but s its normal i think the car goes better for more float effect.
Javier Bas is offline   Reply With Quote
Old 01-17-2015, 10:23 PM   #979
http://www.arrowmax-rc.com/index.php...oducts_id=1350
This is the one I use, can buy direct off of site, or there's the usual RCMart, RCMushroom etc
Old 01-18-2015, 07:37 AM   #980
Mach10_shooter's Avatar
Trader Rating: 36 (100%+)
If anyone is looking for a good deal on a new main chassis plate.
NIP DURANGO DETC410 MAIN CHASSIS. NEW, UNUSED...
Mach10_shooter is offline   Reply With Quote
Old 01-18-2015, 05:25 PM   #981
ZeroDown7169's Avatar
Trader Rating: 53 (100%+)
Gravity rc has it too
ZeroDown7169 is offline   Reply With Quote
Old 01-18-2015, 07:37 PM   #982
tbrymer's Avatar
Thanks for all the info. I haven't built my front diff yet, but when I do, I'll try the 2.5million cst Gravity lube. BTW - The car is working great!
Old 01-18-2015, 07:39 PM   #983
Nice color scheme and carbon fiber
leothegreat is offline   Reply With Quote
Old 01-18-2015, 08:11 PM   #984
Crowbo74's Avatar
Trader Rating: 111 (100%+)
Default Front diff
Tyler, the ride putty works good also.
http://www.tqrcracing.com/shop/produ....asp?p_id=3550
Crowbo74 is offline   Reply With Quote
Old 01-18-2015, 08:43 PM   #985
tbrymer's Avatar
Yeah, I was thinking that the lube wouldn't lock the diff up completely. I do want some slip, and I'm not sure if the putty will be just like it was locked.
Old 01-18-2015, 08:56 PM   #986
Crowbo74's Avatar
The 45 putty is medium hardness. If you look they have different compounds all the way up to locking putty. The 45 is heavier than the 2.5 million but will still allow slip.
I have 1 million cst and the 45 putty I can bring to the track and let you see the difference.
Old 01-19-2015, 06:50 AM   #987
tbrymer's Avatar
OK, that sounds great. I'll try the 45 putty and see how it feels.
Old 01-19-2015, 07:24 PM   #988
Mikey M's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to Mikey M
Ok heres a question in sure has been answered a few times. But it's a lot of pages to look thru on my phone.
What are some ideas being used to keep these from spinning off? And also from the threaded rod from pulling out of the arm?
Mikey M is offline   Reply With Quote
Old 01-19-2015, 08:14 PM   #989
tbrymer's Avatar
I'm not sue I really know what you are trying to specify in the picture. If you are talking about the shock ball end, you can use the blue thread lock.
Old 01-19-2015, 08:30 PM   #990
Mikey M's Avatar
Yeah that thought has come to mind to try. Just need to figure out why the threaded rods seem to be continuing to pull out too on what seems to be fairly mild taps on cliktrack barriers on a carpet track.
