Team Durango DETC410
#886
Looks like new lower bulkheads and new spur gear systerm , testing parts for the updated car
#887
The "new" lower bulkheads are the original ones, but a bit more cut to save some weight. As far as I know there is no new spur gear System. I think he did just not mount the other side of the motor-mount.
#888
Which drive shaft do you use with the front gear diff?
#890
half way threw my build and there is no plastic shims in bag G1, anyone else have parts missing
#892
Thats fine, we want more involvement in clubs but I wouldn't want it to be labled as cheap kit and be in the same categories as those cheap kits!
#893
I looked all threw parts trees and in bags not opened no shims at all
#894
96T Yokomo Panaracer with 46T pinion, FDR = 3.90
it really depends on your track and its size. I started at 4.07 (46t) and not at 3.90 and its much better for my track. You need to experiment. Good ball park is to start around 4.0 FDR.
#895
XRAY Hard Foam Bumper [XRA301223]
#897
Is it normal that i need so different EPA for the steering? Left a value of 80 and right 120. A small difference is normal, but so much?
Servo is a Savöx 1251 and the transmitter a Futaba T4PK. The servo horn is mounted in the center.
#898
When setting up your steering, you must ensure that the servo horn and the tie-rod are at a 90 degree angle. In the case of the DETC410, this means that the servo horn leans towards the middle of the chassis slightly. The brand of servo and radio make no difference. See how the servo arm on my steering servo leans into the middle of the chassis.
#899
Thx for your help. It works. A tie-rod was also bent.
#900
Hello, rc-demon,
Can you please explain why you think the stock bumper is crap?
If you leave it as one part without takubg out the inserts it's pretty stiff and protects the front suspension well.
The next thing is: what makes a kit for 200€ worse than a kit for 450€? I think the example of the detc410 makes clear, that you pay a lot for the brands name and their pro drivers. Durango decided that they don't need a pro team anymore and they give the benefit to the costumers with a lower price. This does not affect the quality of the car.
It is known, that the plastic parts are quite soft. Thats the reason why other parts and material is tested.
But there will not be a complete new kit in the near future.
Greets
Chris
Greets
Chris
