Old 11-08-2014, 08:23 PM   #826
tbrymer's Avatar
Has anyone tried the C&M chasis for the Durango?
tbrymer is offline   Reply With Quote
Old 11-13-2014, 12:39 PM   #827
32819toon's Avatar
Default reliability
Anyone have reliability issues ?
I bought 2 DETC410 cars. I built one for my 11 year old son which he now races and loves driving. However, in his first practice (not even a race) he broke a front CVD joint, it split in half. On his second outing, he broke a driveshaft axle. The nipple bit which joins into the driveshaft actually sheared off. Third time out he broke a plastic outdrive. Three outings - three breakages. Not what I expect from a so called top end car. I've emailed Durango twice and had no reply, so much for customer service. I've not even built my car yet, it's been a spares donor for my son's car.
I believe that the problem might be the spool. I had similar issues with our last touring car. We went through loads of driveshaft joints until I installed a gear diff up front. We race on a tight technical track, and I think it's too much for a spool to handle.
I've bough a gear diff and steel outdrives for both Durango's so hopefully this will sort out the problems.
Not happy with the customer service at Durango though. I feel like selling both cars and buying another brand.
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 11-13-2014, 06:14 PM   #828
Trader Rating: 14 (100%+)
I've always called the support.
RBraswell is offline   Reply With Quote
Old 11-15-2014, 01:56 PM   #829
32819toon's Avatar
Update - broke another front CVD joint tonight - while building a driveshaft ! The joint split in half while I was tightening the grub screw. I put a new joint on the driveshaft and it has jammed at an angle, and won't budge. I'm feeling less and less for this car every day. I found that standard Spec R driveshafts fit the front, so I might just fit those and leave the double jointed ones off. It's a pity my 12 year old loves driving his or I'd just sell both if them.
32819toon
Old 11-16-2014, 05:32 PM   #830
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
Can someone do me a favor and measure the thickness of the rear bone blade (310338)? Is it for a 2.0mm pin also? Looking to use it on a project for my DEX410 outdrives. Thank you!
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 11-17-2014, 12:00 PM   #831
32819toon's Avatar
Just found that the Durango driveshafts and blades are narrower than Spec R (probably Xray as well). I've managed to free up the jammed joint, and will persevere with building the driveshaft unit. The pin and grub screw are a very tight fit though. Bman, this may be useful info for you.
32819toon
Old 11-18-2014, 05:14 AM   #832
quick question just got a used DETC410 and i am missing the battery mount tdr320179
but seems to be back order everywhere. is there a compatible part for it ?
thx for your help
dodgeboy8888 is offline   Reply With Quote
Old 11-18-2014, 06:08 AM   #833
Amazon has one left in stock look up part number td320179
Drop the R you get different results
Old 11-18-2014, 06:37 AM   #834
ouch 26$ shipped
trying to find a compatible part
Old 11-19-2014, 10:11 AM   #835
They are 3.5mm wide, similar to a TC6 blade
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 11-19-2014, 10:17 AM   #836
Try this number for Hobby Services in the US 217-398-8970
Yes, running the Gear Diff up front will also help with some breakage as well as using an XRay front bumper #301223. We also have used the Parma Ultimate Bumper for the TC5, but it has now been discontinued.
I have only broken 1 axle up front as you have after an extremely hard hit to a board on an outside track using 2x4 boards. Assembly of the DJoint can and is tricky because of the tight fit, and have found if there is any damage to the shaft side of the assembly it can bind or become "stuck" as you mentioned.
Old 11-19-2014, 10:28 AM   #837
Thank you!! What about the pin size it fits over. 2.0mm? Thanks again.
Xray Xb2 CE
Old 11-19-2014, 06:57 PM   #838
thx for your help
nobody ?
Old 11-20-2014, 01:51 AM   #839
ekt
ekt's Avatar
2mm for the pin.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 11-20-2014, 05:34 AM   #840
Originally Posted by ekt View Post
2mm for the pin.
Thank you!
Xray Xb2 CE
