Old 08-26-2014, 09:49 PM   #766
CypressMidWest's Avatar
Medium to high bite carpet, everyone locally has found that Yokomo Pink, and Blue Springs are the best option. The car is very forgiving, while still carrying excellent cornerspeed with these springs coupled, with the manual high bite set-up, tuned slightly to personal tastes. Excellent turn-in, great rotation, while maintaining a stable feel.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 08-26-2014, 09:53 PM   #767
Trader Rating: 39 (100%+)
Front pink blue rear? Do you know the spring rate?? Have not ran mine on carpet yet
DR.Vanostrum is offline   Reply With Quote
Old 08-26-2014, 09:59 PM   #768
Blue front, pink rear if I remember correctly. I'll double check tomorrow. I had been running two dot rears, and three dot fronts. After switching, I was more comfortable, and WAY more consistent. Fast lap didn't improve, but 10 lap average picked up .2 total. Smoother, and easier to drive, with no "snap" oversteer on exit.
Old 08-27-2014, 04:30 AM   #769
Yokomo's standard carpet spring setup is Pink Front, Blue Rear.
Smartypants is offline   Reply With Quote
Old 09-01-2014, 02:40 PM   #770
Trader Rating: 35 (100%+)
I have 2 black editions for sale if anyone is interested and a ton of parts.
Team Durango DETC410-20140829_170330.jpg   Team Durango DETC410-20140829_170357.jpg
XRAY T4 15' MOD:X-RAY T4 15 17.5:T.O.P Rebel WGT:VBC LIGHTNING F1
5280 RACEWAY "Racing Elevated"
MILE HIGH INDOOR CHAMPS April 17-19th 2015 @ www.milehighindoorchamps.com
Losi22 is offline   Reply With Quote
Old 09-10-2014, 10:48 AM   #771
Trader Rating: 14 (100%+)
Thinking about getting into on-road and was looking at this car and the AE 6.2 FT. What would you say are some pro's and con's to this car? I own several durango offroad vehicles currently.
RBraswell is offline   Reply With Quote
Old 09-10-2014, 11:08 AM   #772
Mach10_shooter's Avatar
Trader Rating: 36 (100%+)
The only con I have is the amount of slop in the ball cups. I've since switched both my cars over to Tamiya balls & cups. Otherwise very nice!
Mach10_shooter is offline   Reply With Quote
Old 09-10-2014, 11:25 AM   #773
Crowbo74's Avatar
Trader Rating: 111 (100%+)
Default Durango
I have ran all the associated touring cars, the 6.2 is the best if you go with associated. I had 3 6.2s until about 3 months ago. Then I converted to Durango detc410s. I feel the associated had more slop in it and it's baseline setup wasn't as good. It takes more tweaking on the 6.2 to get it dialed in bit once you figure it out the cars are similar. The Durango out of the box has a front spool with plastic out drives, this is the first thing that has to go. You will break the out drives, replace the front spool and install a gear diff with steel out drives and problem is solved. You will do the same with the associated 6.2 as it comes with a composite spool in the front. I currently have 5 Durango's, 2 vta, a 21.5 spec gt car, and 2 17.5 blinky cars. All have the front diff changed to a gear diff. 1 car has tamiya arms, caster blocks and bearing carriers as they are a little harder. When comparing 6.2 to detc410, I feel the Durango has less slop and baseline setups will make you faster out of the box as they offer 4 different setups depending in your track. Durango cars are cheaper used and parts are cheaper. That's why I chose them. My first night with my Durango, I matched my fastest laps with my 6.2 I had for several months. All that being said, I now have too many. Lol so if you are looking I will make you a good deal on a roller. I have 2 listed. Just really need 1 to go, thought I would list both, sell 1 and run the other. Both are great cars, but I think the Durango is better out of the box on the track.
Crowbo74 is offline   Reply With Quote
Old 09-10-2014, 11:31 AM   #774
Crowbo74's Avatar
Default Here are my cars
Really just want 1 gone. Have too many
Hey guys, selling 2 durango detc410 touring cars.
Car #1 Durango detc410 I have the gravity aluminum screws on the top, It has the gear diff up front, and has the spool as well. I put all the tamiya 418 parts on the car now. The plastic is harder and seems to give it more steering. So the Tamiya parts are the arms, hub carriers, steering knuckles and outer hinge pins. All the stock arms hubs and carriers will come with so you can switch back if wanted. Car has about 5-6 weeks on it. Electronics are 1 race old. Team powers actinium 17.5, hobbywing 120 amp water proof v3.1, futaba s9551 low profile servo with aluminum arm and outside aluminum mount, and wild turbo fan.
Roller $320
With electronics $580
Car #2 Durango detc410. Comes with front gear diff installed and stock spool. Also comes with 2 race old trakpower ms1 esc, 2 race old spektrum 6070 servo with aluminum arm, and a hacker skalar 17.5.
Roller $280
With electronics $500
Both cars are in great shape and super fast.
Pm or text 520-431-4075
Old 09-13-2014, 01:39 PM   #775
tbrymer's Avatar
Default Rollout
What's the tranny ratio for the DETC410? I want to calculate rollout.
tbrymer is offline   Reply With Quote
Old 09-13-2014, 01:54 PM   #776
Crowbo74's Avatar
Default Ratio
1.95
If you are going spec gt you need 116/41 gives you a 5.52
Old 09-14-2014, 01:52 PM   #777
tbrymer's Avatar
Thanks! I didn't see you at the track yesterday. They changed up the road course and it's rather complicated, but should help me learn to drive better
Old 09-14-2014, 03:04 PM   #778
Crowbo74's Avatar
Default Track
No problem. Probably won't be out for a few weeks. Did you run the durango? If so, how did it feel?
Old 09-14-2014, 05:15 PM   #779
tbrymer's Avatar
No, it will be at least a couple more weeks before I run the Durango. I have some electronics coming and still need to get a body and paint it.
Old 09-16-2014, 02:38 PM   #780
Trader Rating: 1 (67%+)
Send a message via AIM to racer034life
Still got the roller for sale with parts...pm me the price and a PayPal email address
Access Hobbies,CRC, Detc410,
The Ian Ruggles Negative Reinforcement Driving School
racer034life is offline   Reply With Quote
