Old 06-01-2014, 10:08 AM   #676
joelwhite's Avatar
Trader Rating: 55 (100%+)
Originally Posted by Mach10_shooter View Post
You have to change the balls too! Just switching out the cup to Tamiya makes it even worse.
I fugured, bummer man. Its a good car, I hate to pick on it. But I knew from offroad that they would suck lol. And bein an offroad guy Im ok with some slop. But its too much for me.
HEART OF A HUSTLER RACING TEAM
Trick Graphics--see spdrac430 on this forum for all your painting needs
Team Pit Racers-Fastest Guys In The Pits!
joelwhite is offline   Reply With Quote
Old 06-01-2014, 02:54 PM   #677
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Very nice DETC410 for sale over at DETC410 and 17.5 HT Killshot by Express Motorsports
Fishhook
ewashburnaf is offline   Reply With Quote
Old 06-01-2014, 03:48 PM   #678
nf_ekt's Avatar
Trader Rating: 113 (100%+)
In the past i used to reduce slop by placing a bit of clear plastic (like what parts are sold in) over the ball, then snapping the cup on. It puts a little material in there to take some play out. Not sure if it would work on this car but it's worth a try.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 06-01-2014, 06:19 PM   #679
joelwhite's Avatar
Yep good advise, have been pondering that myself.
Old 06-02-2014, 01:23 PM   #680
Cadman1981's Avatar
It works on this car as well, just not the Durango bags as they are very thick! haha
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 06-02-2014, 06:54 PM   #681
Originally Posted by Rodney Racer View Post
I received this car under a certain situation that helped another racer out. I was curious about the car and the geometry of the car.
Taking nothing away from this car, it is flat out the best out of the box car I have ever driven. The few times I have run it the car has worked exceptionally, and surprisingly well. It responds to changes positively and is very easy to work on.
If I wasn't under another tent this would be the car I would run, hands down.
Awesome!
Fishhook
Old 06-03-2014, 10:19 AM   #682
Mach10_shooter's Avatar
Trader Rating: 36 (100%+)
I'm running the steel out-drives on my spool and I've noticed some wear already on the drive pins on the swing shafts. I'd love to run drive pins with replaceable plastic blades like other cars have.
Does anyone know why Durango wouldn't have put blades on the front too?
Also what about swapping another brand of axle assembly onto this car?
Mach10_shooter is offline   Reply With Quote
Old 06-03-2014, 10:30 AM   #683
Phoenix82's Avatar
In the past. I have broke a pin cushion durning a heat. the car would pull in when on power. I personally like that there is no pin cushion. Id rather just replace the worn out part.
JMO
Nick K
Phoenix82 is offline   Reply With Quote
Old 06-03-2014, 10:51 AM   #684
As Nick has said the chance of a ill handling car after a crash is reduced by not running the pin cushions in the front. If your running the steel outdrives its best to cover them with shrink wrap and then load them up with black grease, this will take some of the shock out of the pin to drive which should give you a little longer life out of those parts.
Rodney Racer is offline   Reply With Quote
Old 06-03-2014, 10:55 AM   #685
Ok, thanks for the info.
Old 06-03-2014, 12:16 PM   #686
Send a message via MSN to Bigger Brother
A number of the Durango team are heading to the ETS event at the fantastic Luxembourg track tomorrow.
If anyone needs any help or has any questions about the car, or just wants to chat to us, please feel free to come and find myself or Elliott Harper at any point over the weekend! See you there!
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 06-03-2014, 12:47 PM   #687
Wattsup23's Avatar
Trader Rating: 29 (97%+)
Oli
Post updates and pictures if you can!
Team Watts Racing
Wattsup23 is offline   Reply With Quote
Old 06-05-2014, 08:39 AM   #688
Cadman1981's Avatar
Has anyone tried the Split suspension blocks in the front (or in the back, or both)? How did you find the car compared to the solid blocks?
I'm looking to get more front end grip with some flex changes on the car. Suggestions? i race mainly outside on medium grip asphalt with Ride 32 tires. I have tried the Yokomo Blue springs, and HPI Silvers
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 06-05-2014, 09:42 AM   #689
Rick Vessell's Avatar
Run the split blocks and take out all the upper deck screws except the ones at the ends. Start with split blocks on the front and add the rears if you end up with too much steering.
Rick Vessell is offline   Reply With Quote
Old 06-07-2014, 05:51 PM   #690
Cadman1981's Avatar
The car Elliott is driving looks good! even using a velcro strap for the battery!
http://ets.redrc.net/2014/06/chassis...lliott-harper/
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
