Old 03-30-2014, 05:53 PM   #466
The One They Call Dirty's Avatar
Trader Rating: 53 (100%+)
Second time out with with the car, and I have to say the cars overall performance is great. The last TC I owned was a MR4TC, and that was 10+ years ago. The car is smooth, and easy easy to drive. I've found myself dialing more steering out out than I probably should, but I'm not used to all all this traction so I'll have to ease my way into it.
This may not be the place to ask, but if anyone has any spare Steering Blocks (TD330521), I'd be more than happy to buy them from you. I'm a newbie to onroad and I seem to be breaking these with ease lol.
92zero Designs -Diggity Designs
Fantom Racing - Lunsford
MIP -Team ARC - Windy City RC
The One They Call Dirty is offline   Reply With Quote
Old 03-30-2014, 07:36 PM   #467
Trader Rating: 135 (100%+)
Tower hobbies has them in stock.
jeff jenkins sr is online now   Reply With Quote
Old 03-30-2014, 08:14 PM   #468
They don't, order pending. I work part part time a hobby shop and have plenty backordered, but in the event I break one before they're off backorder (likely lol) I'll be screwed.
Old 03-30-2014, 09:03 PM   #469
snoopyrc's Avatar
I'm sure a steering block from another chassis would work until the backorder parts come in. I would change them bilaterally to keep the setup symmetrical.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 03-30-2014, 09:08 PM   #470
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
First time out with the DETC410 today. Started with the Low Grip Carpet setup. Worked well, made some changes to give more flex and I set my best lap times by .5 secs... gained 2 laps from my best ever!!! Didn't break a single part and had a blast!! I love this car!! I do think the steering rack needs some "tightening up".
Fishhook
ewashburnaf is offline   Reply With Quote
Old 03-30-2014, 09:21 PM   #471
pyro854's Avatar
Just like every other car out there, its nothing a shim couldnt fix.
RJ Whiteside
pyro854 is offline   Reply With Quote
Old 03-30-2014, 09:26 PM   #472
Yeah. That would do it.
Fishhook
Old 03-30-2014, 10:40 PM   #473
JimmyMac's Avatar
Your car looked good out there Eric. If you need any shims, let me know. I can shim it out for ya the next time you are at the track.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
JimmyMac is offline   Reply With Quote
Old 03-30-2014, 11:35 PM   #474
Hi guys. Am I correct in saying that you can change your rear toe via suspension hangars or rear hub carriers? If not. What are the inserts for in the rear hub carriers
Gerrie is offline   Reply With Quote
Old 03-31-2014, 02:37 AM   #475
Airwave's Avatar
inboard toe and outboard toe have not the same effect on the car behaviour...
Airwave is offline   Reply With Quote
Old 03-31-2014, 03:47 AM   #476
defcone's Avatar
Trader Rating: 15 (100%+)
What difference is there?
defcone is offline   Reply With Quote
Old 03-31-2014, 06:55 AM   #477
Trader Rating: 26 (96%+)
I really find the plastic too soft, its got more of a foamy feal, rather then the more crisp xray or tamiya carbon reinforced parts feal, but they do not break easily, I guess a lot of flex built in, I am going to mount some 418 suspension on the car and see how it handles, like I said earlier it is a direct fit, no modifications required. The trf shocks as well are a direct fit and proper lenght and you get one of the best shocks in the business, my car handled a lot better then the stock shocks, but I tend to put trf shocks on all my cars anyway, I think this car with the correct parts will be very quick
zaraz is offline   Reply With Quote
Old 03-31-2014, 11:03 AM   #478
Cadman1981's Avatar
How are the Durango shocks vs the TRF shocks??
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 03-31-2014, 11:44 AM   #479
rosko's Avatar
If your running a total of 3 deg rear toe and 1 deg of the 3 deg is on the rear hub, your car would have a little less turn in into the corner but more rotation center on, and less forward bite.
rosko is offline   Reply With Quote
Old 03-31-2014, 11:45 AM   #480
the durango are not as smooth, compared to trf, I find the trf more adjustable friendly, as in you can notice a difference if you make adjustments, the durango are fine, but as soon as I put the tamiya ones on, the car was like its on rails, for me also helps as I have tons of springs that fit the trf, so gives me more options, my next project is going to see how the 418 suspension works on the car
SEO by vBSEO 3.5.0
