Old 04-10-2013, 02:27 PM   #1
Default New To Drifting - Suggestions and Tips?
Current setup is:
Chasis: Sprint 2 Flux with 1 way front differential
Motor/ESC: Novak Drift Spec Sensored 13.5T
Novak Glitch Buster
Stock Radio
Stock Reciver
Savox Servo
Tires: i have some HPI t Drifts but also some Traxxis Volk Racing
Generally running on Asphalt parking lot.
0 Camber 0 Toe
Is there anything here that you guys suggestion tweaking? i can get it sideways in the parking lot with ease but it seems videos i watch they seem to slide easier. Maybe its just the surface im on but im open to suggestions. Where i am from non of the RC stores do ON Road as its unpopular here so i dont have much resource for this side of RC.
Treello is offline   Reply With Quote
Old 04-10-2013, 09:39 PM   #2
Research "countersteer" it is pretty easy to do with the sprint chassis, you could also do the drive train swap, and to fix your sloppy steering do the solid screw mod on the drivers side bellcrank.
2013 HPI Mini Recon
2012 HPI Sprint 2 Sport
1983 Marui Samurai
Slobalt7 is offline   Reply With Quote
Old 04-11-2013, 07:06 AM   #3
Counter steer is what is most are using in the vids u see to drift easier. Also set your camber to at least -2. That will help out also.
Badcompny44 is offline   Reply With Quote
Old 04-11-2013, 07:32 AM   #4
grapejuice's Avatar
Trader Rating: 123 (100%+)
You will find a lot more info/help on the drifting forums like csjunkies.com
TLR 22 2.0 / TLR 22-4 / Yokomo BD7
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
Old 04-11-2013, 02:24 PM   #5
kneedeeppow's Avatar
rc drift can be split into two 'classes'. 50/50 which basic 4wd like most rc touring cars,and counter steer which is still 4wd but the gearing(pulley wheels or gears)has been modified so the rear wheels spin faster than the front to enhance the rear wheel drive affect. 50/50 is nice and simple to set up and drive,counter is a little more tricky. it requires a very good understanding of the gearing and steering and suspension geometry of the chassis to get the cs working properly.
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
SEO by vBSEO 3.5.0
