Old 05-29-2013, 09:18 AM   #121
theatriks's Avatar
Originally Posted by EricF View Post
Because it's the law of internet... besides what else are we going to do??
E
LOL ya im getting kinda figgedty waiting for this kit too......but you cant give an honnest opinion on this car until its actually in someones hands......its like road and track giving a review without driving the car lol.........i hate that were still 3 weeks away ahhhhhhh!!!!
Mod Mod Mod...I love Mod.....and scotch!
theatriks is offline   Reply With Quote
Old 05-29-2013, 12:11 PM   #122
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Sydewynder View Post
You are absolutely correct. What I'm saying is with no camber gain the tire camber goes towards positive as the car rolls. It was stated that the positive camber is no different than a pro but the difference is the pro has camber gain.
If a car is setup properly then as it rolls and the camber goes more positive you could end up with a full contact patch/0 deg camber at max roll which would be ideal thus no reverse coning. On the flipside with the 103 since it has no static camber, if the upper arms moved ---> camber gain you might not see reverse coning.
its also going to depend on the caster as well since the caster is going to add camber on the outside tire even with no actual camber gain. I think the regular pro front end is around 5* so if they maintain that there will be some outside tire gain and some inside loss as well.
I think the big thing is making the car more stable. Sometimes all that extra front bite is hard to tame.
Old 05-29-2013, 12:27 PM   #123
theatriks's Avatar
what 21.5 turn motors you guys running? i just want to get my electronics line up before i get the kit.
Old 05-29-2013, 12:41 PM   #124
Originally Posted by WheelNut View Post
So, has anyone else noted the fact that the front end of this car will feature zero camber gain. It is essentially a Macpherson strut front end. Thoughts?
I'm not sure if I should wait for this car of buy a F104 v2 Dark Ti edition. The 101 looks really strong in the front, which would be a plus.
The F104 front end has an upper link 52mm centre to centre. You have at absolute maximum uncompressed to fully compressed spring a wheel travel of 3mm, and that full travel is unlikely to happen on track. This means as the F104 front end compresses the kingpin leans in all of 0.087mm, that's 4 thou and you'll probably get more movement from the play in the front end. The camber gain is 0.23 degrees.
Yeah but as the chassis rolls the outside wheel will actually get positive camber, which is a fundamental problem for the tire's contact patch.
If the chassis rolls so the inside is at full extension while the outside is at full compression, that means the chassis rolls through 0.95 of a degree, that is 4 times the amount of camber gain the F104 front end has so if positive camber is a problem with the TRF101 then it would be the same problem with the F104. Of course this doesn't take into account that when cornering the wheels are turned, so the caster adds most of the camber gain when cornering so neither front end will ever have positive camber when cornering.
There has never been anything wrong with the F103 having a sliding kingpin front end, the only problem being the fixed camber meaning tyre coning but you can dial a lot of that out as well as increasing caster by adding a 1mm thick washer between the wing and front suspension on the front mounting screw. The TRF101 has adjustable camber as standard, and if Tamiya doesn't produce a range of upper arms to tune the suspension geometry even further I'm sure the likes of QTEQ or 3Racing will fill the gap.
The main difference will be in roll centres. The standard F104 front end starts with a roll centre at ground level, but when cornering it will move up slightly but quite a bit from side to side. The TRF101 roll centre will be fixed at ground level, but it won't move as the chassis rolls. This should make the handling more consistent instead of the all or nothing grip of the standard F104 front end.
If you really think the tiny amount of camber gain is more important then get the F104v2.
terry.sc is offline   Reply With Quote
Old 05-30-2013, 08:27 AM   #125
WheelNut's Avatar
Send a message via MSN to WheelNut
Excellent post Terry.sc!
•Brad Comis
WheelNut is offline   Reply With Quote
Old 05-30-2013, 09:24 AM   #126
macavant's Avatar
Trader Rating: 58 (100%+)
I like your style - planning ahead.
likes the oldskool RC action...
F103.F201.F103GT.F1R3☆F104WGP.F1Ultra☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 05-30-2013, 09:26 AM   #127
I just pre-ordered one as well and was also wondering what electronics people would/will run.
merkyworks is offline   Reply With Quote
Old 05-30-2013, 09:30 AM   #128
macavant's Avatar
This is what I have lined up for my kit:
Rx: Spektrum 3520
servo: Savox 1251mg
ESC: Viper VTX1
motor: Viper 21.5T
Old 05-30-2013, 09:36 AM   #129
Mechintosh's Avatar
I am curently running a F104V2.
Spektrum Receiver
Futaba Servo
21.5 Trinity Rev-Tech
LRP SXX v2 ESC
CRC Shorty Lipo
Planning on moving this over to new car and will use silver can.
Xray T4-14,T4-15, X1
Pro Mini Truggy Mid Motor Mafia Xfactory
Serpent SRX4, 811 TE-e
Kyosho RB6, MP9e TKi
Mechintosh is offline   Reply With Quote
Old 05-30-2013, 09:41 AM   #130
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Thunderpower Z3-R 21.5 @ 30* timing, Hobbywing Justock ESC, Savox 1251 servo and 16 gauge wire. Gearing between 2.75 and 3.00.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 05-30-2013, 11:14 AM   #131
Trader Rating: 1068 (100%+)
The release date seems to be 6/21 in japan.
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 05-30-2013, 12:12 PM   #132
idbdoug's Avatar
Trader Rating: 33 (100%+)
Fantom D3.5 21.5 with 12.3 broadband rotor
idbdoug
idbdoug is offline   Reply With Quote
Old 05-31-2013, 09:01 PM   #133
HeliYogi's Avatar
Default LA -SFV Track F1 action this Sunday
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 06-03-2013, 02:24 PM   #134
theatriks's Avatar
only 19 more days .........
Old 06-03-2013, 02:25 PM   #135
theatriks's Avatar
I ordered my 2012 ferrari body ....and noticed the front clip is white....i want to paint it black...whats the best paint to use...can i get away with the tamiya ps paint or should i use there ts series paint?
SEO by vBSEO 3.5.0
