Like Tree1Likes
Old 03-11-2015, 01:37 AM   #1096
Anyone running a spur other than tamiya? If you do, can you share the # of teeth & the brand?
Stock one is too wobbly....
VBC f1 / MST 01 d pro /
I love this hobby!!
aackjw is offline   Reply With Quote
Old 03-11-2015, 02:46 AM   #1097
malcnz's Avatar
Good question and I would also like to know if any spur does the job as I know usually Tamiya run 3mm diff balls and can you run the slightly larger 3.2 imperial size as i have a few of those in ceramic and have a serpent spur thats the size i want to use.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 03-11-2015, 04:16 AM   #1098
Originally Posted by mtveten View Post
How is the lower ball held in on the new front end conversion? Is the upper ball still supported by the spring only or is it captive now?
The upper ball is still supported by the spring.
The lower is held in between the carbon arm which is shaped to the ball and the aluminium king pin end which is also shaped.
blue247carz is offline   Reply With Quote
Old 03-11-2015, 07:45 AM   #1099
sohlman's Avatar
Trader Rating: 89 (100%+)
Leespeed direct drive spur gears. Many options, even inner/outer width. http://www.leespeed-racing.com
It still wobbles a bit, but not more than any 1/12th scale i've ever owned.
Steve Sohl
sohlman is offline   Reply With Quote
Old 03-11-2015, 08:25 AM   #1100
JoJo1241's Avatar
It is supposed to wobble a bit, the diff plates squeeze the balls, not the gear, and therefore the spur gear wobbles.
If it does not wobble at all, the diff rings squeezes the gear, so no diff action.
I like Kimbrough gears 48 pitch
They use the 3,2 imperial size balls.
JoJo1241 is offline   Reply With Quote
Old 03-11-2015, 10:00 AM   #1101
banquer's Avatar
Yes, I do.
Exotek are so good and also Kinborough 64 pitch ones. 96 tooth.
Regards.
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 03-11-2015, 05:55 PM   #1102
Suspended
I seen some of the rules for uf1 they require the red blinky light for rain...where can i find one?
kongluc is offline   Reply With Quote
Old 03-11-2015, 08:11 PM   #1103
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Exotek all the way.
Only issue for me is the odd size diff balls.
Aside from that....They are my go to F1 spur.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 03-11-2015, 08:17 PM   #1104
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Tq racing has them, but I usually make my own.
I'm not sure what length wire TQ has, but I make mine with custom lengths.
RCBuddha is offline   Reply With Quote
Old 03-11-2015, 08:52 PM   #1105
Suspended
Thanks for the link...i was thinking it may need some kind of module
Old 03-11-2015, 09:43 PM   #1106
RCBuddha's Avatar
Nope! I'm in talks with a friend to make something like this with small LED's that will bolt into the Tamiya rear wing's 5mm hole:
On a side note: http://www.shapeways.com/product/XHS...ionId=56050499
Old 03-11-2015, 09:52 PM   #1107
Suspended
Is that a pic of the ones you make?
Old 03-11-2015, 09:57 PM   #1108
RCBuddha's Avatar
No, but it will be very similar.
Old 03-11-2015, 10:28 PM   #1109
Did you make the diffuser yourself too?
Looks great.
I love this hobby!!
Old 03-11-2015, 10:32 PM   #1110
RCBuddha's Avatar
Looks great.
No, that's a chevron piece, I am going to make the multi led brake light.
