Like Tree1Likes
Old 02-15-2015, 12:04 PM   #1066
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
The new front end looks like it will be 190mm.
Your other option is to run the standard F104 front end, which should be less than $20 in parts. It'll add a different feel to the car though, you may or may not like it.
What surface are you running it on? The TRF101W is notorious for having a much softer chassis than any of the other F1 that Tamiya has released in the past.
Dan is offline   Reply With Quote
Old 02-16-2015, 01:32 PM   #1067
Thanks for the reply, yes I thought it looked narrower than the one on mine but not sure if it would bolt straight on...
Im running indoor on carpet but may run it outdoor on asphalt in the summer.
blue247carz is offline   Reply With Quote
Old 02-16-2015, 01:50 PM   #1068
Actually on further inspection all the aluminium bulkheads and parts etc are the same as the 101W so all I would need is the carbon parts and the small plates that fit on the end of the wishbones which should be far cheaper to convert.
Old 02-17-2015, 07:20 AM   #1069
sohlman's Avatar
Trader Rating: 89 (100%+)
I have both the 101 and 101w. Front end (arms, king pin mounts, suspension mounts, etc.), chassis and battery plate are different parts. Kinda annoying to convert…I tried. Got expensive. Ended up buying another kit. Now I have plenty spares.
Steve Sohl
sohlman is offline   Reply With Quote
Old 02-17-2015, 07:20 PM   #1070
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Unfortunately the bulkhead and the servo mounts are not the same as either 101 or 101W.
Look closely.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 02-18-2015, 08:23 AM   #1071
CnR
CnR's Avatar
Trader Rating: 31 (100%+)
Super excited just picked up a Tamiya TRF101w !!! This is my first F1 I normally race off road but I always wanted one. Any tricks i should know about before the build ? this baby will probably be a shelf queen unless I move closer to an on road track. cant wait to get it built.
Upgrade-RC | Dialed-RC Hobbies | NitroHouse.com | Kal-Gard
CnR is offline   Reply With Quote
Old 02-19-2015, 01:24 AM   #1072
Will the new front suspension fit on a F104 ?
Gurneyflap is offline   Reply With Quote
Old 02-19-2015, 02:44 AM   #1073
Jorge T's Avatar
It should, the 104 front end fits on the 101. You will need the trf101 aluminum bulkhead too
RSD MS
Jorge T is offline   Reply With Quote
Old 02-19-2015, 01:08 PM   #1074
Thanks but I've been told the price....150 $.
Old 02-19-2015, 01:28 PM   #1075
is that the amount for converting or you found a kit with that price?
if its the latter, awesome!
VBC f1 / MST 01 d pro /
I love this hobby!!
aackjw is offline   Reply With Quote
Old 02-19-2015, 02:01 PM   #1076
Trader Rating: 70 (100%+)
street price looks to be just below $100. just to convert to the new front end.
Markus is offline   Reply With Quote
Old 02-19-2015, 02:56 PM   #1077
Dan
Dan's Avatar
Ouch, might as well wait for the new TRF coming out in 3-4 months going by typical new Tamiya F1 release timeframe.
Old 02-19-2015, 09:25 PM   #1078
100 for front converting is too steep for me.
I love this hobby!!
Old 03-08-2015, 12:40 PM   #1079
malcnz's Avatar
I know this has been touched on before but what bodies fit the TRF101W best..have cut out a streetjam body i have and fits ok but could be a bit wider in the very back to go over the side spring carbon bits but is there anything out there and prefer the older style of bodies and running the older style wings with foam 103 style foams that fits better?
Thanks.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 03-08-2015, 04:14 PM   #1080
Default Front shock placement
Has anyone tried to mount the front A-arm shocks on the bottom similar to the Way they are positioned in the F104 v2? If it's possible it would be much easier to adjust ride height with out using so many shims.
astgerma52sp is offline   Reply With Quote
