Old 12-08-2014, 06:47 PM   #1051
Punched's Avatar
Trader Rating: 46 (100%+)
Does anyone have any recommendations or links for basic information like setting droop, tweak, etc. for an F1? I'm primarily an off-road racer and am a bit lost on F1/Pan-Car setups.
Thanks in advance for your help!
Punched is offline   Reply With Quote
Old 12-09-2014, 01:36 AM   #1052
Ph3nyx's Avatar
http://rcf1.fr/index.php/les-chassis...tamiya-trf-101
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 12-24-2014, 07:51 AM   #1053
Evo 13's Avatar
What foam tires do you guys run on this car? I'm looking to widen the width of the car
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 12-26-2014, 11:05 AM   #1054
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
Does anyone know, what camber angles you get in both mounting possitions on TRF101W?
"If you no longer go for a gap that exists, you're no longer a racing driver"
Ayrton Senna
Acid_CZ is offline   Reply With Quote
Old 12-26-2014, 11:38 AM   #1055
NutDriver's Avatar
Trader Rating: 14 (100%+)
I'm looking for the blue aluminum upper arm mount for the front suspension (3454890) for a TRF101. I've looked high and low and can't seem to find anyone who has one in stock (TQRC Racing, Banzai Hobbies, RC Mart, etc). Any suggestions?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 12-28-2014, 04:04 PM   #1056
Default TRF 101 For Sale
Hey guys, My TRF 101 is up for sale if anyone is interested.
TRF101 can be seen here.
PremierRC - Timezone Raceway I and II - Schumacher Racing cars - EMRFactory.com
Robert Bakoczy is offline   Reply With Quote
Old 01-04-2015, 08:03 PM   #1057
Originally Posted by Carl Giordano View Post
Attached is my Jackson RC TCS wining Set-up using a TRF101. Used Ferrari F60 body and wing kit
Front:
- Stock Rubber Front tires, (not the TCS labeled brand)
- gold springs
- 5000 damper lube on kingpins
- offset trailing axle
- 5mm ride height
- middle hole on steering knuckle
Rear:
- TCS labeled tires
- yellow center spring
- 450 shock oil
- 10000 damper fluid on side damper
- gold side springs
- 4mm ride height
General:
- 35/96 gearing
- Reedy R1 21.5
- short battery in front
- Just Stock Speedo in rear
I hope this helps.
Good info. thanks
liftmys10 is offline   Reply With Quote
Old 01-28-2015, 09:46 AM   #1058
trf 101 front carbon suspension set
announced at Nuremberg toy fair, scroll down, they kill hotlinks
torg is offline   Reply With Quote
Old 01-28-2015, 03:37 PM   #1059
robk's Avatar
Trader Rating: 22 (100%+)
Looks like it's narrow (>190mm), is that right?
Old 01-28-2015, 05:30 PM   #1060
mtveten's Avatar
Trader Rating: 27 (100%+)
its defiantly different from the trf101 and 101w kits. It'll be interesting to see whats cars tcs will allow it on.
mtveten is offline   Reply With Quote
Old 01-29-2015, 06:53 PM   #1061
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Same top arm and ball mounts as the 101 right?
Looks like everything else is unique.
Aluminum front mount is one off as are the servo mounts.
Was hoping something from the W front end might be the same but it's not lookin like it thru my comparisons.
Not even using the newer 101W type aluminum ball mounts?
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-29-2015, 07:03 PM   #1062
mtveten's Avatar
The shape of the upper arms looks slightly different, the ball mounts do look the same though. The new servo and arm mounts appear to have a caster adjustment that wasnt present on previous versions.
Old 01-30-2015, 05:06 AM   #1063
Acid_CZ's Avatar
I would guess thats not caster setting but the new arm and servo mounts that will let you mount old or new upper arms for 101 (+new lower 101 arms) and 101w arms on same mounts so you can switch front width without servo and arm mount removal. Hope you understand what I mean.
Ayrton Senna
Old 02-14-2015, 03:34 PM   #1064
Default should I keep trf101w?
Hello
I recently got trf101w as a gift.
The problem is I have a vbc f1 kit already and tamiya one seems very similiar.
So my question is if I should keep it or sell it to get the other latest kit, which is likely to be xray one.
Looking forward your input on this.
Thank you.
aackjw is offline   Reply With Quote
Old 02-15-2015, 11:58 AM   #1065
Just bought my 1st F1 kit and opted for the TRF101W, I didn't realise that this kit was designed to perform with foam tyres, the car builds up lovely but the front end is massively wide. I have run it on the rubber ride F1 tyres and it seems to perform ok but I would like to run the front end narrower for better steering.
Does anyone know if I am best to sell the kit and buy a TRF101 kit or will this new item that was at the toy fair #42286 carbon front suspension set fit my car and make it 190mm?
blue247carz is offline   Reply With Quote
