Like Tree1Likes
Old 10-26-2014, 04:02 PM   #1036
Default Thanks Rob.
Originally Posted by robk View Post
Sand the diff rings with something like #400 paper. They should not be polished smooth, you want some tooth.
I still use Associated silicone lube (red lettering NOT stealth lube). Some guys use stuff like Tamiya a/w grease, but I personally feel like non silicone lubes change a lot during the run
Use a diff gear with a lot of balls. Kimbrough is 12, Zen has 16, and Exotek is 16 as well.
Rubber tires put a lot more stress on the diff, and its pretty hard to get 100% lock up.
Took the car to THE GATE to practice for the HALLOWEEN CLASSIC, I was just going to run USGT and VTA but the 101 was HOOKED UP so I will be running three classes at THE CLASSIC!!!!! Thanks for the help. Will se you at THE GATE...
TWILL is offline   Reply With Quote
Old 10-27-2014, 11:40 AM   #1037
banquer's Avatar
Hey guys!
Are expected a new TRF fórmula near?
Any rumours at respect?
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 10-27-2014, 11:42 AM   #1038
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
No, they just released the TRF101W this summer.
Probably expect the next one to be available next summer, 2015.
Dan is offline   Reply With Quote
Old 10-30-2014, 03:11 PM   #1039
malcnz's Avatar
Has anybody run the 101W and the serpent 110 back to back as considering both and currently struggle with rear grip and we run 200mm foams or we can run 180 rubbers etc over here on low grip asphalt and price works out similar by the time you add the widening kit for the serpent but the serpent is a little cheaper and has better parts back up but currently running the tamiya f104w gp and have found it very very strong.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 10-30-2014, 03:21 PM   #1040
Dan
Dan's Avatar
Whoa...cannot understand what you are saying. Punctuation is your friend.
Old 10-30-2014, 03:32 PM   #1041
malcnz's Avatar
lol..sorry about that...
Has anybody run the 101W and the serpent 110 back to back? as considering both and currently struggle with rear grip with my F104W GP. We run 200mm foams or we can run 180 rubbers etc over here on low grip asphalt.
Price works out similar by the time you add the widening kit for the serpent but the serpent is a little cheaper and has better parts back up.
Currently running the tamiya f104w gp and have found it very very strong so do like the tamiya f1s.
Old 10-30-2014, 04:00 PM   #1042
Originally Posted by TWILL View Post
I have the 101 and am running on carpet, I am using the otional TRF trust bearing and have turned around the coned washers. The issue I have is that when applying power no matter how hard I crank down the diff it seems to spin. What should I be using to lude the diff balls and is there any way to stiffen up the diff without locking it all the way up? I am running on indoor carpet and think the 101 is a good car,I just need to get the pop out of the corners. Thanks
I run my 101 at The Gate also. Last two weekends I had a similar experience. You could hear my car through the infield whirring away. I'll try those suggestions for the next race. Can't make the Classic , however.
ic-racer is offline   Reply With Quote
Old 11-03-2014, 06:32 PM   #1043
Trader Rating: 19 (100%+)
Does anyone know if the speed passion diff rings (SP000628) work on the TRF101 rear end. the tamiya ones are a pain to find and expensive!
Cheers
bee200sx is offline   Reply With Quote
Old 11-05-2014, 12:49 PM   #1044
MiTaller-RC's Avatar
Send a message via Skype™ to MiTaller-RC
Hi, I´m searching for a good "ruber base setup" for asphalt track (medium grip). Thanks for any info!
JQ WE - Alpha Lutz WE - Xpert Servos - AKA
Tekno EB48 - Tekin RX8 - AKA
_________________________
=> BIMA RACING TRACK <==
MiTaller-RC is offline   Reply With Quote
Old 11-07-2014, 09:11 AM   #1045
Carl Giordano's Avatar
Trader Rating: 20 (100%+)
Attached is my Jackson RC TCS wining Set-up using a TRF101. Used Ferrari F60 body and wing kit
Front:
- Stock Rubber Front tires, (not the TCS labeled brand)
- gold springs
- 5000 damper lube on kingpins
- offset trailing axle
- 5mm ride height
- middle hole on steering knuckle
Rear:
- TCS labeled tires
- yellow center spring
- 450 shock oil
- 10000 damper fluid on side damper
- gold side springs
- 4mm ride height
General:
- 35/96 gearing
- Reedy R1 21.5
- short battery in front
- Just Stock Speedo in rear
I hope this helps.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 11-09-2014, 07:42 PM   #1046
Just TQ'd and won the 2014 Timezone GP with my TRF101.
Gold front springs
1 mm shim under the front. No eclip under spring. This should make ride height 4 mm.
No front droop
TCS soft front tires
TCS hard rear tires
sliver side springs
60k damper tube fluid
4 mm rear ride height
Rear pod sagged .5 mm below ridea height.
Can't remember what spring and shock oil.
Esc mounted up front. Battery all the way back.
88 spur/33pinion
Novak 21.5
Lrp flow esc
This was a high bite indoor carpet setup.
It was the dominant car at the event. Current and past IIC champs were in the house running F1 as well.
PremierRC - Timezone Raceway I and II - Schumacher Racing cars - EMRFactory.com
Robert Bakoczy is offline   Reply With Quote
Old 11-09-2014, 08:57 PM   #1047
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Gold front springs
No front droop
TCS hard rear tires
sliver side springs
88 spur/33pinion
Novak 21.5
Lrp flow esc
I was pretty impress that your F1 is dialed .....it is good to see the Tamiya f1 won...Franko
hopefully will see his F1 on the track again..
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 11-10-2014, 09:34 AM   #1048
Thank you. It was a good battle and a fun weekend. Its probably the first time that my F1 was 100%. I had been running on a really old reedy wolfpack and worn out tires at previous events. Ran a fresh Turnigy roar approved battery and TCS tires.
Old 12-02-2014, 09:42 AM   #1049
I'm gonna keep coming through this thread but does anyone know if the TRF101 chassis plates will bolt up to a F104V2? I'm almost positive the front suspension and servo mount for the F104 will bolt right up, but will the F104 rear pod holes line up with the rear plate on the TRF101? Thanks in advance.
viking44 is offline   Reply With Quote
Old 12-02-2014, 10:06 AM   #1050
NVM found my answer. Wider pod on the TRF101.
