Old 04-15-2014, 08:46 PM   #946
FMW
FMW's Avatar
Originally Posted by robk View Post
So, the next question........
TCS legal for this year???
Really? Do we really need to ask that question? LOL
TRF101W legal
FMW is offline   Reply With Quote
Old 04-15-2014, 09:00 PM   #947
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
TRF101W legal
Fred,
You'll have to pardon Rob, I think he had an episode of Dave-ja-Vu
Where do we see a picture of this beast?
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 04-15-2014, 10:14 PM   #948
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
190mm width?
Dan is offline   Reply With Quote
Old 04-16-2014, 10:42 AM   #949
FMW
FMW's Avatar
I have pictures, but I can't make them public yet. We have an image EMBARGO for now.
190mm. The front end is wider than the previous 101. That I know for sure, but how much wider I do not know.
The rear uses the same parts as the first 101, so for now I'm presuming the front is wider compared to the rear for stability. More will be known shortly.
Old 04-17-2014, 06:33 AM   #950
Trader Rating: 25 (100%+)
Will it be legal for TCS this season?
Former RC fanatic just trying to keep up......
BSR Tires / Spektrum RC
Jamie Hanson is offline   Reply With Quote
Old 04-17-2014, 07:22 AM   #951
robk's Avatar
Trader Rating: 22 (100%+)
TRF101W legal
Its all good !
Old 04-17-2014, 05:46 PM   #952
Anyone else have difficulty with the carbon axle and diff? It seems they are permanently glued together. I took a hit and it loosened it and then the tire always wobbled. I could not fix it, even with re-gluing. So I went for a totally new metal axle and diff.
I still have the original axle and diff. Any way to fix it?
ic-racer is offline   Reply With Quote
Old 04-18-2014, 09:47 AM   #953
Dan
Dan's Avatar
It has probably fractured inside, causing the wobble.
I actually bent mines after a pretty bad cartwheel just two weeks ago. The only part I've broken on my TRF in about a dozen races. Too bad instead of replacing a shaft, I had to buy the whole assembly. ~$35
Old 04-24-2014, 04:03 AM   #954
TRF101W cad pic here
http://www.thercracer.com/2014/04/42...first-cad.html
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 04-24-2014, 06:55 AM   #955
subaru73's Avatar
Trader Rating: 41 (100%+)
Default Trf101
Quick question what effect does moving the side links in or out on the chassis have on the car.
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 04-24-2014, 06:56 AM   #956
subaru73's Avatar
Default Trf 101
Originally Posted by Qatmix View Post
Very interesting espicelly the front end will be nice to see the real pictures
Old 04-26-2014, 06:45 PM   #957
Hey guys, very few that run this car @ my club and we are looking for pointers.
first thing, have you ever found that you needed to balance shimizu rubber once glued? I am getting a wicked wobble at 3/4 throttle. I think this might be causing my abrupt on power changes of direction. Everything is fine coming out of the corner, then snap hard 90 deg into the wall, no warning, either direction. No tweak, which is what I thought at first. Car is straight, no issues, but now I notice the imbalance on the bench at 3/4 throttle.
Also, silver front springs, car is good, but gold if I nick a barrier, susp balls pop out. Is there an easy fix for this? Silver 4.5mm ht, gold 5.5mm ht. Is it that the shaft travels further up allowing the ball to be pried free?
Anyone had these issues and how did you resolve them?
Darryl
dman18t is offline   Reply With Quote
Old 04-27-2014, 01:50 PM   #958
shadowracer24's Avatar
I had that issue with mine using the thin insert in the tire. Fixed it by gluing the ends of the insert together and then use two sided tape to attach to the inside of the tire. Stopped the wobble in mine. Unfortunately the issue with the kingpin seems to be a common problem with this car and have not found a fix for that yet.
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 04-29-2014, 01:17 PM   #959
I balanced them and it's a lot better. I also moved my wires to give more pod movement. The wires were just barely touching the body. So now that the tires aren't wobbling, I'm hoping that the car will be more consistent.
Nobody has figured out the susp. balls? There must be a way to stop this from happening. Maybe if I've fixed the handling problems, I won't hit the wall and it won't be a problem having them pop out.
Anybody else have any tips?
Darryl
Old 05-02-2014, 01:10 PM   #960
http://www.thercracer.com/2014/05/la...-cad-pics.html
Colour Cad pic here of the TRF101W, not more detail than the original pic other than its colour so you can spot which bits are aluminium etc
