Like Tree1Likes
Old 11-25-2013, 06:58 PM   #886
Trader Rating: 17 (100%+)
Or turn them opposite
Team Schumacher USA
meddman is offline   Reply With Quote
Old 11-25-2013, 09:05 PM   #887
aloksatoor's Avatar
Trader Rating: 42 (100%+)
http://www3.towerhobbies.com/cgi-bin...?&I=LXVRA3&P=7
Not sure if it will make the diff smoother but felt its better than having a regular bearing in there.
So for the regular bearing the manual says ( ) for the spring washers, with this part you gotta do ) (. I also put a dab of bfast thrust grease on sides of the bearing before installation.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 11-25-2013, 09:44 PM   #888
Typeone's Avatar
Trader Rating: 30 (100%+)
Anyone the size of the thrust bearing I want to replace it with a Avid thrust bearing.
TRF101/Tamiya F104-V2/ TRF Tamiya 417/ Smokem FX chassis & V7 conversion/ Speed Passion/ Sweep Racing/ Futaba/ SMC
Typeone is offline   Reply With Quote
Old 11-25-2013, 11:54 PM   #889
-jacob-'s Avatar
so i stripped my stock spur gear that came with my 101. anyone here know what other spur gear would fit the 101?
Thank you
www.teameamotorsports.com
www.seattlercracers.com
-jacob- is offline   Reply With Quote
Old 11-26-2013, 05:52 AM   #890
subaru73's Avatar
Trader Rating: 41 (100%+)
Default Trf 101
Thank you
I use kimbrogh spur gears on any other manufactor spur gear wil work.
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 11-26-2013, 04:19 PM   #891
Alok....what springs are you running on the front. Shock oil in shock. Any other adjustments u can think of.
Team Schumacher USA
Old 11-26-2013, 04:37 PM   #892
aloksatoor's Avatar
Medium gold springs for the fronts. If spinning out then blacks in front
Ride height around 5 for front chassis and 4.5 for rear (I have the tuning Haus 0.5 block to get it exactly 5mm rear pod)
Running 350 oil in damper with blue spring (softer of the two in the kit) 3 hole kit piston
Link springs outermost of the 3 options with gold (medium spring). The outermost allows chassis a roll a bit and not be as twitchy
I have also done the front axle trailing change but not put it on track yet. Supposed to smooth her out more. Shorty servo as forward as possible for max ackerman effect.
Most important pit tires front soft rear med. There are no others which work at our track (except yokomos which are the same make but rare to find). Also check how much preload you have on the center damper, should have some give.
Another thing I had to do was reduce pod droop otherwise with full droop was undrivable off power. I made the pod droop to 1.5. If I am not mistaken, all other things being equal, a black oring and a 2mm limiter inside your center damper should bring droop to around 1.5. But check anyways.
Heres a tutorial to do it scroll to the droop section http://www.tamiyausa.com/articles/f1...e#.UpU-R8RDtQY
Must have upgrades are the carbon links from tamiya but they are always backordered so grab some when they come up ,
Good to have upgrades are
http://www.tqrcracing.com/shop/produ....asp?p_id=6436
http://www.tqrcracing.com/shop/produ....asp?p_id=7056 for ride height the kit comes with 0,1 and 2 offset I got the 0.5 as well.
And that thrust bearing.
Old 11-28-2013, 01:57 AM   #893
dcuz383's Avatar
Default My First F1 Build
Here is my first F1 build.
TRF101-imag2269.jpg   TRF101-imag2270.jpg   TRF101-imag2271.jpg   TRF101-imag2272.jpg
I would probably hate me too!
dcuz383 is offline   Reply With Quote
Old 11-28-2013, 06:47 AM   #894
subaru73's Avatar
Default Trf 101
Welcome to the trf 101 nice build
Old 11-29-2013, 11:26 AM   #895
When installing the f103 thrust bearing into the trf 101. What does the thrust bearing replace in the assembly, the spur adapter? Or does it replace the bearing next to the conical washers. It also has the longer diff spacer do I use that or the original one. Lastly I was told if installing the trust bearing that the disk springs go backwards, true?
Team Schumacher USA
Old 11-29-2013, 08:12 PM   #896
Anybody?
Team Schumacher USA
Old 11-29-2013, 09:52 PM   #897
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
The one piece thrust bearing replaces the bearing in the diff hub that sits behind the cone washers, and yes the small ends of the cone washers should face each other
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 12-01-2013, 02:23 PM   #898
Drove my TRF101 for the second time in a race and the car was once again very smooth and constant.
Drove the fastest lap time of the day but the guys with a ver.II are not that much slower, the second fastest time was 0,03 seconds slower.
Even with a less powerfull motor (comparing to the other guys) i was able to take TQ and the overall win of today.
2 times i finished second and 2 wins out of 4 races and still 3 more races to compete to be hopefully the overall season winner.
I have high hopes
addicted2blue is offline   Reply With Quote
Old 12-12-2013, 08:54 PM   #899
spring71's Avatar
Smile
New Tunning Haus TRF101 upgrades are available.
http://www.tqrcracing.com/shop/produ...id=95&s_sort=3
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
[email protected]
spring71 is offline   Reply With Quote
Old 12-14-2013, 07:19 AM   #900
ZZracing's Avatar
Send a message via Skype™ to ZZracing
ZZracing Titanium screws /Hobby Wing /Savox /Nvaracing / Star racing/Novarossi/Sanwa/Castle/Xcore/Yeah Racing/Tianhao UFO/Q-World/Venom/Orion/Sky Rc
Email:[email protected] [email protected]
www.rzhobby.com www.zzracing.net
ZZracing is offline   Reply With Quote
