Like Tree1Likes
Old 11-21-2013, 08:53 PM   #871
Csaari77's Avatar
Trader Rating: 34 (100%+)
Originally Posted by hanulec View Post
anyone know which part number i need to get BC15? it is the ball socket mounted on the upper carbon plate - Tamiya (3404021)
http://www.petitrc.com/reglages/tami...101_Manual.pdf
Pg11
Also, BA13 looks out of stock. Tamiya (19808245)
BA13 comes in a set with the upper and lower balls. The part number is 54161.
BA15, the upper plate that holds the ball in carbon arms, is part number 42252.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 11-22-2013, 02:58 AM   #872
hanulec's Avatar
Trader Rating: 27 (100%+)
42252 Is the car kit. Gotta come in a less expensive bundle...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-22-2013, 03:22 AM   #873
godzukihop's Avatar
Trader Rating: 31 (100%+)
http://www.tqrcracing.com/shop/produ...eyword=9804735
ALSO
http://www.tamiyausa.com/product/rcp...2#.Uo8-lsSUSNB
JOHN's MOBILE RACEWAY | 180 RACEWAY | Jackson RC Track
Murnan Modified because HP is intoxicating!!! | VP RACE FUEL |
G-FORCE HOBBIES | Fordham Hobbies | ASHFORD HOBBY | TEAM CAMDEN
RC AMERICA / XRAY / HUDY / TEAM POWERS
godzukihop is offline   Reply With Quote
Old 11-22-2013, 06:51 AM   #874
Trader Rating: 114 (100%+)
Default Tamiya Aluminum Pitch Damper Set RM-01 for TRF101
Does anyone have a spare Tamiya Aluminum Pitch Damper Set RM-01, Tamiya part # 54341, they would be willing to sell?
I have the TRF damper on my TRF101, but wanted to try out the smaller damper as well. I had good luck with that part on the F104v2 and it helps reduce CG over the TRF style damper. I know a few people swapped over to the TRF shock as it is easier to set up, so I figure they may be a few laying around.
PM or email with any details.
Erik
http://store01.prostores.com/servlet/whipracing_bluescrews/StoreFront
ewippler is offline   Reply With Quote
Old 11-22-2013, 06:56 AM   #875
MiTaller-RC's Avatar
Send a message via Skype™ to MiTaller-RC
Hi, What about this Kit? I just want to try F1 class but can't find this chassis available.
Maybe is better to start with F104 v2 pro?
Thanks for the info.
JQ WE - Alpha Lutz WE - Xpert Servos - AKA
Tekno EB48 - Tekin RX8 - AKA
_________________________
=> BIMA RACING TRACK <==
MiTaller-RC is offline   Reply With Quote
Old 11-24-2013, 06:00 PM   #876
mingnon's Avatar
Hi all, picking the brains trust
Have been running the kit setup for about 5 weeks. No major crashes or general "out of control" issues. Track is flat, med grip, not bumpy, medium kerbs (Painted so tend to stay off them).
Have had to replace lower front arm (51381) as it keeps pushing out the lower ball (51461) out, has happened 4 times so far. It never occurs on the same side and at different times.
Have always replaced with new lower/upper ball and new lower arm. Checked the kingpin/shaft (54335) and they are true/straight, and have also replaced them as well just to be sure.
Anyone else having this issue? and any ways you solved it. Have had the F1 gurus at the track suss it out, with no luck.
mingnon is offline   Reply With Quote
Old 11-24-2013, 07:59 PM   #877
Trader Rating: 17 (100%+)
Having big issue with rear end coming loose under any power.
Team Schumacher USA
meddman is offline   Reply With Quote
Old 11-24-2013, 08:12 PM   #878
aussierevo's Avatar
Trader Rating: 14 (100%+)
I had this exact same issue with my TRF101 and I gave up trying in the end. This never happened to me once in racing 3 years for F104, but happened too often with this car. I think because of the stiffness of the upper graphite arm, it doesn't allow much play, so small touches on barriers or rubbing wheels with another car cause this when on the normal F104 such impacts didn't have the same result.
I gave up using the front end of the TRF 101 as it cost me race wins and installed the exotek on the front. It is a simply changeover and since doing that I've not had problem free runs with the front end. And the exotek allows such more changes to camber and caster that I think it's really the only option for the front of the car.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 11-24-2013, 08:44 PM   #879
i'd make sure your diff isn't too tight , loose , also check the tweek on the car.. and chk your front wheel bearings . might have some binding ..
Mark Barden .
mb racer is online now   Reply With Quote
Old 11-24-2013, 08:47 PM   #880
mingnon's Avatar
Hmmm, thats what i thought may have to do.
Really appreciate the quick reply
Cheers
Matt B
Old 11-24-2013, 11:36 PM   #881
rack's Avatar
Trader Rating: 64 (100%+)
I know it is on the forum some were but I need to ask. What is the beswt F1 tires for around 60deg f asphalt track with med bite.
rack is offline   Reply With Quote
Old 11-25-2013, 01:27 PM   #882
wondering what other's are using for the 2 top screws on the front upper arm . longer screws or dirffrent screws . they seem to back off and cause unwanted flex in the front end .during a run ...
Mark Barden .
Old 11-25-2013, 05:39 PM   #883
What are most of you setting the diff at?
Team Schumacher USA
Old 11-25-2013, 05:54 PM   #884
aloksatoor's Avatar
Trader Rating: 42 (100%+)
As loose as possible @diff without slipping. If you crumpled up the spring washers then replace.
I also have the f103 thrust bearing in it Steve. You will need to swap the spring washers for it to work. Glad you got the 101 .
ALso on Dans suggestion, got 1/8 balls and a precision racing or a robinson spur instead of the tamiya spur so you can use regular ceramic balls and 64 pinions.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 11-25-2013, 06:57 PM   #885
Thanks bro. So the 103 thrust bearing replaces the conical washers?
Team Schumacher USA
