Like Tree1Likes
Old 11-03-2013, 08:24 PM   #841
godzukihop's Avatar
Trader Rating: 31 (100%+)
Anyone have a complete set up sheet for carpet? My car feels good, would just like to try and get it better.
JOHN's MOBILE RACEWAY | 180 RACEWAY | Jackson RC Track
Murnan Modified because HP is intoxicating!!! | VP RACE FUEL |
G-FORCE HOBBIES | Fordham Hobbies | ASHFORD HOBBY | TEAM CAMDEN
RC AMERICA / XRAY / HUDY / TEAM POWERS
godzukihop is offline   Reply With Quote
Old 11-07-2013, 07:21 AM   #842
godzukihop's Avatar
No one?
Old 11-07-2013, 07:27 AM   #843
Csaari77's Avatar
Trader Rating: 34 (100%+)
I'm not sure why this thread has died. With carpet season here you would think there would be more people running this car and sharing setups.
I've only run mine 2 times and I'm still fighting an on power push. I'm going to try widening the side links and loosening the screws on the front arms. Does anyone else have any other suggestions? The setup is pretty much stock with Pit/TCS tires on med grip carpet.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 11-07-2013, 08:40 AM   #844
Ph3nyx's Avatar
you can try less camber and less caster setup (i'm not sure if the trf101 has a caster setting)
you can stiffen the lateral damper too
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 11-07-2013, 07:29 PM   #845
godzukihop's Avatar
Please let me know how it works for you. I have the same issue with a push on power. Off power perfect, on power not so perfect.
Old 11-08-2013, 11:44 AM   #846
Typeone's Avatar
Trader Rating: 30 (100%+)
for asphalt racing what shock oil should i use also, would 40wt be ok and what spring should i use and also on the friction damper how thick should the oil be. Tuning Haus has 50k, 75k, 100k. i run on med to high grip asphalt.
TRF101/Tamiya F104-V2/ TRF Tamiya 417/ Smokem FX chassis & V7 conversion/ Speed Passion/ Sweep Racing/ Futaba/ SMC
Typeone is offline   Reply With Quote
Old 11-08-2013, 11:48 AM   #847
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Are the reissue rumors legit?
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 11-08-2013, 12:18 PM   #848
Csaari77's Avatar
It was confirmed by TamiyaUSA a few weeks ago.
Old 11-08-2013, 01:11 PM   #849
shadowracer24's Avatar
The tracks I run here are not what you would call high bite more med but I have mine setup with silver springs on the front and side pod with 35wgt oil in the shock with the tamiya red spring, 10,000 diff oil on the dampner and the springs set touching plus two turns tension. 571f and 572r pit tires with 4mm ride height. I have the links setup middle on the chassis and inside on the pod. the car is on rails for me with this setup. Hope that helps ya out. Also moved the side springs to the outside hole.
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 11-08-2013, 04:11 PM   #850
Typeone's Avatar
ok thank a lot ima try it by chance what motor and spur/pinion are u running?? Y is it that most people run the tamiya red shock spring?
Old 11-08-2013, 05:23 PM   #851
Trader Rating: 27 (100%+)
I got the new "TAMIYA Pro101".
JoeyE is offline   Reply With Quote
Old 11-09-2013, 10:19 AM   #852
Typeone's Avatar
Does anybody put weight in the front of the 101??
Old 11-09-2013, 11:04 AM   #853
Ph3nyx's Avatar
Where did you get the front parts ?
Old 11-09-2013, 12:53 PM   #854
You can find those front parts from TQrcracing.com
addicted2blue is offline   Reply With Quote
Old 11-09-2013, 03:38 PM   #855
Typeone's Avatar
Has anybody tried the Sweeps F1 tires on the TRF101 I have the pits 571/572's and what compounds for outdoor asphalt also with racing going into the winter.
