Like Tree1Likes
Old 07-26-2013, 02:00 AM   #541
Meilleur's Avatar
Trader Rating: 20 (95%+)
For all you diehard Tamiya fans to add to your collection:
Meilleur is offline   Reply With Quote
Old 07-26-2013, 05:50 AM   #542
volracer's Avatar
Send a message via ICQ to volracer
Originally Posted by Autocratic View Post
Just got done something some maintenance, and noticed my diff housing is bent. I've actually had some bad wheel vibration since I built the kit but thought it was tires. Even after balancing the right rear tire has a bad vibration. The side of the diff that is bad is pinned to the shaft.
Any chance getting Tamiya USA to replace the shaft/housing? Or am I out of luck and need to buy a whole new assembly?
Side note, also checked Tamiya USA site again, and it does say camber adjustment 1.5/2.5, but that's just bogus. With the mark on the inside I'm right at 1.5. Outside is barely a 1/2 degree, which was actually wearing the outside of the tire and leaving the inside still shiny after several runs.
I noticed a wobble in my diff housing when I spin it. I am going to check the bearings and how they are seated and the cone washers. Was yours caused by the axle or the piece where the wheel is attached.
I also had a graphite pod plate that only had three of the four holes countersunk.
volracer is offline   Reply With Quote
Old 07-26-2013, 06:30 AM   #543
FL_SilverEvo8's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to FL_SilverEvo8
What gear ratio are must of you running for outdoor?
Off-Road - Durango:DEX210R(2wd Buggy), DESC210R(2wd SCT), DESC410R(4wd SCT)
On-Road - CRC: Gen-X 10 LE(WGT), X-Ray:T3 2011(VTA), X-Ray:T2 009(USGT) TRF 101(F-1), AE: RC10R5.1(Spec17.5)
Jeff's RC Studio Video>> http://www.youtube.com/watch?v=WtZ8-TV8Fs8&feature=share
FL_SilverEvo8 is offline   Reply With Quote
Old 07-26-2013, 07:34 AM   #544
Trader Rating: 30 (100%+)
2.4 with Pit's
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 07-26-2013, 07:55 AM   #545
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
88/30 with TCS tires
Dan is offline   Reply With Quote
Old 07-26-2013, 08:01 AM   #546
Autocratic's Avatar
Trader Rating: 26 (100%+)
The housing that is pinned to the driveshaft is bent. It's definitely not straight.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 07-26-2013, 08:56 AM   #547
Hi guys,
Can I use F104 Ver2 Lower deck and rear pod as a replacement for TRF101? Since there is no parts yet for them except those titanium screws.
squalleonde is offline   Reply With Quote
Old 07-28-2013, 09:41 AM   #548
Autocratic's Avatar
What's the part number for the carbon driveshaft assembly? I no longer think it's the same as the RM01X car.
According to the manual it says #42252, and the RM01X shaft is #54427
Can anyone confirm? Will the RM01X shaft work as a replacement?
Old 07-28-2013, 09:44 AM   #549
Does anyone have a good base setup for Rubber Tire on Carpet? I am hoping to run at IIC this fall, so I will most likely be running Pardus tires up until then.
puhrot is offline   Reply With Quote
Old 07-28-2013, 07:15 PM   #550
I ran my 101 today. The car was great out there on foams and rubber. The only problem I am having is that it is real darty. What can I do to tame this down? I hear that more caster would fix it. Can we add caster to this 101? I was looking at it. It really doesn't look like we can.
Old 07-28-2013, 07:19 PM   #551
aussierevo's Avatar
if you built it as per manual, then you will have had the front axles in-line. To help tame down the front I moved the axle to the offset position and it helped a lot.
I do race on a flowing track where this helps. I understand the front hole position is better for tight technical tracks.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is online now   Reply With Quote
Old 07-28-2013, 07:34 PM   #552
aussierevo's Avatar
maybe even play a little with radio settings to help calm it down a bit.
Speed Passion F1.
Old 07-28-2013, 08:05 PM   #553
I did this. (S/R is turned down)
Now for the front of the car the only thing I did was put shims and spacers in there so I could have the ride hight at like 5mm.
Old 07-28-2013, 08:06 PM   #554
What do you mean by this? Could you show me a picture of your f-1?
Old 07-28-2013, 08:18 PM   #555
aussierevo's Avatar
if you go to the rear of your manual, you'll find it will make reference to the front axle position on page 17.
sorry, I'm about to board a plane so can't load a picture, but the manual covers what can be done which may help.
http://www.petitrc.com/reglages/tami...101_Manual.pdf
Speed Passion F1.
