Like Tree1Likes
Old 07-22-2013, 12:55 PM   #511
edhchoe's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Autocratic View Post
I don't think so.
The 101 diff housing is pinned to the carbon shaft, so it's not a direct replacement.
Curious though, how did you break the shaft?
Well. I did hit the curb twice on the left side at the end of the straight, a high speed right hand turn. Some sort of protection material on the curb would have been nice. I named it "the money turn". I broke the upper front arm on my F104v2 at the same turn yesterday. So I broke two cars and ended up making a hybrid out of f104v2 and trf101.
Next week I plan to make a hybrid of f104w gp rear and trf101 front.
edhchoe is offline   Reply With Quote
Old 07-22-2013, 01:02 PM   #512
I was told by Rc champ that this was a one off production run and there was no more stock for the forseable future. Although as stated if there is enough demand then they will make another batch.
Are spares available for them yet? Such as the car on rear shaft?
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 07-22-2013, 01:44 PM   #513
FMW
FMW's Avatar
I can't speak for other markets around the world, but Tamiya America has stock of the TRF101. Our wholesale partners have been purchasing this item for over 3 weeks.
The TRF101 is a "limited-edition" racing kit. It says so on the box and it's marketed that way.
Will more be made after the production run has been completely sold out will depend on current market conditions and demand.
RE: Parts for the TRF101. Spare parts for the TRF101 will arrive at Tamiya USA's warehouse in about 4-5 weeks from today. This includes high wear items.
FMW is offline   Reply With Quote
Old 07-22-2013, 02:09 PM   #514
Ed the RM and the 101 as pointed out use slightly different axles. The rear diff race is thinner and the inner spur race is a different diameter.
If you want a pic pm me your mobile and ill send you one
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 07-22-2013, 03:14 PM   #515
edhchoe's Avatar
Thanks. I am replacing the axle with a steel axle and f104 diff housing.
Old 07-22-2013, 06:37 PM   #516
Autocratic's Avatar
Trader Rating: 26 (100%+)
What's the kit front camber supposed to be? I'm needing more camber and I'm only reading 1 with the slot on the inside. Also, has anyone figured out how to get more camber with the kit blocks?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 07-22-2013, 06:40 PM   #517
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Flip them the other side so the indent is facing the outside. I forget how much more camber. Heard -1.5 or -2.5?? Someone correct me...
Dan is offline   Reply With Quote
Old 07-22-2013, 07:32 PM   #518
Autocratic's Avatar
I just swapped them and it's -1.5
Old 07-23-2013, 03:31 PM   #519
F1Jet's Avatar
[QUOTE=FMW;12372119]I can't speak for other markets around the world, but Tamiya America has stock of the TRF101. Our wholesale partners have been purchasing this item for over 3 weeks.
QUOTE]
Anybody seen a TRF101 kit listed for sale? All the sites I checked had the kit out of stock.
F1Jet is offline   Reply With Quote
Old 07-23-2013, 07:23 PM   #520
Trader Rating: 14 (100%+)
Does anyone know if this will work on the TRF101?
http://www.tqrcracing.com/shop/produ...id=2976#images
Or maybe a better question is if this is even needed? What width is this car with Rubber tires?
puhrot is offline   Reply With Quote
Old 07-23-2013, 07:32 PM   #521
PhilippineEagle's Avatar
you do not need any hop ups for the TRF101 kit... except for alloy twist nuts (thumb screw) battery holders (optional). http://www.tqrcracing.com/shop/produ....asp?p_id=3596
The width of the car is 190mm.
1:10 Tamiya TRF101, Turnigy Trackstar 17.5, Toro TS120
1:12 Tacon Thriller
PhilippineEagle is offline   Reply With Quote
Old 07-23-2013, 07:44 PM   #522
edhchoe's Avatar
My TRF101 is missing the rear axle right now, so I can't measure the rear but the front end measures 183mm.
Old 07-24-2013, 05:41 AM   #523
aussierevo's Avatar
another night of racing and I'm pleased with how the car is shaping up. I had a question around cornering. In fast sweepers the car handles really well, but in chicanes/s bends it doesn't like to go left right left very quickly, it hates the quick change of directions.
I didn't get much of a chance to try anything to correct, but to honest, I don't know where to start.
I'm currently running the silver springs on the rear, 30 wt oil rear with red spring. track is low traction/bumpy. Tires are Shimizu 572 rear and 573 front in night temps of 16 deg cel.
would appreciate any thoughts on what might help make it transition smoother
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 07-24-2013, 06:16 AM   #524
Ph3nyx's Avatar
If you are using the tamiya servo saver , you can start to change it for a better one (kimbrough for exemple)
you can also raise the rear position of the central damper
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 07-24-2013, 07:52 AM   #525
Not according to the website
http://www.tamiyausa.com/product/ite...oduct-id=42252
And as has been pointed out no one seems to have them in stock anywhere.
terry.sc is offline   Reply With Quote
