Old 07-11-2013, 07:21 PM   #451
rtypec's Avatar
Originally Posted by robk View Post
Dude, it's Masami. That was straight murder. And it would have been the same with aTRF car.
Was that on foam or rubber? Maximum fast. Huge speed. If rubber...I quit!
rtypec is offline   Reply With Quote
Old 07-11-2013, 07:25 PM   #452
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
https://www.youtube.com/user/waigoleaks?feature=watch
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-11-2013, 08:38 PM   #453
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Masami is still king!
Dan is offline   Reply With Quote
Old 07-11-2013, 09:02 PM   #454
bhambrent's Avatar
Yes he is!
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 07-12-2013, 03:53 AM   #455
badboy's Avatar
Trader Rating: 14 (100%+)
Default Build Question
Hi.
Would like to ask if there are any special points of attention when building this kit. I'll be starting mine this weekend and I just want to make sure that I get it right.
Thanks.
badboy is offline   Reply With Quote
Old 07-12-2013, 05:12 AM   #456
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Originally Posted by RedBullFiXX View Post
That is also a 200mm Foam car with Masami at the wheel
No doubt the YRF is a pretty slick F1 though
I know someone who was there when he was running , foams, and mod, I think I heard 5.5 mentioned
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 07-12-2013, 06:56 AM   #457
Originally Posted by badboy View Post
Hi.
Thanks.
Not really, enjoy the build as its up to Tamiya's usual standards.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 07-12-2013, 08:06 AM   #458
theatriks's Avatar
Originally Posted by squalleonde View Post
Have anyone compared YRF001 and TRF101 performance? Coz Masami drove YRF001 so fast like driving a TC. Check this video http://m.youtube.com/#/watch?v=g7EaQ...%3Dg7EaQ3eBKZ4
^^^video no worky worky
Mod Mod Mod...I love Mod.....and scotch!
theatriks is offline   Reply With Quote
Old 07-12-2013, 08:33 AM   #459
Trader Rating: 23 (100%+)
http://www.youtube.com/watch?v=g7EaQ...%3Dg7EaQ3eBKZ4
There you go.
Former RC fanatic just trying to keep up......
BSR Tires / Spektrum RC
Jamie Hanson is offline   Reply With Quote
Old 07-12-2013, 10:12 AM   #460
Man that guy FLYS
Wish the camera guy would have just zoomed out instead of trying to follow the car, makes it hard to see how fast the car is going through chicane.
merkyworks is offline   Reply With Quote
Old 07-13-2013, 11:40 AM   #461
Dan
Dan's Avatar
What sort of handling characteristics change from moving the side links from the most narrow position to the most wide?
Old 07-13-2013, 02:07 PM   #462
macavant's Avatar
Trader Rating: 58 (100%+)
Thumbs up TRF101 first run : great results
Had a chance to run the TRF101 @ the track for the first time. Setup is derived from kit build, with black springs, 400cst oil in the main damper.
Tires are [used] Pit571/572 no traction compound cleaned with SimpleGreen. It worked really well with the 571/572 combo, and should yield similar results with the TCS setup.
Mechanical grip on this kit is outstanding. Steering is precise and stable on the straights.
The only kit change made towards the end of the day was to change the car to silver springs and add a touch of drag brake to the ESC to increase initial turn in.
Compared to my F1R (with 2.5mm flex chassis), the 101 is easier to drive and throttle can be applied earlier out of the turns. Compared to my F104WGP (Pit541/545), steering was less on black and gold springs - on par with silver.
Rear grip is better than both (used the same exact wheels/tires on the F1R) when I did back to back runs.
I let my bro-in-law drive it, and he has 0 time driving F1 cars (just 4wd short course and TC) and he found it "fun and as a surprise - easy to drive".
Short clip of test runs:
+ YouTube Video
likes the oldskool RC action...
F103.F201.F103GT.F1R3☆F104WGP.F1Ultra☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 07-13-2013, 02:46 PM   #463
theatriks's Avatar
+ YouTube Video
Asphalt or carpet ? Phone won't play the vid.
Old 07-13-2013, 02:51 PM   #464
RonF's Avatar
+ YouTube Video
What camera is used for the onboard view? Nice action. good quality.
VBR,
Ron
F104pro, Turnigy Turbo 80amp, 21.5 trackstar, LRP esc and Rs 540
RC10 original, RC10 graphite, RC10 4wd MIP SP1 version, RC10T
RonF is offline   Reply With Quote
Old 07-13-2013, 05:53 PM   #465
macavant's Avatar
Asphalt. NorCal Hobbies in Union City, CA
Changed the syndication settings - hope that helps to play the vid on ur device.
Thanks. GoPro Hero3 black edition.
cam car rig is a TA05 running a 10.5T with boost:
SEO by vBSEO 3.5.0
