Like Tree1Likes
Old 07-05-2013, 05:29 PM   #406
PhilippineEagle's Avatar
Originally Posted by subaru73 View Post
Here is mine big thanks to Dan at Speedwerkes
Nice. What tire and rim combo are you using?
1:10 Tamiya TRF101, Turnigy Trackstar 17.5, Toro TS120
1:12 Tacon Thriller
PhilippineEagle is offline   Reply With Quote
Old 07-05-2013, 05:37 PM   #407
subaru73's Avatar
Trader Rating: 41 (100%+)
Default Trf101
Using Tamiya tcs tires and Tamiya f104 foam rims
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 07-05-2013, 06:28 PM   #408
rtypec's Avatar
Default TRF 101 MP4-24
Electronics installed and body finished. Ready to wreck
rtypec is offline   Reply With Quote
Old 07-05-2013, 06:53 PM   #409
DayDAY's Avatar
rtypec, This is awesome !!! I like it...
I notice you placed the battery in the middle, does it better as I have placed my battery at the rear.
DayDAY is offline   Reply With Quote
Old 07-05-2013, 07:06 PM   #410
DayDAY's Avatar
My TRF101 body
Old 07-05-2013, 07:19 PM   #411
Rtype: I like your battery forward set up. It's making me second think mine.
This is my first build in 20+ years and have no experience in F1.
The previous prebuilt and used kits I got, I eventually disposed because I knew I wanted to build something from scratch.
I am just wondering which set up would be better for indoor asphalt, medium to high temperature (Philippine tropical climate)... Battery forward or battery back?
I already know the answer is to try both set ups and see for myself... But I also don't really want to have to re-wire (re-solder) connections as much as possible.
1:12 Tacon Thriller
Old 07-05-2013, 07:25 PM   #412
DayDAY's Avatar
Old 07-05-2013, 08:04 PM   #413
rtypec's Avatar
Default Battery Forward
To be honest, I basically copied electronics installation with the battery in the forward position from FMW, RedbullFixx, and Vyger. I haven't run the 101 yet but my V2 on asphalt with the same electronics layout has been pretty quick. I'm in the same boat as you, it'll take a lot of work to move electronics around...so I'll just run it as is since ignorance is bliss haha
Old 07-05-2013, 08:07 PM   #414
Travis S's Avatar
Trader Rating: 46 (100%+)
Even though it isn't as "clean" looking; Mounting the speedo on the side like your receiver will give you the option to move the battery forward, back, and mid for easy change setup options based on the track conditions.
Travis S is offline   Reply With Quote
Old 07-05-2013, 08:36 PM   #415
I'm a little OC and paranoid about the ESC not "fitting perfectly" on the side. My concern would be the ESC getting damaged in a crash because it would be "hanging/exposed". I have little faith in the shell protecting the ESC.
As it stands now, my Futaba R2104 GF receiver is slightly overhanging from the carbon fiber chassis. I am considering getting the R204GF-E just for the smaller case.
1:12 Tacon Thriller
Old 07-06-2013, 02:56 AM   #416
I've added an editable set-up sheet for the TRF101 here
http://www.thercracer.com/p/community.html
Also Manual here
http://www.thercracer.com/p/manuals.html
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 07-06-2013, 03:40 AM   #417
Qatmix: thank you for sharing the set up sheet. I downloaded it and will use it next week.
1:12 Tacon Thriller
Old 07-06-2013, 02:58 PM   #418
http://www.petitrc.com/reglages/tami...iyaTRF101.html
Arn0 is offline   Reply With Quote
Old 07-06-2013, 03:02 PM   #419
Manual now available from Tamiya
http://www.tamiya.com/japan/download/rcmanual/42252.pdf
terry.sc is offline   Reply With Quote
Old 07-06-2013, 05:02 PM   #420
This is how I got my front end ride height to 5mm with standard Tamiya rubber front tires. Basically I just added an extra 2mm all the way around. I used extra spacers left over from various Tamiya kits I had built. I believe this is the same as depicted in post #271.
ic-racer is offline   Reply With Quote
