Old 07-03-2013, 10:38 AM   #376
FL_SilverEvo8's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to FL_SilverEvo8
Originally Posted by terry.sc View Post
When the chassis starts to spin out the gyro will counter steer for you. If the chassis starts to spin when either turning into a corner or when wheels spin coming out of the corner depending on how you have set up the gyro it will correct the steering so will help keep it on line. It means you can run softer front tyres for more steering grip for faster cornering without worrying about the car spinning out.
here's a good demonstration http://www.youtube.com/watch?v=90dQlBmfV2I
Wouldn't this be the same as the HPI D-Box?
http://www.hpiracing.com/products/en/80588/
Off-Road - Durango:DEX210R(2wd Buggy), DESC210R(2wd SCT), DESC410R(4wd SCT)
On-Road - CRC: Gen-X 10 LE(WGT), X-Ray:T3 2011(VTA), X-Ray:T2 009(USGT) TRF 101(F-1), AE: RC10R5.1(Spec17.5)
Jeff's RC Studio Video>> http://www.youtube.com/watch?v=WtZ8-TV8Fs8&feature=share
FL_SilverEvo8 is offline   Reply With Quote
Old 07-03-2013, 12:44 PM   #377
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Good points
Something else we noted when a few drivers snuck them into their F1's
F1 Gyro drivers can plow into other cars, without much risk of loosing time
One can imagine the type of racing this leads to...
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-03-2013, 02:20 PM   #378
celt's Avatar
Originally Posted by RedBullFiXX View Post
Good points
I've seen guys do that as well, try to get away with a gyro....
Simply don't understand it. Isn't it more challenging and rewarding to actually "drive" the car yourself?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-03-2013, 02:49 PM   #379
All the HPI D-Box is, is a Futaba G190 helicopter gyro at double the price.
terry.sc is offline   Reply With Quote
Old 07-03-2013, 02:57 PM   #380
So how is this car over all? Is it hard to set up? Does it push a lot? Does it over rotated? Is this car made for more asphalt or carpet? What tire works best on this car Rubber or foam? I see that it is more durable than most kits out there. I have a VBC Flash-04 and was thinking about getting this kit. Reason being because of the durably and every time I take out my VBC the arms break most of the time. Have any of you compered this kit with any others out there? Like the VBC one.
Old 07-03-2013, 02:58 PM   #381
Cool
Fezzik: We face each other as God intended. Sportsmanlike. No tricks, no weapons, skill against skill alone.
Old 07-03-2013, 03:08 PM   #382
robk's Avatar
Trader Rating: 22 (100%+)
Inconceivable!!
Old 07-03-2013, 03:13 PM   #383
edhchoe's Avatar
Trader Rating: 41 (100%+)
Arms won't break every time on TRF101. F104v2 was a very durable chassis and trf101 is more so. TRF101 felt better than F104v2 overall.
It worked well with pit shimizu 573 f and 572 r for me on the asphalt track.
IMO, there is no better f1 kit out there right now that will perform like this out of box.
edhchoe is offline   Reply With Quote
Old 07-03-2013, 03:42 PM   #384
It depends on whether they are allowed or not. In the mid 90s when we raced F1, especially on our damp and cold UK tracks, there wasn't any rule banning gyros. When you are racing on low grip tracks against cars with perfectly legal gyros saying it is better to "drive" it yourself isn't going to get you any extra laps.
The gyros were just a tuning aid, if the grip was good enough it was better to remove the gyro as you have more control, if it was slippery you added the gyro to help you get around. It was strange to drive as you didn't feel in full control, much like the way a boosted ESC will take over the throttle for you when it kicks in.
And sticking a gyro in doesn't just let the car drive itself, if you are spinning out every corner you will still spin out with a gyro. You can't just throw a chassis down with whatever setup and expect the gyro to control it so it drives around on rails, it just doesn't happen. The chassis still needs to be set up and you still need to drive it properly, the difference is you can dial in a bit more front end grip for a gyro.
Old 07-03-2013, 05:23 PM   #385
My first F1! Managed to install all the electronics and build the kit 1/3 faster than touring car. Applied my touring knowledge a bit coz the principal somewhat similar.
Now need to cut my Ferrari 2012 body. Will post soon.
squalleonde is offline   Reply With Quote
Old 07-03-2013, 07:11 PM   #386
DayDAY's Avatar
Thumbs down
Originally Posted by merkyworks View Post
So use O-rings where the red and/or green circles are?
That's a good point for tuning the car, you can adjust the stiffness of the front by steps. I found some springs with different strengths from my Mini-Z and will try them out this Sun, I will put it in the middle where the RED circle is, will let you know how it runs.
DayDAY is offline   Reply With Quote
Old 07-03-2013, 07:34 PM   #387
DayDAY's Avatar
I have one Esky headlock gyro and have try it on my TRF101, I wired the signal cable to AUX and sucessfully tuned the headlock mode with min gain, but when I put it on the ground and test run it, it just turn when it wanted to. Can you post some set up of the AUX... ( I am using a Spectrum DS3S) thank you.
Old 07-03-2013, 07:48 PM   #388
Super Moderator
Grizzbob's Avatar
Good points
You mean like Short Course trucks? j/k
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 07-04-2013, 10:36 AM   #389
policeman0077's Avatar
if trf101 front would sell separately, so i can mount trf101 front end on my x1 lol
多情自古伤离别。更那堪、冷落清秋节。
policeman0077 is offline   Reply With Quote
Old 07-04-2013, 11:30 AM   #390
edhchoe's Avatar
Yes but it will be expensive.
You will need :
King pin, Center mount, new servo mounts(they are taller), king pin holders, upper arm.
My guess for total cost would be 12, 25,28, 15, 20 = $100.
I left out the aluminum spacers which you can probably replace with plastic ones.
