Old 06-28-2013, 06:30 PM   #331
edhchoe's Avatar
Trader Rating: 41 (100%+)
Here you go.
TQ RC racing.
edhchoe is offline   Reply With Quote
Old 06-28-2013, 06:33 PM   #332
DayDAY's Avatar
Originally Posted by terry.sc View Post
When the chassis starts to spin out the gyro will counter steer for you. If the chassis starts to spin when either turning into a corner or when wheels spin coming out of the corner depending on how you have set up the gyro it will correct the steering so will help keep it on line. It means you can run softer front tyres for more steering grip for faster cornering without worrying about the car spinning out.
here's a good demonstration http://www.youtube.com/watch?v=90dQlBmfV2I
Do the gyros from helicopter work with rc cars?? thanks.
DayDAY is offline   Reply With Quote
Old 06-28-2013, 06:45 PM   #333
DayDAY's Avatar
Originally Posted by edhchoe View Post
Here you go.
TQ RC racing.
Thanks, I'll check this out.
Old 06-28-2013, 07:14 PM   #334
mtveten's Avatar
Trader Rating: 27 (100%+)
Those long screws are a pain in the butt when I need to change camber or front height.
I get to find out tomorrow if trf101 will out run my f104v2.
The real question is if it will be faster than the gp. So far my t- bar car has been a couple of tenths faster at every other nw track.
mtveten is offline   Reply With Quote
Old 06-28-2013, 07:21 PM   #335
edhchoe's Avatar
I hope it is but I bet it won't be. There is so little difference between f104v2 and TRF101 fundamentally. IMO, TRF101 is just an eye candy.
Old 06-28-2013, 07:59 PM   #336
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Originally Posted by DayDAY View Post
Got it, thanks for all the comments from you guys, in conclusion, I will take the 24t pinion from the kit and test run for few minutes then check the motor temp. if it is not more than 160f then I can go for higer tooth. Any idea about the highest range of tooth I should get, 33t?
Any one can answer the question from "merkyworks" above in regards to the cooling fan, do I need to put the fan for the esc or better place it at the motor...... OR just leave it, thank you.
If you gear between 2.75 and 3.0 with moderate timing the car should be quick and depending on motor and tire diameter the temps should be in the 130-150 range which is more than safe. At that point fans are an option
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 06-28-2013, 08:30 PM   #337
DayDAY's Avatar
Hi Shadow, your word make me feel more agressive now, what about the Lipos, I only got one pc of 4200mah 45C for test purpose as shown in the attachment, any suggestion for better performance and matching with my esc and motor, of course longer time better, a long one or the short one... always greedy on the playing time. Thanks
Old 06-28-2013, 09:12 PM   #338
BP SHADOW's Avatar
We have these
http://f1paintlab.mybigcommerce.com/...0c-short-lipo/
and they run really strong
http://f1rclab.com
Old 06-28-2013, 09:16 PM   #339
PhilippineEagle's Avatar
That is a great battery for a great price!!! Then again, all your items have to keep up with your top notch services.
1:10 Tamiya TRF101, Turnigy Trackstar 17.5, Toro TS120
1:12 Tacon Thriller
PhilippineEagle is offline   Reply With Quote
Old 06-29-2013, 06:14 AM   #340
Gyros are the same, whether they are sold for helicopters or cars. In fact the HPI D-Box is just a rebadged Futaba G190 heli gyro. Just be aware that lots of organisations do not allow gyros for racing.
terry.sc is offline   Reply With Quote
Old 06-29-2013, 01:25 PM   #341
Trader Rating: 18 (100%+)
My front ride height doesn't seem to be as bad as others. I'm at 5mm with the silver springs.
Speaking of production issues though, my kingpin mount doesn't seem to be threaded all the way through. This is the farthest I can get the screw in before it starts to strip.
viet is offline   Reply With Quote
Old 06-29-2013, 03:45 PM   #342
miles514's Avatar
A little OT here,
I have here a F104Wgp which I converted to 190 width and I love it! Im just waiting for the TRF 101 front end conversion kit so I can have the taste of 101 on my Wgp. I really love the rear suspension of my Wgp, simple effective and can survive some crashes. I also cut some parts of my top deck to have an easy access for my shorty
AE SC10 FT, RC10 Worlds Car, 3Racing Cactus, HPI Rally, Tamiya MF01X Jimny, Tamiya M05 Pro V2, Tamiya group C, Wild Willy 2, CC-01 Bronco, F103 Le Mans, F104Wgp, Subaru Brat, Wild One, Sand Scorcher.
miles514 is offline   Reply With Quote
Old 06-29-2013, 10:19 PM   #343
edhchoe's Avatar
Raced my TRF101 today and I liked it a lot.
I made many bad moves but that was because the car's speed and handling gave me too much confidence. My f104v2 might not get any more run time.
I am driving the yellow car. (There were at least 3 other TRF's at the race today including Difuser's which TQ'd.)
+ YouTube Video
Old 06-30-2013, 05:04 AM   #344
DayDAY's Avatar
Finally, I got all the wire done..... please comment. I'm also thinking of putting a gyro on it, where should I plug in the signal.
Old 06-30-2013, 05:43 AM   #345
+ YouTube Video
That's reassuring to know that you are running it on asphalt. I was worried that the TRF101 was designed specifically for carpet.
Could you share some pictures and details of your set up? I would like to know if you are using a full length battery or shorty. And where you placed your electronics to balance the weight.
I start my build tomorrow.
1:12 Tacon Thriller
