Old 06-27-2013, 07:09 PM   #316
GMartinez's Avatar
Trader Rating: 83 (100%+)
http://www.superiorhobbies.com/store...S/F1+RACE+CARS
Just saw today they have 4 in stock & told me the price was going to be adjusted so if your in need I would call them directly
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup
2014 Hosted Events Roar Paved Electric Nationals, IFMAR ISTC Worlds
2015 Roar Fuel On Road Nationals,U.S.World Nitro Cup Completed
2016 U.S. World Nitro Cup Dec 7th - Dec 11th
GMartinez is offline   Reply With Quote
Old 06-27-2013, 08:21 PM   #317
edhchoe's Avatar
Trader Rating: 41 (100%+)
So the camber settings are -0.5 and -2.1 according to my measurements.
I suspect tamiya will release -1.5 and -2.5 king pin mounts in the future.
edhchoe is offline   Reply With Quote
Old 06-27-2013, 08:32 PM   #318
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
I have 2 of them inbound for $329.99+ shipping.
Should be here Monday at the latest.
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 06-27-2013, 09:44 PM   #319
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Finally got mine ready to rock and roll for Golden State Championship race this weekend. Looking forward to seeing how it will do!
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 06-27-2013, 11:01 PM   #320
DayDAY's Avatar
My one is almost finish... only waiting for wiring and electric setup.
Need some advise from you guys, since I am new to electronic cars, I dunno what is best pinion for the motor.. the one comes with the kit is 24gear. I am running a 17.5T motor and a Hobbywing Xtreme Stock ESC (60A). Thank you.
DayDAY is offline   Reply With Quote
Old 06-28-2013, 09:03 AM   #321
edhchoe's Avatar
I normally use 21.5t motor and run 2.8-3.0 fdr.
96 spur and 24 pinion is 4.0 fdr. I would start with that and if the motor temp is ok I would use bigger pinion.
Old 06-28-2013, 09:04 AM   #322
theatriks's Avatar
You know what dude just try the pinion and spur that came in the kit ...run the car for a couple minutes only then check the temp...you dont want that motor to go beyond 160 f.....after a couple minutes if the motor isnt that hot run the car for a 5 minute run and check the temp if it still isnt that hot go up a tooth on your pinion and go from there....just never let the motor temp go beyond 160f
Mod Mod Mod...I love Mod.....and scotch!
theatriks is offline   Reply With Quote
Old 06-28-2013, 10:18 AM   #323
JayL's Avatar
You can run the F104 entire front end, right? Be curious which front end is faster
Don't get the UF1RC guys started about gyro's
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 06-28-2013, 11:04 AM   #324
Trader Rating: 18 (100%+)
I think it would just require the f104 servo mounts to fit. Pretty sure these mounts are taller.
viet is offline   Reply With Quote
Old 06-28-2013, 11:46 AM   #325
edhchoe's Avatar
Those long screws are a pain in the butt when I need to change camber or front height.
I get to find out tomorrow if trf101 will out run my f104v2.
Old 06-28-2013, 01:44 PM   #326
do you really need to run a fan on the ESC for these cars?
merkyworks is offline   Reply With Quote
Old 06-28-2013, 05:37 PM   #327
Originally Posted by tommy911t View Post
Does anyone recognize the esc and motor in this photo?
-Tommy
Motor is Tamiyas Formula Tuned, a 32T brushed motor that's used as the standard motor in Tamiya F1 races in Japan.
terry.sc is offline   Reply With Quote
Old 06-28-2013, 06:21 PM   #328
Originally Posted by Autocratic View Post
It's the same parts tree.
As for the gyro, I know what it does, but what purpose would it serve on our F1's?
When the chassis starts to spin out the gyro will counter steer for you. If the chassis starts to spin when either turning into a corner or when wheels spin coming out of the corner depending on how you have set up the gyro it will correct the steering so will help keep it on line. It means you can run softer front tyres for more steering grip for faster cornering without worrying about the car spinning out.
here's a good demonstration http://www.youtube.com/watch?v=90dQlBmfV2I
Old 06-28-2013, 06:25 PM   #329
DayDAY's Avatar
Got it, thanks for all the comments from you guys, in conclusion, I will take the 24t pinion from the kit and test run for few minutes then check the motor temp. if it is not more than 160f then I can go for higer tooth. Any idea about the highest range of tooth I should get, 33t?
Any one can answer the question from "merkyworks" above in regards to the cooling fan, do I need to put the fan for the esc or better place it at the motor...... OR just leave it, thank you.
Old 06-28-2013, 06:27 PM   #330
It depends on the ESC used, but unless you go for a really cheap 25-35A rated ESC then there's no need for a fan.
