Like Tree1Likes
Old 06-25-2013, 01:04 PM   #271
Got the front to 5mm this way. Now just gotta get to track and start testing...
[RC10TC] is offline   Reply With Quote
Old 06-25-2013, 01:10 PM   #272
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by InspGadgt View Post
Later versions of the F103 had the spring below the arm and the upper arm did not move either. You just need a long enough king pin and the steering knuckle has to be affixed to the king pin either with e-clips on top and bottom or a set screw.
Perhaps with enough pin ...
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-25-2013, 05:12 PM   #273
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by aussierevo View Post
car was setup as per manual except I used 2000wt diff oil in roll damper and first run noticed the rear would step out. Changed the side springs from silver to gold and the car was a lot better thru the sweepers. Used Shimizu 571 front and 575 rear and car TQ'd the 2 x 8min heats. Car if anything had some mid corner understeer.
Made a couple of changes for the 15min final and must say car wasn't as good. Went to Shimizu 572 rear and soft grease in roll damper and car just wouldn't rotate and kept skipping sideways. Admittedly, I could hear diff slipping from the drivers stand so that was not ideal.
To be honest I would go back to the 575 rears. It may be all tires, did you ever try the 574 front?
One other thing that might help would be going back to the silver side spring but preload it at least 1 full turn. That will help stabilize the car, but it will still roll and maybe help your mid corner.
robk is online now   Reply With Quote
Old 06-25-2013, 05:30 PM   #274
mtveten's Avatar
Trader Rating: 27 (100%+)
rc10tc By increasing the total shim stack like that preloading the spring you would have eliminated all the up-travel that is likely to cause the front end to bounce with a notchy feel.
InspGadgt
The trf kingpins are long enough to place the springs below but the upper arm suspensions balls are not captive and rely on the springs to keep them in place.
mtveten is offline   Reply With Quote
Old 06-25-2013, 05:33 PM   #275
edhchoe's Avatar
Trader Rating: 41 (100%+)
Shorter springs maybe the answer.
edhchoe is offline   Reply With Quote
Old 06-25-2013, 05:49 PM   #276
rtypec's Avatar
Default TRF 101 Build - Steps 12-16
Steps 12-16 completed
rtypec is offline   Reply With Quote
Old 06-25-2013, 05:57 PM   #277
rtypec's Avatar
Default TRF 101 Build - Steps 17-19
Steps 17-19 completed
Notes:
  • Applied a small amount of loctite to all hardware attached to uprights.
  • Replaced the silver 3x3mm grub screws with shorter black grub screws. This allows the 3x5mm low profile screw to fully set and not get scratched by the silver grub screw.
  • This might be overkill, but I applied a small amount of Loctite to the 2x6mm screws that attach the king pin mounts to the front upper arm.
Close up of front suspension
Another close up of front suspension
Old 06-25-2013, 06:05 PM   #278
rtypec's Avatar
Default TRF 101 Build - Steps 20-25
Steps 20-25 completed
Notes:
  • 3.5mm along with an o-ring were used in the pitch damper. I rebuilt the shock 4 times to get rear droop to be slightly below level with 3mm spacers under the middle brace's ball connector.
  • Tamiya soft friction damper grease was used on the roll damper.
Close up of chassis center
That pretty much covers the chassis build.
I still need to install electronics and prepare a body for this chassis...which will probably take a while
Old 06-25-2013, 06:12 PM   #279
CraigM's Avatar
awesome shots!
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-25-2013, 06:16 PM   #280
edhchoe's Avatar
Tamiya should provide rtypec a new car to do this for every new release.
Old 06-25-2013, 06:28 PM   #281
Trader Rating: 18 (100%+)
I still can't believe those are from a point-and-shoot.
viet is offline   Reply With Quote
Old 06-25-2013, 06:32 PM   #282
Autocratic's Avatar
Trader Rating: 26 (100%+)
Originally Posted by viet View Post
I can't believe those are from a point-and-shoot.
Amazing what a proper light box does for pictures.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 06-25-2013, 06:32 PM   #283
robk's Avatar
Originally Posted by rtypec View Post
[*]This might be overkill, but I applied a small amount of Loctite to the 2x6mm screws that attach the king pin mounts to the front upper arm.[/LIST]
I never used so much loctite until I started running rubber tire F1 cars....
Great build posts!!!
Old 06-25-2013, 06:47 PM   #284
rtypec's Avatar
Canon ghetto-cam taken from my iPhone.
The camera kinda sucks but Photoshop doesn't
It's a $0.32 piece of poster board
Old 06-25-2013, 08:00 PM   #285
mtveten, I raised the front arms the same amount as the spacer so the spring is not being pre-loaded
