Old 01-10-2014, 07:03 PM   #601
theproffesor's Avatar
Trader Rating: 45 (100%+)
Ok so I could hook something similar to the old deans bulb bar to the power side of the charger along with the power supply and it would discharge at the higher amperage?
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 01-10-2014, 07:09 PM   #602
Super Moderator
It goes in series with the RC battery (not on the power supply side). Check out page 18 of the manual.
If you want more help we need to know your battery size, 1S, 2S, etc, and discharge amperage target (20A?). And the resistance of the bulbs. Might need some tweaking too due to the typical resistance change of light bulbs as they heat up.
Dave H is offline   Reply With Quote
Old 01-10-2014, 07:18 PM   #603
jwmustang's Avatar
Originally Posted by Obsidian View Post
What is a typical storage voltage for a Lipo?
around 65 percent
Spectrum Pro, RC8BE, B44,T8TE, MP9e tki3
jwmustang is offline   Reply With Quote
Old 01-10-2014, 07:20 PM   #604
Jerz616's Avatar
Trader Rating: 49 (100%+)
About 3.7v-3.8v per cell
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 01-10-2014, 07:29 PM   #605
Trader Rating: 22 (100%+)
3.75 - 3.85 Volts per cell. I usually go for 3.8v and it is really important that the pack is in balance as well.
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 06-23-2014, 08:07 PM   #606
Does anyone know if there's a icharger 4010 duo thread?
Goldfish is offline   Reply With Quote
Old 06-23-2014, 08:13 PM   #607
Jerz616's Avatar
I haven't seen a dedicated 4010 thread but there is a 308 and 406 in the radio I and electronics forum. They are mostly the same chargers aside of the charging amps and cell allowance. So you could prob ask questions in one of those.
Ryan Gracey
XRAY XB8'14
Old 06-23-2014, 08:56 PM   #608
Thank you
Old 06-24-2014, 04:24 AM   #609
d16dcoe45's Avatar
Originally Posted by EAMotorsports View Post
The ONLY thing that charging at higher amps will do is: Charge the battery faster, cut down on the life of the pack (from 300 cycles to 200 cycles maybe all speculation), and it will warm the pack internally which will decrease IR and increase voltage. But with all the big races checking battery temp it will not help as it wont pass tech.
The heat is the only reason it increases the voltage and lowers IR. If you let the pack cool to room temp and check it it will be the same as if you charged it at 5 amps. I have yet to see a charger that has any special voodoo built in that will charge and make a battery faster without using heat.
Ive been charging at 40 amps since December with the ICharger Duo 4010 came out. I raced every week all the way up till the birds. I only keep two packs to my name at a time. I practice and race on those two packs every week in TC. Those packs are still good today as they were new in December. The 40 amps thus far has not shown any ill effects at all. Generally when I go to the track its 4-5 charges per pack per day. There were some 3 day races in there too.
The pack I won the birds with was charged at 40 amps every single charge. I used it in both 17.5 and 13.5 TC all week in every practice and every race. Then I sent it to Josh Cyrul and he did the same with it in Modified and 13.5 sedan which he won both classes. That battery was put through hell and still cycles the same as it did when it was new a week before the birds.
The key to keeping batteries fresh is USING THEM! And making sure they dont sit with a full charge or zero charge in them. Not being used is a Lipo's worst enemy I have found.
EA
Eric, what packs are these robust monsters you speak of?
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 06-24-2014, 06:55 AM   #610
speeddaddy's Avatar
Here is a dedicated 4010 on RcGroups site
http://www.rcgroups.com/forums/showthread.php?t=1801512
If you can't fix it with a hammer, you've got an electrical problem.
RC Sailboat, 3RC planes, SC5m, Yuneec Typhoon Quadcopter
speeddaddy is offline   Reply With Quote
Old 06-24-2014, 07:40 AM   #611
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
Batteries? Ive done it with mine and the ORCA packs. Never any issues and always perform!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 08-15-2014, 02:17 AM   #612
Michael_T's Avatar
Trader Rating: 47 (100%+)
Send a message via MSN to Michael_T
Slightly off topic, being an electric novice, can anyone recommend charger settings, I have a team much more hybrid pro.
The batteries are Orca 1s 3.7v 6800mah (12th scale)
It charges a max 10 amp, which is what I plan to use, but what about all the other settings I need to set in the charger (voltage, peak, etc)
Also, reading this thread, should I charge it to 3.8v then store it?
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 08-15-2014, 05:02 AM   #613
Bishop's Avatar
Charger, or any good LiPo charger, should have all the right settings out of the box, choose your amps and cell count, and charge, LiPo is easy.
For storage, or inbetween meets, most chargers have a "storage' mode, which is like 50-75% charge, usually the idea is to not storage the pack either flat or full, as either is hardest on the cells, you should avoid flattening a LiPo as well, if your hitting the lipo cutoff on yours esc, it's not great for the packs.
Oh and try and make sure your packs get used or cycled (like at least once a month if your not racing), they actually loose some punch from not being used regularly.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-15-2014, 05:43 PM   #614
Mr RCTech's Avatar
Reality:
Time for a new charger...
You need a charger to charge a lipo battery a min of 30 amps to have
the benefits of lower IR and higher voltage.
If not, your already at a disadvantage at a big race.
I always store lipos at 3.8 per cell.
Mr RCTech is offline   Reply With Quote
Old 08-16-2014, 04:34 AM   #615
What is the IR if charged at 10A and 30A.
frozenpod is offline   Reply With Quote
SEO by vBSEO 3.5.0
