Who charging 20+ amps or more now??
#586
EA- I can't find the unit you're using. Do you have a link?
#590
Looks right, thanks. They have several nice toys I could use.
#591
ICharger
308DUO or 4010DUO
308DUO or 4010DUO
#593
I was wondering why everyone is using external dumpers?
Are you just trying to avoiding putting heat in the charger?
#594
I am OK with discharging at 6 or so amps but I get it, after a race day getting home at 10 or later being able to discharge to storage voltage quickly would be nice.
It doesn't take hours but it takes 10 -15 minutes per pack to get to storage if their still full so I may be 45 to 60 minutes till I can crash out.
I don't like leaving packs outside of storage voltage for long so most of the time I put them on storage when I get home..
#596
Try it on a fully (or close) charged pack. You may have been close to storage voltage already so it didn't get to a high amperage discharge rate.
With my PowerLab even if I set it to 10a I will only see 6 or so amps when just using the charger itself. To get more than that I would need to hook up to a car battery for a regenerative discharge.
#597
The 206B is limited to 20 watts of discharge power on it's own. Need to set up a regenerative or external discharge to get any higher.
#599
Regenerative is when you use a large enough not fully charged lead acid (auto) battery (or multiples) for the power source, and the charger basically runs in reverse, discharges the RC battery into the lead acid(s). 206B can go to 300 watts that way.
External uses a properly sized external resistor bank, maybe a light bulb setup, etc, to dissipate the energy. Can get to 500W.
