Old 11-24-2013, 12:05 PM   #556
Trader Rating: 59 (100%+)
Originally Posted by Mr RCTech View Post
It dumps all the power to the load.
I hooked up the input line straight to the load and hookup a volt meter.
Works great.
If you want to add more load just solder .47 ohm resistors inside.
I used it for a one cell - Integy 30 amps.
For two cell I would use the Integy 20 amp.
If you have the 30a discharger plugged in and select a 20a discharge, does the charger limit the load, or does it end up 30a and just monitors the voltage?
MC112b is offline   Reply With Quote
Old 11-24-2013, 06:31 PM   #557
Mr RCTech's Avatar
It's simple.
Just a 30 amp load and I monitor the voltage with a volt meter.
Mr RCTech is offline   Reply With Quote
Old 11-24-2013, 07:07 PM   #558
Send a message via AIM to A-Ko
I got tired of baby-sitting my batteries with bulbs/volt meter, and bought a Tekin Dis-350.
It does resistance and up to 30 amps.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 11-24-2013, 07:13 PM   #559
It's simple.
We all might be on different pages? Forgive my ignorance. So it sounds like you are using a modified integy reactor as a stand alone unit, and not connecting it to a junsi 308d on regenerative discharge?
Sean B. is offline   Reply With Quote
Old 11-25-2013, 08:56 AM   #560
I'm in the same boat. I have been reading a thread dedicated to the 4010 & 308. I 99% sure we could. We set the maximum parameters in the charger and it works inside those. Us 1s or 2s battery users won't have any issues with the 30a Reactor. The wattage never really adds up. The 6s-10s flyers have issues with getting enough watt dissipation.
Old 11-25-2013, 05:40 PM   #561
I'm certain we could. I want to do like this YouTube video, except on a much smaller scale.
http://m.youtube.com/watch?v=L6Q_Ze6NC2g
Seems like the reactor would work, just need to pull the "brains" out of it.
Old 11-25-2013, 11:24 PM   #562
Microtome's Avatar
Default Thanks for the info
To be more specific, scroll down to page 20 in the manual....
http://www.progressiverc.com/media/i...o%20Manual.pdf
Thanks MC112b, I took a minute to read through the section you called out. It also mentions a "Lithium Battery Extra Discharge Mode" on page 39. Where you place a load in the positive side between the battery and charger.
Or just get one of these:
http://www.ebay.com/itm/iNTEGY-INDI-...item1e7a2be20c
Thanks Mr RCTech, just ordered it on ebay.
www.GoodentiteRacing.com
Microtome is offline   Reply With Quote
Old 11-26-2013, 01:03 AM   #563
Microtome's Avatar
Default Dammit I'm up way too late
All this talk is making want to trade the PL8 in on a 308.
Bah! I'm up way too late. I think sleep deprivation impairs my judgement. You were right I couldn't wait any longer.
I just ordered the 308 Duo from BuddyRC and added the free ParaBoard. Besides the best way to learn is by doing.
Thanks guys I greatly appreciate all of the comments, tips, and info.
Old 11-26-2013, 12:41 PM   #564
I haven't taken mine apart yet, but I plan to bypass the switch/cutoff misc parts. Obviously I hope to keep the fan working. I'm not expecting it to be too big of deal.
Old 11-26-2013, 05:14 PM   #565
Microtome's Avatar
Does this work with the 308D! I've been thinking of making something exactly like that, but haven't gotten around to figuring out the details. One detail I haven't been able to find yet is if you are using regenerative discharge, does the charger draw power (around 10.7A for a 2 cell) as well as dumping power to the load? Or does it dump all power to the load?
Looks like you "Might" be able to do it both ways. Or actually three total.
1. Standard discharge 80watt max
2. Regen discharge
a. To input(car battery, or deep cycle)
b. To Channel(dump power to load connected to other channel
c. To Channel charge other battery(supposed to be a function added in future update.)
3. Lipo Extended Discharge(found on page 38,39.) This uses a combo of standard discharge PLUS a load connected to positive lead between battery and charger.
I believe with all of these methods it uses constant amp until Target voltage is reached then switched to constant voltage and balancing cell voltages until complete.
FINE PRINT: This is how I read and understand the manual. I will try each once I have the charger. If anything differs I will edit and or delete post to prevent spread of false info.
Old 11-26-2013, 05:55 PM   #566
That's the way I'm understanding it. I will likely use the dump thru other channel into external load method mostly to keep the heat out of it. The Indy reactors are pretty cheap. I'd rather burn them up.
Old 01-07-2014, 07:39 AM   #567
dirt42fan's Avatar
Trader Rating: 135 (100%+)
Hello
I just got a iCharger 4010 Duo. Love it so far and I want to learn more. I have a couple questions I am hoping some of you experts can help me with
1. Internal Resistance. What are the good numbers I need to be looking for on the charger? What is bad? I run 2s and 4s LiPo packs.
2. External Temp sensor. I did not get one with the charger and cannot seem to find them online. Can someone send me a link to them? And they are for LiPo right?
Thanks in advance for your help!
"Never apologize for hard racing" Scott Bloomquist
dirt42fan is offline   Reply With Quote
Old 01-07-2014, 03:59 PM   #568
On I.R., zero/cell is perfect, over 20/cell time to toss it.
Johnnysplits is offline   Reply With Quote
Old 01-07-2014, 04:02 PM   #569
Suspended
Originally Posted by dirt42fan View Post
Hello
I get I.R. readings on my fastest 2s shorty packs around 1 to 1.5
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 01-08-2014, 09:19 AM   #570
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
To get a higher amp discharge you can plug a classic Deans light bulb discharger into the second charge port and do a "regenerative discharge." Pretty slick actually.
Have you done this to see if it actually works? Ive wondered about doing it but didnt want to take a chance on one of my Ichargers! LOL
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
