Old 11-11-2013, 05:45 PM   #526
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally Posted by asc6000 View Post
Having a 2nd battery would be even more convenient.
+1 LOL
Racing4Evo is offline   Reply With Quote
Old 11-15-2013, 03:48 PM   #527
Send a message via ICQ to JiuHaWong
Default A New High Power contender emerges?
http://www.amainhobbies.com/product_...r-6S-40A-1000W
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 11-20-2013, 12:30 PM   #528
Mr RCTech's Avatar
Even better charger is this:
http://www.ebay.com/itm/321237656194...84.m1436.l2649
Mr RCTech is offline   Reply With Quote
Old 11-20-2013, 12:34 PM   #529
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Mr RCTech View Post
Do you really think a $200 charger off ebay, with no support is a wise purchase ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-20-2013, 03:39 PM   #530
Mr RCTech's Avatar
NO. This is my point.
If your looking for a cheap charger then I would say don't race in competition.
I personally don't try to save money when it comes to racing in competition.
Old 11-20-2013, 03:43 PM   #531
How much do you feel one should spend to charge batteries for racing in competition ?
Old 11-20-2013, 03:52 PM   #532
Super Moderator
Gotta agree it doesn't make sense to spend $200 on a 30 amp charger off ebay, when a well regarded and proven 40 amp PowerLab 6 can be bought from a reputable dealer for $175.
Dave H is offline   Reply With Quote
Old 11-20-2013, 05:53 PM   #533
Mr RCTech's Avatar
You want a charger to show real time IR, so you know the condition of the lipo before you race.
Having a HIGHER IR will effect the voltage sag in the pack which means slower lap times at the end of a race.
I have bought quite of few different chargers as well as lipos packs.
There is a HUGE difference....in lipos brands that have no sag in voltage.
IR has to be checked in a controlled environment (same temp).
Also, the way you store and charge makes all the difference maintaining low IR.
Old 11-20-2013, 09:17 PM   #534
Osiris 75's Avatar
Trader Rating: 17 (100%+)
To get the most out of your lipos.
First, buy good quality lipos if your racing.
Discharge only to 3.4 volts per cell (nothing lower)
I prefer to discharge to 3.4 volts per cell only on the first charge.
Charge at 12-20 amps and your good to go.
I prefer 20 amps first charge to heat them up internally.
This lowers the IR on the first charge.
If you don't think its an advantage then discharge your lipo at 30 amps.
And watch the voltage.
It's HUGE!
So, are you to discharge to 3.4v just when you get a new battery, then charge at 20A, or do this every time for race days? If the battery will be stored for a week or more after a race weekend?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS / EA MOTORSPORTS
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 11-20-2013, 11:16 PM   #535
Jochim_18's Avatar
I have been charging mine at 2C ever since I start using a charger that's is capable charging at 10amps... One time I accidentally charge my TP lipo battery at 10amps with a checkpoint charger.. I thought I ruined my batteries but when I run it I notice I got more punch with same pack so I start charging my batteries at a higher amp since then this is probably 2 1/2 years ago when start charging at 2C with no issues..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-21-2013, 05:52 PM   #536
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
If any of you guys need a big power supply to run your power hungry charger, pm me. I have or can build to meet any specs.
Dayton
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 11-22-2013, 12:31 PM   #537
Mr RCTech's Avatar
Yes.
If its really cold out then discharge until you get some heat into the pack.
Measured on the outside of the pack 7-8 degrees above ambient temperature
will keep lower IR.
Timing is key.
You want to peak the lipo no more then 8 minutes before you race.
Old 11-22-2013, 06:15 PM   #538
avs
avs's Avatar
PL6/PL8 both work really well but you don't see them much at the track.
Tony Shimko
avs is online now   Reply With Quote
Old 11-22-2013, 06:19 PM   #539
avs
avs's Avatar
so $200 for a charger is doing it on the cheap?
Tony Shimko
Old 11-22-2013, 06:21 PM   #540
fq06's Avatar
He's not referring to the price, he's talking about the quality.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
